I am using YouTube with RTX Video Enhancement. When it is on theatre mode, it is active. However, if I fullscreen it, it became inactive.
I already check that my Gpu driver are the latestest version and I even did a clean reinstall.
My browser is also the latest version.
I am using Window 11 Home.
Specs:
rtx3060 mobile
Samsung g50a 1440p
It sounds like you’re experiencing an issue with RTX Video Enhancement not working properly in fullscreen mode on YouTube. Since you’ve already updated your GPU driver and browser, here are a few additional steps you can try:
Check your NVIDIA Control Panel settings. Ensure that RTX Video Enhancement is enabled and configured correctly.
Disable hardware acceleration in your browser settings and then re-enable it. Sometimes toggling this option can resolve display issues.
Try using a different browser to see if the issue persists. This can help determine if the problem is browser-specific.
Adjust the resolution settings on your monitor. Ensure that it’s set to the native 1440p resolution.
Test the RTX Video Enhancement feature with other video players or streaming services to see if the problem is isolated to YouTube.
If none of these steps resolve the issue, consider reaching out to NVIDIA support for further assistance, as there may be specific compatibility issues with your setup.
I hope this tool will more beneficialChatgtpai.org
