Does anyone know the detailed working principle of RTX Lidar for generating point cloud?
RTX lidar simulates the light rays of a lidar sensor, then can return them as a point cloud either to visualize or be recorded for synthetic data.
Lets look at the code first.
import omni.kit.commands
from pxr import Gf
lidar_config = "Example_Rotary"
# 1. Create The Camera
_, sensor = omni.kit.commands.execute(
"IsaacSensorCreateRtxLidar",
path="/sensor",
parent=None,
config=lidar_config,
translation=(0, 0, 1.0),
orientation=Gf.Quatd(1,0,0,0),
# 2. Create and Attach a render product to the camera
render_product = rep.create.render_product(sensor.GetPath(), [1, 1])
# 3. Create Annotator to read the data from with annotator.get_data()
annotator = rep.AnnotatorRegistry.get_annotator("RtxSensorCpuIsaacCreateRTXLidarScanBuffer")
annotator.attach(render_product)
# 4. Create a Replicator Writer that "writes" points into the scene for debug viewing
writer = rep.writers.get("RtxLidarDebugDrawPointCloudBuffer")
writer.attach(render_product)
You can run this in script editor and it will create a running lidar when you hit play.
This will also make a action graph holding the setup of the pipeline
to open the graph
Window > Visual Scripting > Action graph
Select - Edit Action Graph
Select - Render/postprocess/SDGPipeline
SDG Omnigraph
If you want to change the color and size of the displayed points you can adjust that in the last node in the attributes panel
Back to the code
The line
lidar_config = “Example_Rotary”
can be changed to the sensor you want from the list below, which are the parameters of real world sensors.
These can be found here /AppData/local/ov/pkg/isaac-sim-4.0.0/lidar_configs
DONT MODIFY THESE FILES
To get the pointcloud data You’ll need to add somewhere in your script, create new tab in script editor like before run the code, you’ll see a print out in the console of an array
data = annotator.get_data()
points = data["data"]
print (points)
thats your actual pointcloud array
For an in-depth look at all the functions and nodes check out
hope this helps
Thanks for your patient answers. I have successfully implemented how to generate point clouds using RTX Lidar in the Isaac Sim. What I may want to know is whether RTX Lidar generates point clouds through real-time ray tracing technology, and what is its principle?
Yes it’s based on ray tracing, so it’s simulating light rays the same way that light is produced for RTX rendering in modern games
