RTX5080 cannot communicate with Nvidia driver
Hi, I am install open kernel nvidia like others post mention however I cannot communicate with GPU
driver: Nvidia-driver-570-open
hardware: RTX5080
error:
NVIDIA-SMI has failed because it couldn’t communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
I had tried install and purge any method but end up either No device found or cannot load ubuntu on install via software update
Recently, no communicate via install on official nvidia (.run), or cuda tool-kit
This is my last attempt, I install with open kernel with is command after clean nvidia all previous installation
“sudo apt install nvidia-driver-570-open” and error is no communicate..
bug_log.log (170.7 KB)
nvidia-bug-report.log.gz (202.0 KB)
[I am not good at solve this, I spend 3 days straight 24/7 to test each method but not work. I have reinstall linux several time or sometime chroot could help. I need to use ubuntu to run specific program that work with gpu. Then without any idea in my head right now. I come to this forum and hope someone find and suggest solution for me because I cannot do something on my computer right now.]
Thank in advance,
I am not an expert, but I was able to fix the problem by disabling Secure Boot, so if it’s currently enabled, try turning it off.
