Systerm : windows 10
Graphic card: gtx730
I use ffmpeg dxva2 to decode h265 stream , the app is block in driver , i search the web , it is supoort hevc ,but why blocked , it is block every time when i use h265 , the h264 is fine.I upgrade the driver but is not help ,the other computer is GT720 the same problem. when switch the video start play and stop.
here is the dump file
Image path: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_733101c735b9e264\nvd3dumx.dll
Image name: nvd3dumx.dll
Timestamp: Tue Aug 24 11:07:17 2021 (61246265)
CheckSum: 017E6806
ImageSize: 01793000
File version: 30.0.15.1006
Product version: 30.0.15.1006
File flags: 8 (Mask 3F) Private
File OS: 40004 NT Win32
File type: 3.4 Driver
File date: 00000000.00000000
Translations: 0409.04e4
CompanyName: NVIDIA Corporation
ProductName: NVIDIA Windows WDDM D3D driver
InternalName: NVD3DUM
OriginalFilename: NVD3DUM.DLL
ProductVersion: 30.0.15.1006
FileVersion: 30.0.15.1006
FileDescription: NVIDIA WDDM D3D Driver, Version 510.06
LegalCopyright: (C) 2021 NVIDIA Corporation. All rights reserved.
Microsoft (R) Windows Debugger Version 6.12.0002.633 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [D:\dump\0412\0412.dmp]
User Mini Dump File with Full Memory: Only application data is available
Symbol search path is: *** Invalid ***
- Symbol loading may be unreliable without a symbol search path. *
- Use .symfix to have the debugger choose a symbol path. *
- After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
Windows 7 Version 9200 MP (6 procs) Free x64
Product: WinNt, suite: SingleUserTS
Machine Name:
Debug session time: Thu Feb 24 16:12:25.000 2022 (UTC + 8:00)
System Uptime: 1 days 3:53:37.592
Process Uptime: 0 days 3:45:48.000
Loading unloaded module list
This dump file has a breakpoint exception stored in it.
The stored exception information can be accessed via .ecxr.
*** ERROR: Symbol file could not be found. Defaulted to export symbols for ntdll.dll -
ntdll!DbgBreakPoint:
00007ffa`44ac7360 cc int 3
0:053> ~*kpn
0 Id: 27ac.26e8 Suspend: 1 Teb: 00000000`00e32000 Unfrozen
Child-SP RetAddr Call Site
00 000000000113d8b8 00007ffa
44a3d7ed ntdll!NtWaitForAlertByThreadId+0x14
01 000000000113d8c0 00007ffa
44a3d511 ntdll!TpSimpleTryPost+0xc1d
02 000000000113d8f0 00007ffa
44a5a6bc ntdll!TpSimpleTryPost+0x941
03 000000000113d9f0 00007ffa
44a5a522 ntdll!RtlEnterCriticalSection+0x1dc
04 000000000113da50 00007ffa
12109b96 ntdll!RtlEnterCriticalSection+0x42
05 000000000113da80 00007ff9
bf2bdd7b OsCore!sdk_mutex_lock(struct LMutex1 * mutex = 0x00000000078af7a8)+0x56 [e:\01code\sdk22\trunk\libvautil\libvautil\libvautil.c @ 839] 06 00000000
0113dab0 00007ff9bf2bed5b NVSSDK!CLS_OsCoreApi::inner_sdk_mutex_lock(struct LMutex1 * mutex = 0x00000000
078af7a8)+0x2b [e:\01code\sdk22\trunk\commoncode\oscore\oscoreapi.cpp @ 505]
07 000000000113dae0 00007ff9
bef074e0 NVSSDK!api_sdk_mutex_lock(struct LMutex1 * mutex = 0x00000000078af7a8)+0x1b [e:\01code\sdk22\trunk\commoncode\oscore\oscoreapi.cpp @ 1321] 08 00000000
0113db10 00007ff9bef07434 NVSSDK!CLS_SingleLock::Lock(void)+0x30 [e:\01code\sdk22\trunk\commoncode\util\cls_singlelock.cpp @ 26] 09 00000000
0113db40 00007ff9bf1aa6c0 NVSSDK!CLS_SingleLock::CLS_SingleLock(struct LMutex1 * _pMutex = 0x00000000
078af7a8, bool blLockOnCreate = true)+0x54 [e:\01code\sdk22\trunk\commoncode\util\cls_singlelock.cpp @ 14]
0a 000000000113db70 00007ff9
bf1b2a95 NVSSDK!CLS_Server::StopPlayEx(struct tagRecvInfo * _tInfo = 0x000000000113dc80, int _iParam = 0n1)+0x40 [e:\01code\sdk22\trunk\nvssdk\realize_mini\cls_server_mini.cpp @ 3045] 0b 00000000
0113dc20 00007ff9bf1ba6f7 NVSSDK!CLS_ServerList::StopPlayEx(unsigned long _ulID = 0x1330, unsigned int _iParam = 1)+0xe5 [e:\01code\sdk22\trunk\nvssdk\realize_mini\cls_serverlist_mini.cpp @ 1017] 0c 00000000
0113dcc0 00007ff63f10033b NVSSDK!NetClient_StopPlayEx(unsigned int _ulID = 0x1330, unsigned int _iParam = 1)+0x37 [e:\01code\sdk22\trunk\nvssdk\realize_mini\netsdkclient_mini.cpp @ 1230] 0d 00000000
0113dd00 00007ff63f0fda69 TestSwitch_VC!Inner_StopPlay(unsigned int _uiConID = 1)+0x2b [e:\01code\sdk_all\demo\testswitch_vc\business\business.cpp @ 1174] 0e 00000000
0113dd30 00007ff63f0fce87 TestSwitch_VC!Inner_StopOneItem(struct _SwitchItem * _ptItem = 0x00000000
000006a4, int _blForceStop = 0n1616928865)+0xf9 [e:\01code\sdk_all\demo\testswitch_vc\business\business.cpp @ 462]
0f 000000000113dd70 00007ff6
3f0f34f4 TestSwitch_VC!Inner_StopSwitch(int iIndexLow = 0n18082736, int iIndexHigh = 0n1059980192, int blForceStop = 0n1022)+0x97 [e:\01code\sdk_all\demo\testswitch_vc\business\business.cpp @ 249]
10 000000000113ddb0 00007ff6
3f108970 TestSwitch_VC!CTestSwitchDlg::OnBnClickedButtonSwitch(void)+0x1c4 [e:\01code\sdk_all\demo\testswitch_vc\windows\testswitchdlg.cpp @ 521]
11 000000000113ddf0 00007ff6
3f108bb0 TestSwitch_VC!AfxDispatchCmdMsg(class CCmdTarget * pTarget = 0x0000000000000000, unsigned int nID = 0x3502f697, int nCode = 0n-1002373064, <function> * pfn = 0x00000000
0113df01, void * pExtra = 0x0000000000000000, unsigned int64 nSig = 0x39, struct AFX_CMDHANDLERINFO * pHandlerInfo = 0x00000000
00000000)+0xc4 [f:\dd\vctools\vc7libs\ship\atlmfc\src\mfc\cmdtarg.cpp @ 82]
12 000000000113de20 00007ff6
3f2271a6 TestSwitch_VC!CCmdTarget::OnCmdMsg(unsigned int nID = 0, int nCode = 0n18082736, void * pExtra = 0x00000000011d0000, struct AFX_CMDHANDLERINFO * pHandlerInfo = 0x00000000
00000000)+0x180 [f:\dd\vctools\vc7libs\ship\atlmfc\src\mfc\cmdtarg.cpp @ 381]
13 000000000113de80 00007ff6
3f1103d8 TestSwitch_VC!CPropertySheet::OnCmdMsg(unsigned int nID = 0x417ca, int nCode = 0n0, void * pExtra = 0x000000000113ebb0, struct AFX_CMDHANDLERINFO * pHandlerInfo = 0x00000000
00000000)+0x32 [f:\dd\vctools\vc7libs\ship\atlmfc\src\mfc\dlgprop.cpp @ 814]
14 000000000113dec0 00007ff6
3f1112eb TestSwitch_VC!CWnd::OnCommand(unsigned int64 wParam = 0x111, int64 lParam = 0n268234)+0xcc [f:\dd\vctools\vc7libs\ship\atlmfc\src\mfc\wincore.cpp @ 2364]
15 000000000113df50 00007ff6
3f10ba98 TestSwitch_VC!CWnd::OnWndMsg(unsigned int message = 0x111, unsigned int64 wParam = 0x3fe, int64 lParam = 0n268234, int64 * pResult = 0x000000000113e0d0)+0x5f [f:\dd\vctools\vc7libs\ship\atlmfc\src\mfc\wincore.cpp @ 1769] 16 00000000
0113e090 00007ff63f10f2f2 TestSwitch_VC!CWnd::WindowProc(unsigned int message = 0x417ca, unsigned int64 wParam = 0x3fe, int64 lParam = 0n19900784)+0x38 [f:\dd\vctools\vc7libs\ship\atlmfc\src\mfc\wincore.cpp @ 1755] 17 00000000
0113e0d0 00007ff63f10f3ad TestSwitch_VC!AfxCallWndProc(class CWnd * pWnd = 0x00000000
0036116c, struct HWND * hWnd = 0x00000000000417ca, unsigned int nMsg = 0x111, unsigned int64 wParam = 0, int64 lParam = 0n268234)+0xfe [f:\dd\vctools\vc7libs\ship\atlmfc\src\mfc\wincore.cpp @ 240] *** ERROR: Symbol file could not be found. Defaulted to export symbols for user32.dll - 18 00000000
0113e170 00007ffa42de1c4c TestSwitch_VC!AfxWndProc(struct HWND__ * hWnd = 0x00000000
00000001, unsigned int nMsg = 0x113e378, unsigned int64 wParam = 0, int64 lParam = 0n0)+0x59 [f:\dd\vctools\vc7libs\ship\atlmfc\src\mfc\wincore.cpp @ 402]
19 000000000113e1b0 00007ffa
42de09e3 user32!CallWindowProcW+0x43c
1a 000000000113e320 00007ffa
42de0737 user32!SendMessageW+0x3e3
*** ERROR: Symbol file could not be found. Defaulted to export symbols for TSafeDoc64.dll -
1b 000000000113e3c0 00007ffa
34f8186b user32!SendMessageW+0x137
*** ERROR: Symbol file could not be found. Defaulted to export symbols for DtFrame64.dll -
1c 000000000113e420 00007ffa
33a33470 TSafeDoc64+0x7186b
*** ERROR: Symbol file could not be found. Defaulted to export symbols for comctl32.dll -
1d 000000000113e490 00007ffa
399350bf DtFrame64!EATUninstallRaw+0x71b70
1e 000000000113e530 00007ffa
39968822 comctl32!GetWindowSubclass+0xa48f
1f 000000000113e560 00007ffa
42de1c4c comctl32!SetWindowSubclass+0x12f2
20 000000000113e670 00007ffa
42de0ea6 user32!CallWindowProcW+0x43c
21 000000000113e7e0 00007ffa
42de6084 user32!DispatchMessageW+0x2b6
22 000000000113e860 00007ffa
42e29b6c user32!IsDialogMessageW+0x104
23 000000000113e8c0 00007ff6
3f113230 user32!IsDialogMessage+0x7c
24 000000000113e8f0 00007ff6
3f10c20c TestSwitch_VC!CWnd::IsDialogMessageA(struct tagMSG * lpMsg = 0x00007ff63f325070)+0x38 [f:\dd\vctools\vc7libs\ship\atlmfc\src\mfc\winocc.cpp @ 198] 25 00000000
0113e920 00007ff63f106a4f TestSwitch_VC!CWnd::PreTranslateInput(struct tagMSG * lpMsg = 0x00007ff6
3f325070)+0x28 [f:\dd\vctools\vc7libs\ship\atlmfc\src\mfc\wincore.cpp @ 4331]
26 000000000113e950 00007ff6
3f10edc2 TestSwitch_VC!CDialog::PreTranslateMessage(struct tagMSG * pMsg = 0x00000000012fa9c8)+0xc3 [f:\dd\vctools\vc7libs\ship\atlmfc\src\mfc\dlgcore.cpp @ 80] 27 00000000
0113e980 00007ff63f1094bb TestSwitch_VC!CWnd::WalkPreTranslateTree(struct HWND__ * hWndStop = 0x00000000
0113ebb0, struct tagMSG * pMsg = 0x0000000000000000)+0x3a [f:\dd\vctools\vc7libs\ship\atlmfc\src\mfc\wincore.cpp @ 2946] 28 00000000
0113e9b0 00007ff63f10951b TestSwitch_VC!AfxInternalPreTranslateMessage(struct tagMSG * pMsg = 0x00000000
012fa9c8)+0x67 [f:\dd\vctools\vc7libs\ship\atlmfc\src\mfc\thrdcore.cpp @ 233]
29 000000000113e9e0 00007ff6
3f1096c2 TestSwitch_VC!AfxPreTranslateMessage(struct tagMSG * pMsg = 0x000000000113ebb0)+0x23 [f:\dd\vctools\vc7libs\ship\atlmfc\src\mfc\thrdcore.cpp @ 252] 2a 00000000
0113ea10 00007ff63f109707 TestSwitch_VC!AfxInternalPumpMessage(void)+0x3a [f:\dd\vctools\vc7libs\ship\atlmfc\src\mfc\thrdcore.cpp @ 178] 2b 00000000
0113ea40 00007ff63f10e18a TestSwitch_VC!AfxPumpMessage(void)+0x1b [f:\dd\vctools\vc7libs\ship\atlmfc\src\mfc\thrdcore.cpp @ 190] 2c 00000000
0113ea70 00007ff63f1072ba TestSwitch_VC!CWnd::RunModalLoop(unsigned long dwFlags = 0x3f0f0000)+0xea [f:\dd\vctools\vc7libs\ship\atlmfc\src\mfc\wincore.cpp @ 4386] 2d 00000000
0113ead0 00007ff63f0f1639 TestSwitch_VC!CDialog::DoModal(void)+0x1c6 [f:\dd\vctools\vc7libs\ship\atlmfc\src\mfc\dlgcore.cpp @ 588] 2e 00000000
0113eb80 00007ff63f277409 TestSwitch_VC!CTestSwitchApp::InitInstance(void)+0x49 [e:\01code\sdk_all\demo\testswitch_vc\windows\testswitch_vc.cpp @ 52] 2f 00000000
0113f8d0 00007ff63f25ab8b TestSwitch_VC!AfxWinMain(struct HINSTANCE__ * hInstance = 0x00000000
00000000, struct HINSTANCE * hPrevInstance = 0x0000000000000000, char * lpCmdLine = 0x00007ffa
44a24830 “H???”, int nCmdShow = 0n1057947648)+0x75 [f:\dd\vctools\vc7libs\ship\atlmfc\src\mfc\winmain.cpp @ 37]
*** ERROR: Symbol file could not be found. Defaulted to export symbols for kernel32.dll -
30 000000000113f910 00007ffa
438554e0 TestSwitch_VC!__tmainCRTStartup(void)+0x187 [f:\dd\vctools\crt_bld\self_64_amd64\crt\src\crt0.c @ 263]
31 000000000113f9c0 00007ffa
44a2485b kernel32!BaseThreadInitThunk+0x10
32 000000000113f9f0 00000000
00000000 ntdll!RtlUserThreadStart+0x2b
1 Id: 27ac.4c2c Suspend: 1 Teb: 00000000`00e3a000 Unfrozen
*** ERROR: Symbol file could not be found. Defaulted to export symbols for KERNELBASE.dll -
00 0000000003c9f928 00007ffa
41f5fb10 ntdll!NtWaitForMultipleObjects+0x14
01 0000000003c9f930 00007ffa
41f5fa0e KERNELBASE!WaitForMultipleObjectsEx+0xf0
*** ERROR: Symbol file could not be found. Defaulted to export symbols for winhadnt64.dll -
02 0000000003c9fc20 00007ffa
346648d7 KERNELBASE!WaitForMultipleObjects+0xe
03 0000000003c9fc60 00007ffa
34665670 winhadnt64!DelPassthru+0x1367
04 0000000003c9fcb0 00007ffa
438554e0 winhadnt64!DelPassthru+0x2100
05 0000000003c9fe90 00007ffa
06 0000000003c9fec0 00000000
2 Id: 27ac.4144 Suspend: 1 Teb: 00000000`00e3c000 Unfrozen
00 0000000003d9f9a8 00007ffa
41f52a4e ntdll!ZwWaitForSingleObject+0x14
*** ERROR: Symbol file could not be found. Defaulted to export symbols for TMailHook64.dll -
01 0000000003d9f9b0 00007ffa
3311889a KERNELBASE!WaitForSingleObjectEx+0x8e
02 0000000003d9fa50 00007ffa
33140042 TMailHook64+0x1889a
03 0000000003d9faa0 00007ffa
438554e0 TMailHook64!SetEnableNetSecurity+0x17b62
04 0000000003d9fad0 00007ffa
05 0000000003d9fb00 00000000
3 Id: 27ac.3d78 Suspend: 1 Teb: 00000000`00e3e000 Unfrozen
00 000000000467fb08 00007ffa
01 000000000467fb10 00007ffa
350c6fad KERNELBASE!WaitForSingleObjectEx+0x8e
02 000000000467fbb0 00007ffa
35132222 TSafeDoc64!DeleteOcularSDDeleteFile+0x4a2d
03 000000000467fc80 00007ffa
438554e0 TSafeDoc64!DeleteOcularSDDeleteFile+0x6fca2
04 000000000467fcb0 00007ffa
05 000000000467fce0 00000000
4 Id: 27ac.71c4 Suspend: 1 Teb: 00000000`00e40000 Unfrozen
00 000000000477fb38 00007ffa
01 000000000477fb40 00007ffa
02 000000000477fe30 00007ffa
34f50034 KERNELBASE!WaitForMultipleObjects+0xe
03 000000000477fe70 00007ffa
35132222 TSafeDoc64+0x40034
04 000000000477fec0 00007ffa
05 000000000477fef0 00007ffa
06 000000000477ff20 00000000
5 Id: 27ac.6350 Suspend: 1 Teb: 00000000`00e42000 Unfrozen
00 000000000487f6a8 00007ffa
01 000000000487f6b0 00007ffa
02 000000000487f9a0 00007ffa
03 000000000487f9e0 00007ffa
04 000000000487fa30 00007ffa
05 000000000487fa60 00007ffa
06 000000000487fa90 00000000
6 Id: 27ac.51d8 Suspend: 1 Teb: 00000000`00e44000 Unfrozen
00 000000000497f738 00007ffa
01 000000000497f740 00007ffa
02 000000000497fa30 00007ffa
03 000000000497fa70 00007ffa
04 000000000497fac0 00007ffa
05 000000000497faf0 00007ffa
06 000000000497fb20 00000000
7 Id: 27ac.2bc4 Suspend: 1 Teb: 00000000`00e46000 Unfrozen
00 0000000004a7fcd8 00007ffa
01 0000000004a7fce0 00007ffa
34f502a8 KERNELBASE!WaitForSingleObjectEx+0x8e
02 0000000004a7fd80 00007ffa
35132222 TSafeDoc64+0x402a8
03 0000000004a7fdb0 00007ffa
04 0000000004a7fde0 00007ffa
05 0000000004a7fe10 00000000
8 Id: 27ac.1bdc Suspend: 1 Teb: 00000000`00e48000 Unfrozen
00 0000000004b7f6d8 00007ffa
01 0000000004b7f6e0 00007ffa
34f4c6b8 KERNELBASE!WaitForSingleObjectEx+0x8e
02 0000000004b7f780 00007ffa
34f4c033 TSafeDoc64+0x3c6b8
03 0000000004b7f7b0 00007ffa
34f4c529 TSafeDoc64+0x3c033
04 0000000004b7f7f0 00007ffa
35132222 TSafeDoc64+0x3c529
05 0000000004b7f820 00007ffa
06 0000000004b7f850 00007ffa
07 0000000004b7f880 00000000
9 Id: 27ac.498c Suspend: 1 Teb: 00000000`00e4a000 Unfrozen
00 0000000004d5f7c8 00007ffa
01 0000000004d5f7d0 00007ffa
351b2696 KERNELBASE!WaitForSingleObjectEx+0x8e
02 0000000004d5f870 00007ffa
351b3287 TSafeDoc64!DeleteOcularSDDeleteFile+0xf0116
03 0000000004d5f8f0 00007ffa
351ae155 TSafeDoc64!DeleteOcularSDDeleteFile+0xf0d07
04 0000000004d5fa10 00007ffa
351ae8b9 TSafeDoc64!DeleteOcularSDDeleteFile+0xebbd5
05 0000000004d5fa50 00007ffa
351ac8e4 TSafeDoc64!DeleteOcularSDDeleteFile+0xec339
06 0000000004d5fa90 00007ffa
35132222 TSafeDoc64!DeleteOcularSDDeleteFile+0xea364
07 0000000004d5fac0 00007ffa
08 0000000004d5faf0 00007ffa
09 0000000004d5fb20 00000000
10 Id: 27ac.2ed0 Suspend: 1 Teb: 00000000`00e4c000 Unfrozen
00 0000000005dfeea8 00007ffa
01 0000000005dfeeb0 00007ffa
12109dbe KERNELBASE!WaitForSingleObjectEx+0x8e
02 0000000005dfef50 00007ff9
e38034bb OsCore!sdk_thread_join(struct LThread1 * thr = 0x0000000015b31230)+0x5e [e:\01code\sdk22\trunk\libvautil\libvautil\libvautil.c @ 894] 03 00000000
05dfef80 00007ff9e3803c2b PlaySdkM4!CLS_OsCoreApi::inner_sdk_thread_join(struct LThread1 * thr = 0x00000000
15b31230)+0x2b [e:\01code\sdk22\trunk\commoncode\oscore\oscoreapi.cpp @ 529]
04 0000000005dfefb0 00007ff9
e380e700 PlaySdkM4!api_sdk_thread_join(struct LThread1 * thr = 0x0000000015b31230)+0x1b [e:\01code\sdk22\trunk\commoncode\oscore\oscoreapi.cpp @ 1341] 05 00000000
05dfefe0 00007ff9e38461a2 PlaySdkM4!CLS_Player::DestroyPlayer(int _iDDrawIndex = 0n0)+0x2e0 [e:\01code\sdk22\trunk\avplaysdk\avplayer\avplayer.cpp @ 2488] 06 00000000
05dff030 00007ff9bf2d33d2 PlaySdkM4!TC_DeletePlayerEx(int _iID = 0n48, int _iParam = 0n1)+0x1f2 [e:\01code\sdk22\trunk\avplaysdk\interface\avplayinterface.cpp @ 1360] 07 00000000
05dff080 00007ff9bf2d117e NVSSDK!CLS_PlaySdk::DeletePlayerEx(int _iID = 0n48, int _iParam = 0n1)+0x82 [e:\01code\sdk22\trunk\nvssdk\decoder\cls_playsdk.cpp @ 417] 08 00000000
05dff0b0 00007ff9bf19fa89 NVSSDK!CLS_Decoder::StopPlayEx(int _iParam = 0n1, int _iDDrawIndex = 0n0)+0x7e [e:\01code\sdk22\trunk\nvssdk\decoder\cls_decoder.cpp @ 293] 09 00000000
05dff0f0 00007ff9bf19fe5c NVSSDK!CLS_BaseLayer::StopPlayEx(int _iParam = 0n1, int _iDrawIndex = 0n0)+0x29 [e:\01code\sdk22\trunk\nvssdk\datalayer\cls_baselayer.h @ 181] 0a 00000000
05dff120 00007ff9bf1aa81b NVSSDK!CLS_DataChan::StopPlayEx(int _iParam = 0n1, int _iDDrawIndex = 0n0)+0x2c [e:\01code\sdk22\trunk\nvssdk\serverbase\cls_datachan.h @ 121] 0b 00000000
05dff150 00007ff9bf1b2a95 NVSSDK!CLS_Server::StopPlayEx(struct tagRecvInfo * _tInfo = 0x00000000
05dff260, int _iParam = 0n1)+0x19b [e:\01code\sdk22\trunk\nvssdk\realize_mini\cls_server_mini.cpp @ 3054]
0c 0000000005dff200 00007ff9
0d 0000000005dff2a0 00007ff6
0e 0000000005dff2e0 00007ff6
0f 0000000005dff310 00007ff6
3f0fce87 TestSwitch_VC!Inner_StopOneItem(struct SwitchItem * ptItem = 0x00000000000006a4, int _blForceStop = 0n1616928865)+0xf9 [e:\01code\sdk_all\demo\testswitch_vc\business\business.cpp @ 462] 10 00000000
05dff350 00007ff63f0fccca TestSwitch_VC!Inner_StopSwitch(int _iIndexLow = 0n0, int _iIndexHigh = 0n-2147459056, int _blForceStop = 0n275)+0x97 [e:\01code\sdk_all\demo\testswitch_vc\business\business.cpp @ 249] 11 00000000
05dff390 00007ffa1210e110 TestSwitch_VC!DoTestSwitchTimer(void * _pvUsr = 0x00000000
07376e80)+0x5a [e:\01code\sdk_all\demo\testswitch_vc\business\business.cpp @ 201]
12 0000000005dff3c0 00007ffa
42de1c4c OsCore!OsWindowProc(struct HWND * hwnd = 0x0000000000291506, unsigned int uMsg = 0x113, unsigned int64 wParam = 0, int64 lParam = 0n0)+0x300 [e:\01code\sdk22\trunk\libvautil\libvautil\windows\os_win32.c @ 609] 13 00000000
05dff460 00007ffa42de0ea6 user32!CallWindowProcW+0x43c 14 00000000
05dff5d0 00007ffa1210e607 user32!DispatchMessageW+0x2b6 15 00000000
05dff650 00007ffa1211a713 OsCore!os_main_thread(void * context = 0x00000000
00000000)+0x147 [e:\01code\sdk22\trunk\libvautil\libvautil\windows\os_win32.c @ 736]
16 0000000005dff870 00007ffa
1211a7c7 OsCore!_callthreadstartex(void)+0x17 [f:\dd\vctools\crt_bld\self_64_amd64\crt\src\threadex.c @ 348]
17 0000000005dff8a0 00007ffa
438554e0 OsCore!_threadstartex(void * ptd = 0x0000000000000000)+0x9f [f:\dd\vctools\crt_bld\self_64_amd64\crt\src\threadex.c @ 326] 18 00000000
05dff8d0 00007ffa44a2485b kernel32!BaseThreadInitThunk+0x10 19 00000000
05dff900 00000000`00000000 ntdll!RtlUserThreadStart+0x2b
11 Id: 27ac.14bc Suspend: 1 Teb: 00000000`00e4e000 Unfrozen
*** ERROR: Symbol file could not be found. Defaulted to export symbols for winmm.dll -
00 0000000005fffc18 00007ffa
38412631 ntdll!NtWaitForMultipleObjects+0x14
01 0000000005fffc20 00007ffa
438554e0 winmm!timeEndPeriod+0x3b1
02 0000000005fffda0 00007ffa
03 0000000005fffdd0 00000000
12 Id: 27ac.6b14 Suspend: 1 Teb: 00000000`00e50000 Unfrozen
00 0000000007c1f8e8 00007ffa
01 0000000007c1f8f0 00007ffa
02 0000000007c1f920 00007ffa
03 0000000007c1fa20 00007ffa
04 0000000007c1fa80 00007ffa
05 0000000007c1fab0 00007ff9
07c1fae0 00007ff9bf2bed5b NVSSDK!CLS_OsCoreApi::inner_sdk_mutex_lock(struct LMutex1 * mutex = 0x00000000
07 0000000007c1fb10 00007ff9
07c1fb40 00007ff9bef07434 NVSSDK!CLS_SingleLock::Lock(void)+0x30 [e:\01code\sdk22\trunk\commoncode\util\cls_singlelock.cpp @ 26] 09 00000000
07c1fb70 00007ff9bf1a1ab9 NVSSDK!CLS_SingleLock::CLS_SingleLock(struct LMutex1 * _pMutex = 0x00000000
0a 0000000007c1fba0 00007ff9
bf1afb63 NVSSDK!CLS_Server::TimeToProcessData(struct _DataPackageInfo * _ptInfo = 0x000000001345b590)+0x59 [e:\01code\sdk22\trunk\nvssdk\realize_mini\cls_server_mini.cpp @ 394] 0b 00000000
07c1fc50 00007ff9bf1af8eb NVSSDK!CLS_ServerList::TimeToProcessData(void * _pvArgs = 0x00000000
0789a8a8)+0x213 [e:\01code\sdk22\trunk\nvssdk\realize_mini\cls_serverlist_mini.cpp @ 125]
0c 0000000007c1fcc0 00007ff9
bef08167 NVSSDK!ThreadPollFun(void * _pvArgs = 0x000000000789a8a8)+0x1b [e:\01code\sdk22\trunk\nvssdk\realize_mini\cls_serverlist_mini.cpp @ 61] 0d 00000000
07c1fcf0 00007ffa1211a713 NVSSDK!CLS_ThreadPool::ThreadWorker(void * _pParam = 0x00000000
0789a8a8)+0x47 [e:\01code\sdk22\trunk\commoncode\common\cls_threadpool.cpp @ 99]
0e 0000000007c1fd30 00007ffa
0f 0000000007c1fd60 00007ffa
438554e0 OsCore!_threadstartex(void * ptd = 0x0000000000000000)+0x9f [f:\dd\vctools\crt_bld\self_64_amd64\crt\src\threadex.c @ 326] 10 00000000
07c1fd90 00007ffa44a2485b kernel32!BaseThreadInitThunk+0x10 11 00000000
07c1fdc0 00000000`00000000 ntdll!RtlUserThreadStart+0x2b
13 Id: 27ac.75d8 Suspend: 1 Teb: 00000000`00e52000 Unfrozen
00 0000000007d1f638 00007ffa
44a7b5c3 ntdll!NtDelayExecution+0x14
01 0000000007d1f640 00007ffa
41f5b3a1 ntdll!RtlDelayExecution+0x43
02 0000000007d1f670 00007ff9
bef0bef5 KERNELBASE!SleepEx+0x71
03 0000000007d1f6f0 00007ff9
bf1afa0f NVSSDK!usleep(int _iMicroSecond = 0n1000)+0x35 [e:\01code\sdk22\trunk\commoncode\common\commonfun.cpp @ 1427]
04 0000000007d1f720 00007ff9
bf1af8eb NVSSDK!CLS_ServerList::TimeToProcessData(void * _pvArgs = 0x000000000789a8c0)+0xbf [e:\01code\sdk22\trunk\nvssdk\realize_mini\cls_serverlist_mini.cpp @ 96] 05 00000000
07d1f790 00007ff9bef08167 NVSSDK!ThreadPollFun(void * _pvArgs = 0x00000000
0789a8c0)+0x1b [e:\01code\sdk22\trunk\nvssdk\realize_mini\cls_serverlist_mini.cpp @ 61]
06 0000000007d1f7c0 00007ffa
1211a713 NVSSDK!CLS_ThreadPool::ThreadWorker(void * _pParam = 0x000000000789a8c0)+0x47 [e:\01code\sdk22\trunk\commoncode\common\cls_threadpool.cpp @ 99] 07 00000000
07d1f800 00007ffa1211a7c7 OsCore!_callthreadstartex(void)+0x17 [f:\dd\vctools\crt_bld\self_64_amd64\crt\src\threadex.c @ 348] 08 00000000
07d1f830 00007ffa438554e0 OsCore!_threadstartex(void * ptd = 0x00000000
09 0000000007d1f860 00007ffa
0a 0000000007d1f890 00000000
14 Id: 27ac.79a8 Suspend: 1 Teb: 00000000`00e54000 Unfrozen
00 0000000007e1f978 00007ffa
01 0000000007e1f980 00007ffa
02 0000000007e1f9b0 00007ff9
03 0000000007e1fa30 00007ff9
04 0000000007e1fa60 00007ff9
bf1af8eb NVSSDK!CLS_ServerList::TimeToProcessData(void * _pvArgs = 0x000000000789a8d8)+0xbf [e:\01code\sdk22\trunk\nvssdk\realize_mini\cls_serverlist_mini.cpp @ 96] 05 00000000
07e1fad0 00007ff9bef08167 NVSSDK!ThreadPollFun(void * _pvArgs = 0x00000000
0789a8d8)+0x1b [e:\01code\sdk22\trunk\nvssdk\realize_mini\cls_serverlist_mini.cpp @ 61]
06 0000000007e1fb00 00007ffa
1211a713 NVSSDK!CLS_ThreadPool::ThreadWorker(void * _pParam = 0x000000000789a8d8)+0x47 [e:\01code\sdk22\trunk\commoncode\common\cls_threadpool.cpp @ 99] 07 00000000
07e1fb40 00007ffa1211a7c7 OsCore!_callthreadstartex(void)+0x17 [f:\dd\vctools\crt_bld\self_64_amd64\crt\src\threadex.c @ 348] 08 00000000
07e1fb70 00007ffa438554e0 OsCore!_threadstartex(void * ptd = 0x00000000
09 0000000007e1fba0 00007ffa
0a 0000000007e1fbd0 00000000
15 Id: 27ac.437c Suspend: 1 Teb: 00000000`00e56000 Unfrozen
00 0000000007f1f8b8 00007ffa
01 0000000007f1f8c0 00007ffa
02 0000000007f1f8f0 00007ff9
03 0000000007f1f970 00007ff9
04 0000000007f1f9a0 00007ff9
bf1af8eb NVSSDK!CLS_ServerList::TimeToProcessData(void * _pvArgs = 0x000000000789a8f0)+0xbf [e:\01code\sdk22\trunk\nvssdk\realize_mini\cls_serverlist_mini.cpp @ 96] 05 00000000
07f1fa10 00007ff9bef08167 NVSSDK!ThreadPollFun(void * _pvArgs = 0x00000000
0789a8f0)+0x1b [e:\01code\sdk22\trunk\nvssdk\realize_mini\cls_serverlist_mini.cpp @ 61]
06 0000000007f1fa40 00007ffa
1211a713 NVSSDK!CLS_ThreadPool::ThreadWorker(void * _pParam = 0x000000000789a8f0)+0x47 [e:\01code\sdk22\trunk\commoncode\common\cls_threadpool.cpp @ 99] 07 00000000
07f1fa80 00007ffa1211a7c7 OsCore!_callthreadstartex(void)+0x17 [f:\dd\vctools\crt_bld\self_64_amd64\crt\src\threadex.c @ 348] 08 00000000
07f1fab0 00007ffa438554e0 OsCore!_threadstartex(void * ptd = 0x00000000
09 0000000007f1fae0 00007ffa
0a 0000000007f1fb10 00000000
16 Id: 27ac.77b0 Suspend: 1 Teb: 00000000`00e58000 Unfrozen
00 000000000801f548 00007ffa
01 000000000801f550 00007ffa
02 000000000801f580 00007ff9
03 000000000801f600 00007ff9
04 000000000801f630 00007ff9
bf1af8eb NVSSDK!CLS_ServerList::TimeToProcessData(void * _pvArgs = 0x000000000789a908)+0xbf [e:\01code\sdk22\trunk\nvssdk\realize_mini\cls_serverlist_mini.cpp @ 96] 05 00000000
0801f6a0 00007ff9bef08167 NVSSDK!ThreadPollFun(void * _pvArgs = 0x00000000
0789a908)+0x1b [e:\01code\sdk22\trunk\nvssdk\realize_mini\cls_serverlist_mini.cpp @ 61]
06 000000000801f6d0 00007ffa
1211a713 NVSSDK!CLS_ThreadPool::ThreadWorker(void * _pParam = 0x000000000789a908)+0x47 [e:\01code\sdk22\trunk\commoncode\common\cls_threadpool.cpp @ 99] 07 00000000
0801f710 00007ffa1211a7c7 OsCore!_callthreadstartex(void)+0x17 [f:\dd\vctools\crt_bld\self_64_amd64\crt\src\threadex.c @ 348] 08 00000000
0801f740 00007ffa438554e0 OsCore!_threadstartex(void * ptd = 0x00000000
09 000000000801f770 00007ffa
0a 000000000801f7a0 00000000
17 Id: 27ac.555c Suspend: 1 Teb: 00000000`00e5a000 Unfrozen
00 000000000811f8f8 00007ffa
01 000000000811f900 00007ffa
02 000000000811f930 00007ff9
03 000000000811f9b0 00007ff9
04 000000000811f9e0 00007ff9
bf1af8eb NVSSDK!CLS_ServerList::TimeToProcessData(void * _pvArgs = 0x000000000789a920)+0xbf [e:\01code\sdk22\trunk\nvssdk\realize_mini\cls_serverlist_mini.cpp @ 96] 05 00000000
0811fa50 00007ff9bef08167 NVSSDK!ThreadPollFun(void * _pvArgs = 0x00000000
0789a920)+0x1b [e:\01code\sdk22\trunk\nvssdk\realize_mini\cls_serverlist_mini.cpp @ 61]
06 000000000811fa80 00007ffa
1211a713 NVSSDK!CLS_ThreadPool::ThreadWorker(void * _pParam = 0x000000000789a920)+0x47 [e:\01code\sdk22\trunk\commoncode\common\cls_threadpool.cpp @ 99] 07 00000000
0811fac0 00007ffa1211a7c7 OsCore!_callthreadstartex(void)+0x17 [f:\dd\vctools\crt_bld\self_64_amd64\crt\src\threadex.c @ 348] 08 00000000
0811faf0 00007ffa438554e0 OsCore!_threadstartex(void * ptd = 0x00000000
09 000000000811fb20 00007ffa
0a 000000000811fb50 00000000
18 Id: 27ac.597c Suspend: 1 Teb: 00000000`00e5c000 Unfrozen
00 0000000008a1f5c8 00007ffa
01 0000000008a1f5d0 00007ffa
02 0000000008a1f600 00007ffa
03 0000000008a1f700 00007ffa
04 0000000008a1f760 00007ffa
05 0000000008a1f790 00007ff9
08a1f7c0 00007ff9bf2bed5b NVSSDK!CLS_OsCoreApi::inner_sdk_mutex_lock(struct LMutex1 * mutex = 0x00000000
07 0000000008a1f7f0 00007ff9
08a1f820 00007ff9bef07434 NVSSDK!CLS_SingleLock::Lock(void)+0x30 [e:\01code\sdk22\trunk\commoncode\util\cls_singlelock.cpp @ 26] 09 00000000
08a1f850 00007ff9bf1a10bc NVSSDK!CLS_SingleLock::CLS_SingleLock(struct LMutex1 * _pMutex = 0x00000000
0a 0000000008a1f880 00007ff9
bf1afc61 NVSSDK!CLS_Server::CheckConnect(void)+0x2c [e:\01code\sdk22\trunk\nvssdk\realize_mini\cls_server_mini.cpp @ 183]
0b 0000000008a1f8f0 00007ff9
bf1af90b NVSSDK!CLS_ServerList::DoCheckConnection(void * _para = 0x0000000000000000)+0xb1 [e:\01code\sdk22\trunk\nvssdk\realize_mini\cls_serverlist_mini.cpp @ 155] 0c 00000000
08a1f940 00007ffa1211a713 NVSSDK!CheckConnection(void * _para = 0x00000000
00000000)+0x1b [e:\01code\sdk22\trunk\nvssdk\realize_mini\cls_serverlist_mini.cpp @ 66]
0d 0000000008a1f970 00007ffa
0e 0000000008a1f9a0 00007ffa
438554e0 OsCore!_threadstartex(void * ptd = 0x0000000000000000)+0x9f [f:\dd\vctools\crt_bld\self_64_amd64\crt\src\threadex.c @ 326] 0f 00000000
08a1f9d0 00007ffa44a2485b kernel32!BaseThreadInitThunk+0x10 10 00000000
08a1fa00 00000000`00000000 ntdll!RtlUserThreadStart+0x2b
19 Id: 27ac.4338 Suspend: 1 Teb: 00000000`00e5e000 Unfrozen
00 0000000008b1f5e8 00007ffa
01 0000000008b1f5f0 00007ffa
02 0000000008b1f620 00007ffa
03 0000000008b1f720 00007ffa
04 0000000008b1f780 00007ffa
05 0000000008b1f7b0 00007ff9
08b1f7e0 00007ff9bf2bed5b NVSSDK!CLS_OsCoreApi::inner_sdk_mutex_lock(struct LMutex1 * mutex = 0x00000000
07 0000000008b1f810 00007ff9
08b1f840 00007ff9bef07434 NVSSDK!CLS_SingleLock::Lock(void)+0x30 [e:\01code\sdk22\trunk\commoncode\util\cls_singlelock.cpp @ 26] 09 00000000
08b1f870 00007ff9bf1a18db NVSSDK!CLS_SingleLock::CLS_SingleLock(struct LMutex1 * _pMutex = 0x00000000
0a 0000000008b1f8a0 00007ff9
bf1afd88 NVSSDK!CLS_Server::HeartBeat(void)+0x2b [e:\01code\sdk22\trunk\nvssdk\realize_mini\cls_server_mini.cpp @ 357]
0b 0000000008b1f910 00007ff9
bf1af92b NVSSDK!CLS_ServerList::DoHeartBeat(void * _para = 0x0000000000000000)+0xd8 [e:\01code\sdk22\trunk\nvssdk\realize_mini\cls_serverlist_mini.cpp @ 193] 0c 00000000
08b1f970 00007ffa1211a713 NVSSDK!HeartBeat(void * _para = 0x00000000
00000000)+0x1b [e:\01code\sdk22\trunk\nvssdk\realize_mini\cls_serverlist_mini.cpp @ 71]
0d 0000000008b1f9a0 00007ffa
0e 0000000008b1f9d0 00007ffa
08b1fa00 00007ffa44a2485b kernel32!BaseThreadInitThunk+0x10 10 00000000
08b1fa30 00000000`00000000 ntdll!RtlUserThreadStart+0x2b
20 Id: 27ac.3c9c Suspend: 1 Teb: 00000000`00e60000 Unfrozen
00 0000000008c1f508 00007ffa
01 0000000008c1f510 00007ffa
02 0000000008c1f540 00007ffa
03 0000000008c1f640 00007ffa
04 0000000008c1f6a0 00007ffa
05 0000000008c1f6d0 00007ff9
08c1f700 00007ff9bf2bed5b NVSSDK!CLS_OsCoreApi::inner_sdk_mutex_lock(struct LMutex1 * mutex = 0x00000000
07 0000000008c1f730 00007ff9
08c1f760 00007ff9bef07434 NVSSDK!CLS_SingleLock::Lock(void)+0x30 [e:\01code\sdk22\trunk\commoncode\util\cls_singlelock.cpp @ 26] 09 00000000
08c1f790 00007ff9bf1a19d2 NVSSDK!CLS_SingleLock::CLS_SingleLock(struct LMutex1 * _pMutex = 0x00000000
0a 0000000008c1f7c0 00007ff9
bf1afea7 NVSSDK!CLS_Server::CheckGetParamDataList(void)+0x22 [e:\01code\sdk22\trunk\nvssdk\realize_mini\cls_server_mini.cpp @ 378]
0b 0000000008c1f820 00007ff9
bf1af94b NVSSDK!CLS_ServerList::DoCheckGetParamDataList(void * _para = 0x0000000000000000)+0xa7 [e:\01code\sdk22\trunk\nvssdk\realize_mini\cls_serverlist_mini.cpp @ 230] 0c 00000000
08c1f870 00007ffa1211a713 NVSSDK!CheckGetParamDataList(void * _para = 0x00000000
00000000)+0x1b [e:\01code\sdk22\trunk\nvssdk\realize_mini\cls_serverlist_mini.cpp @ 76]
0d 0000000008c1f8a0 00007ffa
0e 0000000008c1f8d0 00007ffa
08c1f900 00007ffa44a2485b kernel32!BaseThreadInitThunk+0x10 10 00000000
08c1f930 00000000`00000000 ntdll!RtlUserThreadStart+0x2b
21 Id: 27ac.7a58 Suspend: 1 Teb: 00000000`00e62000 Unfrozen
00 0000000008d1f7d8 00007ffa
01 0000000008d1f7e0 00007ffa
02 0000000008d1f810 00007ff9
03 0000000008d1f890 00007ff9
bf1c2f36 NVSSDK!usleep(int _iMicroSecond = 0n15000)+0x35 [e:\01code\sdk22\trunk\commoncode\common\commonfun.cpp @ 1427]
04 0000000008d1f8c0 00007ff9
bf1c2cc5 NVSSDK!CLS_MessageLoop::DoMessageLoop(void)+0xb6 [e:\01code\sdk22\trunk\nvssdk\serverbase\cls_messageloop.cpp @ 115]
05 0000000008d1f930 00007ffa
1211a713 NVSSDK!MessageLoop(void * _pvParam = 0x0000000000000000)+0x15 [e:\01code\sdk22\trunk\nvssdk\serverbase\cls_messageloop.cpp @ 50] 06 00000000
08d1f960 00007ffa1211a7c7 OsCore!_callthreadstartex(void)+0x17 [f:\dd\vctools\crt_bld\self_64_amd64\crt\src\threadex.c @ 348] 07 00000000
08d1f990 00007ffa438554e0 OsCore!_threadstartex(void * ptd = 0x00000000
08 0000000008d1f9c0 00007ffa
09 0000000008d1f9f0 00000000
22 Id: 27ac.1d40 Suspend: 1 Teb: 00000000`00e64000 Unfrozen
00 0000000008e1fa98 00007ffa
41f60a33 ntdll!NtRemoveIoCompletion+0x14
01 0000000008e1faa0 00007ff9
bf2ed2b6 KERNELBASE!GetQueuedCompletionStatus+0x53
02 0000000008e1fb00 00007ff9
bf2f5293 NVSSDK!IOWorkThreadProc(void * _lparam = 0x0000000000000000)+0x66 [e:\01code\sdk22\trunk\nvssdk\epoll_client\windows\cls_singlenetwork.cpp @ 40] 03 00000000
08e1fb80 00007ff9bf2f5347 NVSSDK!_callthreadstartex(void)+0x17 [f:\dd\vctools\crt_bld\self_64_amd64\crt\src\threadex.c @ 348] 04 00000000
08e1fbb0 00007ffa438554e0 NVSSDK!_threadstartex(void * ptd = 0x00000000
05 0000000008e1fbe0 00007ffa
06 0000000008e1fc10 00000000
23 Id: 27ac.7838 Suspend: 1 Teb: 00000000`00e66000 Unfrozen
00 0000000008f1f818 00007ffa
01 0000000008f1f820 00007ff9
02 0000000008f1f880 00007ff9
08f1f900 00007ff9bf2f5347 NVSSDK!_callthreadstartex(void)+0x17 [f:\dd\vctools\crt_bld\self_64_amd64\crt\src\threadex.c @ 348] 04 00000000
08f1f930 00007ffa438554e0 NVSSDK!_threadstartex(void * ptd = 0x00000000
05 0000000008f1f960 00007ffa
06 0000000008f1f990 00000000
24 Id: 27ac.7308 Suspend: 1 Teb: 00000000`00e68000 Unfrozen
00 000000000901f808 00007ffa
01 000000000901f810 00007ff9
02 000000000901f870 00007ff9
0901f8f0 00007ff9bf2f5347 NVSSDK!_callthreadstartex(void)+0x17 [f:\dd\vctools\crt_bld\self_64_amd64\crt\src\threadex.c @ 348] 04 00000000
0901f920 00007ffa438554e0 NVSSDK!_threadstartex(void * ptd = 0x00000000
05 000000000901f950 00007ffa
06 000000000901f980 00000000
25 Id: 27ac.3a0c Suspend: 1 Teb: 00000000`00e6a000 Unfrozen
00 000000000911f698 00007ffa
01 000000000911f6a0 00007ff9
02 000000000911f700 00007ff9
0911f780 00007ff9bf2f5347 NVSSDK!_callthreadstartex(void)+0x17 [f:\dd\vctools\crt_bld\self_64_amd64\crt\src\threadex.c @ 348] 04 00000000
0911f7b0 00007ffa438554e0 NVSSDK!_threadstartex(void * ptd = 0x00000000
05 000000000911f7e0 00007ffa
06 000000000911f810 00000000
26 Id: 27ac.4070 Suspend: 1 Teb: 00000000`00e6c000 Unfrozen
00 000000000921f7d8 00007ffa
01 000000000921f7e0 00007ff9
02 000000000921f840 00007ff9
0921f8c0 00007ff9bf2f5347 NVSSDK!_callthreadstartex(void)+0x17 [f:\dd\vctools\crt_bld\self_64_amd64\crt\src\threadex.c @ 348] 04 00000000
0921f8f0 00007ffa438554e0 NVSSDK!_threadstartex(void * ptd = 0x00000000
05 000000000921f920 00007ffa
06 000000000921f950 00000000
27 Id: 27ac.6afc Suspend: 1 Teb: 00000000`00e6e000 Unfrozen
00 000000000931f788 00007ffa
01 000000000931f790 00007ff9
02 000000000931f7f0 00007ff9
0931f870 00007ff9bf2f5347 NVSSDK!_callthreadstartex(void)+0x17 [f:\dd\vctools\crt_bld\self_64_amd64\crt\src\threadex.c @ 348] 04 00000000
0931f8a0 00007ffa438554e0 NVSSDK!_threadstartex(void * ptd = 0x00000000
05 000000000931f8d0 00007ffa
06 000000000931f900 00000000
28 Id: 27ac.6e04 Suspend: 1 Teb: 00000000`00e70000 Unfrozen
00 000000000941f8d8 00007ffa
01 000000000941f8e0 00007ff9
02 000000000941f940 00007ff9
0941f9c0 00007ff9bf2f5347 NVSSDK!_callthreadstartex(void)+0x17 [f:\dd\vctools\crt_bld\self_64_amd64\crt\src\threadex.c @ 348] 04 00000000
0941f9f0 00007ffa438554e0 NVSSDK!_threadstartex(void * ptd = 0x00000000
05 000000000941fa20 00007ffa
06 000000000941fa50 00000000
29 Id: 27ac.7a20 Suspend: 1 Teb: 00000000`00e72000 Unfrozen
00 000000000951fb68 00007ffa
01 000000000951fb70 00007ff9
02 000000000951fbd0 00007ff9
0951fc50 00007ff9bf2f5347 NVSSDK!_callthreadstartex(void)+0x17 [f:\dd\vctools\crt_bld\self_64_amd64\crt\src\threadex.c @ 348] 04 00000000
0951fc80 00007ffa438554e0 NVSSDK!_threadstartex(void * ptd = 0x00000000
05 000000000951fcb0 00007ffa
06 000000000951fce0 00000000
30 Id: 27ac.7884 Suspend: 1 Teb: 00000000`00e74000 Unfrozen
00 000000000961f878 00007ffa
01 000000000961f880 00007ff9
02 000000000961f8e0 00007ff9
0961f960 00007ff9bf2f5347 NVSSDK!_callthreadstartex(void)+0x17 [f:\dd\vctools\crt_bld\self_64_amd64\crt\src\threadex.c @ 348] 04 00000000
0961f990 00007ffa438554e0 NVSSDK!_threadstartex(void * ptd = 0x00000000
05 000000000961f9c0 00007ffa
06 000000000961f9f0 00000000
31 Id: 27ac.7358 Suspend: 1 Teb: 00000000`00e76000 Unfrozen
00 000000000971f6d8 00007ffa
01 000000000971f6e0 00007ff9
02 000000000971f740 00007ff9
0971f7c0 00007ff9bf2f5347 NVSSDK!_callthreadstartex(void)+0x17 [f:\dd\vctools\crt_bld\self_64_amd64\crt\src\threadex.c @ 348] 04 00000000
0971f7f0 00007ffa438554e0 NVSSDK!_threadstartex(void * ptd = 0x00000000
05 000000000971f820 00007ffa
06 000000000971f850 00000000
32 Id: 27ac.755c Suspend: 1 Teb: 00000000`00e78000 Unfrozen
00 000000000991f9d8 00007ffa
01 000000000991f9e0 00007ff9
02 000000000991fa40 00007ff9
0991fac0 00007ff9bf2f5347 NVSSDK!_callthreadstartex(void)+0x17 [f:\dd\vctools\crt_bld\self_64_amd64\crt\src\threadex.c @ 348] 04 00000000
0991faf0 00007ffa438554e0 NVSSDK!_threadstartex(void * ptd = 0x00000000
05 000000000991fb20 00007ffa
06 000000000991fb50 00000000
33 Id: 27ac.61e0 Suspend: 1 Teb: 00000000`00e7a000 Unfrozen
00 0000000009a1f808 00007ffa
01 0000000009a1f810 00007ff9
02 0000000009a1f870 00007ff9
09a1f8f0 00007ff9bf2f5347 NVSSDK!_callthreadstartex(void)+0x17 [f:\dd\vctools\crt_bld\self_64_amd64\crt\src\threadex.c @ 348] 04 00000000
09a1f920 00007ffa438554e0 NVSSDK!_threadstartex(void * ptd = 0x00000000
05 0000000009a1f950 00007ffa
06 0000000009a1f980 00000000
34 Id: 27ac.6840 Suspend: 1 Teb: 00000000`00e7c000 Unfrozen
00 0000000009f1f598 00007ffa
01 0000000009f1f5a0 00007ffa
02 0000000009f1f5d0 00007ff9
03 0000000009f1f650 00007ff9
bf1da9cd NVSSDK!usleep(int _iMicroSecond = 0n10000)+0x35 [e:\01code\sdk22\trunk\commoncode\common\commonfun.cpp @ 1427]
04 0000000009f1f680 00007ff9
bf1c797b NVSSDK!CLS_ServerList::DoCheckActive(void * _pvPara = 0x0000000000000000)+0x1fd [e:\01code\sdk22\trunk\nvssdk\serverctrl\cls_serverlist.cpp @ 5706] 05 00000000
09f1f700 00007ffa1211a713 NVSSDK!CheckActive(void * _para = 0x00000000
00000000)+0x1b [e:\01code\sdk22\trunk\nvssdk\serverctrl\cls_serverlist.cpp @ 20]
06 0000000009f1f730 00007ffa
07 0000000009f1f760 00007ffa
438554e0 OsCore!_threadstartex(void * ptd = 0x0000000000000000)+0x9f [f:\dd\vctools\crt_bld\self_64_amd64\crt\src\threadex.c @ 326] 08 00000000
09f1f790 00007ffa44a2485b kernel32!BaseThreadInitThunk+0x10 09 00000000
09f1f7c0 00000000`00000000 ntdll!RtlUserThreadStart+0x2b
35 Id: 27ac.18c8 Suspend: 1 Teb: 00000000`00e7e000 Unfrozen
00 000000000a01fc38 00007ffa
01 000000000a01fc40 00007ffa
02 000000000a01fc70 00007ff9
03 000000000a01fcf0 00007ff9
bf16c930 NVSSDK!usleep(int _iMicroSecond = 0n1000000)+0x35 [e:\01code\sdk22\trunk\commoncode\common\commonfun.cpp @ 1427]
04 000000000a01fd20 00007ff9
bf16c20b NVSSDK!CLS_ActiveManage::ProcessActiveChan(void * _pvPara = 0x0000000000000000)+0x160 [e:\01code\sdk22\trunk\nvssdk\active\cls_activemanage.cpp @ 185] 05 00000000
0a01fd90 00007ffa1211a713 NVSSDK!ProcessActiveChanThread(void * _pvPara = 0x00000000
00000000)+0x1b [e:\01code\sdk22\trunk\nvssdk\active\cls_activemanage.cpp @ 13]
06 000000000a01fdc0 00007ffa
07 000000000a01fdf0 00007ffa
0a01fe20 00007ffa44a2485b kernel32!BaseThreadInitThunk+0x10 09 00000000
0a01fe50 00000000`00000000 ntdll!RtlUserThreadStart+0x2b
36 Id: 27ac.4a98 Suspend: 1 Teb: 00000000`00e8a000 Unfrozen
00 0000000015c6fbf8 00007ffa
01 0000000015c6fc00 00007ffa
02 0000000015c6fc30 00007ff9
e3801515 KERNELBASE!SleepEx+0x71
03 0000000015c6fcb0 00007ff9
e38501fe PlaySdkM4!os_usleep(int _iMicSec = 0n1000000)+0x35 [e:\01code\sdk22\trunk\commoncode\common\global_common.cpp @ 205]
04 0000000015c6fce0 00007ffa
1211a713 PlaySdkM4!CSingleFrameList::MemoryRecyclingThread(void * _pvParam = 0x000000000a1c8170)+0x4e [e:\01code\sdk22\trunk\avplaysdk\framelist\singleframelist.cpp @ 176] 05 00000000
15c6fdb0 00007ffa1211a7c7 OsCore!_callthreadstartex(void)+0x17 [f:\dd\vctools\crt_bld\self_64_amd64\crt\src\threadex.c @ 348] 06 00000000
15c6fde0 00007ffa438554e0 OsCore!_threadstartex(void * ptd = 0x00000000
07 0000000015c6fe10 00007ffa
08 0000000015c6fe40 00000000
37 Id: 27ac.820 Suspend: 1 Teb: 00000000`00e8e000 Unfrozen
00 000000001607f908 00007ffa
44a36c2f ntdll!ZwWaitForWorkViaWorkerFactory+0x14
01 000000001607f910 00007ffa
438554e0 ntdll!EtwNotificationRegister+0x5af
02 000000001607fc00 00007ffa
03 000000001607fc30 00000000
38 Id: 27ac.f2c Suspend: 1 Teb: 00000000`00f6a000 Unfrozen
00 00000000d139f968 00007ffa
*** ERROR: Symbol file could not be found. Defaulted to export symbols for d3d9.dll -
01 00000000d139f970 00007ffa
209789cc KERNELBASE!WaitForSingleObjectEx+0x8e
02 00000000d139fa10 00007ffa
438554e0 d3d9!Direct3DShaderValidatorCreate9+0x521cc
03 00000000d139fa40 00007ffa
04 00000000d139fa70 00000000
39 Id: 27ac.8648 Suspend: 1 Teb: 00000000`00f6e000 Unfrozen
00 00000000d3fade88 00007ffa
*** ERROR: Symbol file could not be found. Defaulted to export symbols for nvd3dumx.dll -
01 00000000d3fade90 00007ff9
d3efda1f KERNELBASE!WaitForSingleObjectEx+0x8e
02 00000000d3fadf30 00007ff9
d3eced7c nvd3dumx!QueryOglResource+0x259d7f
03 00000000d3fadf60 00007ff9
d3ecd241 nvd3dumx!QueryOglResource+0x22b0dc
04 00000000d3fadfb0 00007ff9
d3eb0c83 nvd3dumx!QueryOglResource+0x2295a1
05 00000000d3fae010 00007ff9
d3e54882 nvd3dumx!QueryOglResource+0x20cfe3
06 00000000d3fae1e0 00007ff9
d3df9683 nvd3dumx!QueryOglResource+0x1b0be2
07 00000000d3fae360 00007ff9
d3ca5e39 nvd3dumx!QueryOglResource+0x1559e3
08 00000000d3fae660 00007ffa
20975cae nvd3dumx!QueryOglResource+0x2199
09 00000000d3fae6b0 00007ffa
20885a77 d3d9!Direct3DShaderValidatorCreate9+0x4f4ae
0a 00000000d3fae6e0 00007ffa
2085b4d5 d3d9!Direct3DCreate9Ex+0x33227
*** ERROR: Symbol file could not be found. Defaulted to export symbols for dxva2.dll -
0b 00000000d3fae770 00007ff9
f1245c99 d3d9!Direct3DCreate9Ex+0x8c85
*** WARNING: Unable to verify checksum for SPDecSDK.dll
*** ERROR: Symbol file could not be found. Defaulted to export symbols for SPDecSDK.dll -
0c 00000000d3fae800 00000000
0a5da485 dxva2!DXVA2CreateDirect3DDeviceManager9+0x2de9
0d 00000000d3faefc0 00000000
0a5db8df SPDecSDK!av_vorbis_parse_reset+0x11d8a5
0e 00000000d3faf240 00000000
0a589782 SPDecSDK!av_vorbis_parse_reset+0x11ecff
0f 00000000d3faf290 00000000
0a4b6d6d SPDecSDK!av_vorbis_parse_reset+0xccba2
10 00000000d3faf2d0 00007ff9
e3269ba3 SPDecSDK!avcodec_decode_video2+0x1bd
11 00000000d3faf390 00007ff9
e32666bb AVDecSDK!CLS_DxvaHwDecoder::DecodeOneFrame(unsigned char * _pucFrameData = 0x00000000d4366058 "", int _iDataLen = 0n113045, struct DecOut * _ptDecOut = 0x00000000
15b30ae0)+0x113 [e:\01code\sdk22\trunk\avdecsdk\source\dxvadecoder\cls_dxvahwdecoder.cpp @ 118]
12 00000000d3faf4d0 00007ff9
e3254e5c AVDecSDK!CLS_AVDecoder::AVDecode(unsigned char * _pucFrameData = 0x00000000d4366058 "", int _iDataLen = 0n113045, struct DecOut * _ptDecOut = 0x00000000
15b30ae0)+0x14b [e:\01code\sdk22\trunk\avdecsdk\source\basedecoder\cls_avdecoder.cpp @ 138]
13 00000000d3faf520 00007ff9
e383d09e AVDecSDK!Decode(void * _pvHandle = 0x0000000000000006, unsigned char * _pucFrameData = 0x00000000
d4366058 “”, int _iDataLen = 0n113045, struct DecOut * _ptDecOut = 0x0000000015b30ae0)+0x11c [e:\01code\sdk22\trunk\avdecsdk\source\interface\avdecinterface.cpp @ 128] 14 00000000
d3faf570 00007ff9e3814600 PlaySdkM4!CLS_AVDecApi::AVDecDecode(int _iDecIdx = 0n6, void * _pvHandle = 0x00000000
00000006, unsigned char * _pucFrameData = 0x00000000d4366058 "", int _iDataLen = 0n113045, struct DecOut * _ptDecOut = 0x00000000
15b30ae0)+0x6e [e:\01code\sdk22\trunk\avplaysdk\avdecoder\avdecapi.cpp @ 276]
15 00000000d3faf5a0 00007ff9
e3838ca2 PlaySdkM4!CLS_Player::InnerDecAVFrame(struct DecOut * _pOut = 0x0000000015b30ae0, int _blClean = 0n0)+0x240 [e:\01code\sdk22\trunk\avplaysdk\avplayer\avplayer.cpp @ 4952] 16 00000000
d3faf5f0 00007ff9e381176b PlaySdkM4!CLS_DxvaHwPlayer::InnerDecode(int _bClean = 0n0)+0x112 [e:\01code\sdk22\trunk\avplaysdk\avplayer\windows\dxvahwplayer.cpp @ 200] 17 00000000
d3faf640 00007ff9e3811594 PlaySdkM4!CLS_Player::Inner_ACT_Play_StreamMode(void)+0x1bb [e:\01code\sdk22\trunk\avplaysdk\avplayer\avplayer.cpp @ 3779] 18 00000000
d3faf690 00007ff9e3810cea PlaySdkM4!CLS_Player::Inner_ACT_Play(void)+0xb4 [e:\01code\sdk22\trunk\avplaysdk\avplayer\avplayer.cpp @ 3736] 19 00000000
d3faf6c0 00007ff9e3808d97 PlaySdkM4!CLS_Player::PlayDirForward(void)+0x5a [e:\01code\sdk22\trunk\avplaysdk\avplayer\avplayer.cpp @ 3488] 1a 00000000
d3faf700 00007ffa1211a713 PlaySdkM4!CLS_Player::PlayThread(void * _pvParam = 0x00000000
15b228a0)+0x127 [e:\01code\sdk22\trunk\avplaysdk\avplayer\avplayer.cpp @ 268]
1b 00000000d3faf740 00007ffa
1c 00000000d3faf770 00007ffa
438554e0 OsCore!_threadstartex(void * ptd = 0x0000000000000000)+0x9f [f:\dd\vctools\crt_bld\self_64_amd64\crt\src\threadex.c @ 326] 1d 00000000
d3faf7a0 00007ffa44a2485b kernel32!BaseThreadInitThunk+0x10 1e 00000000
d3faf7d0 00000000`00000000 ntdll!RtlUserThreadStart+0x2b
40 Id: 27ac.1d88 Suspend: 1 Teb: 00000000`00f70000 Unfrozen
00 00000000d48ff968 00007ffa
01 00000000d48ff970 00007ffa
02 00000000d48ffa10 00007ffa
03 00000000d48ffa40 00007ffa
04 00000000d48ffa70 00000000
41 Id: 27ac.85f8 Suspend: 1 Teb: 00000000`00f72000 Unfrozen
00 00000000d4c0f818 00007ffa
01 00000000d4c0f820 00007ff9
d3efdc50 KERNELBASE!WaitForSingleObjectEx+0x8e
02 00000000d4c0f8c0 00007ff9
d3efe040 nvd3dumx!QueryOglResource+0x259fb0
03 00000000d4c0f8f0 00007ffa
438554e0 nvd3dumx!QueryOglResource+0x25a3a0
04 00000000d4c0f920 00007ffa
05 00000000d4c0f950 00000000
42 Id: 27ac.7c6c Suspend: 1 Teb: 00000000`00f74000 Unfrozen
00 00000000d4d0fb78 00007ffa
01 00000000d4d0fb80 00007ffa
02 00000000d4d0fbb0 00007ff9
03 00000000d4d0fc30 00007ff9
e3839f13 PlaySdkM4!os_usleep(int _iMicSec = 0n40000)+0x35 [e:\01code\sdk22\trunk\commoncode\common\global_common.cpp @ 205]
04 00000000d4d0fc60 00007ff9
e3811a84 PlaySdkM4!CLS_DxvaHwPlayer::Inner_ShowLastFrame(void)+0x13 [e:\01code\sdk22\trunk\avplaysdk\avplayer\windows\dxvahwplayer.cpp @ 543]
05 00000000d4d0fc90 00007ff9
e3811594 PlaySdkM4!CLS_Player::Inner_ACT_Play_StreamMode(void)+0x4d4 [e:\01code\sdk22\trunk\avplaysdk\avplayer\avplayer.cpp @ 3846]
06 00000000d4d0fce0 00007ff9
07 00000000d4d0fd10 00007ff9
08 00000000d4d0fd50 00007ffa
1211a713 PlaySdkM4!CLS_Player::PlayThread(void * _pvParam = 0x0000000077d58090)+0x127 [e:\01code\sdk22\trunk\avplaysdk\avplayer\avplayer.cpp @ 268] 09 00000000
d4d0fd90 00007ffa1211a7c7 OsCore!_callthreadstartex(void)+0x17 [f:\dd\vctools\crt_bld\self_64_amd64\crt\src\threadex.c @ 348] 0a 00000000
d4d0fdc0 00007ffa438554e0 OsCore!_threadstartex(void * ptd = 0x00000000
0b 00000000d4d0fdf0 00007ffa
0c 00000000d4d0fe20 00000000
43 Id: 27ac.6e5c Suspend: 1 Teb: 00000000`00f76000 Unfrozen
00 00000000d73bfe38 00007ffa
01 00000000d73bfe40 00007ffa
02 00000000d73bfee0 00007ffa
03 00000000d73bff10 00007ffa
04 00000000d73bff40 00000000
44 Id: 27ac.86dc Suspend: 1 Teb: 00000000`00f78000 Unfrozen
00 00000000d76cf6c8 00007ffa
01 00000000d76cf6d0 00007ff9
02 00000000d76cf770 00007ff9
03 00000000d76cf7a0 00007ffa
04 00000000d76cf7d0 00007ffa
05 00000000d76cf800 00000000
45 Id: 27ac.69c4 Suspend: 1 Teb: 00000000`00f7a000 Unfrozen
00 00000000d77cfc78 00007ffa
01 00000000d77cfc80 00007ffa
02 00000000d77cfcb0 00007ff9
03 00000000d77cfd30 00007ff9
04 00000000d77cfd60 00007ff9
05 00000000d77cfd90 00007ff9
06 00000000d77cfde0 00007ff9
07 00000000d77cfe10 00007ff9
08 00000000d77cfe50 00007ffa
1211a713 PlaySdkM4!CLS_Player::PlayThread(void * _pvParam = 0x0000000077d78240)+0x127 [e:\01code\sdk22\trunk\avplaysdk\avplayer\avplayer.cpp @ 268] 09 00000000
d77cfe90 00007ffa1211a7c7 OsCore!_callthreadstartex(void)+0x17 [f:\dd\vctools\crt_bld\self_64_amd64\crt\src\threadex.c @ 348] 0a 00000000
d77cfec0 00007ffa438554e0 OsCore!_threadstartex(void * ptd = 0x00000000
0b 00000000d77cfef0 00007ffa
0c 00000000d77cff20 00000000
46 Id: 27ac.7d14 Suspend: 1 Teb: 00000000`00f7c000 Unfrozen
00 00000000d7a5f678 00007ffa
01 00000000d7a5f680 00007ffa
02 00000000d7a5f720 00007ffa
03 00000000d7a5f750 00007ffa
04 00000000d7a5f780 00000000
47 Id: 27ac.6dc0 Suspend: 1 Teb: 00000000`00f7e000 Unfrozen
00 00000000da08fe08 00007ffa
01 00000000da08fe10 00007ff9
02 00000000da08feb0 00007ff9
03 00000000da08fee0 00007ffa
04 00000000da08ff10 00007ffa
05 00000000da08ff40 00000000
48 Id: 27ac.77dc Suspend: 1 Teb: 00000000`00f80000 Unfrozen
00 00000000da18fb08 00007ffa
01 00000000da18fb10 00007ffa
02 00000000da18fb40 00007ff9
03 00000000da18fbc0 00007ff9
04 00000000da18fbf0 00007ff9
05 00000000da18fc20 00007ff9
06 00000000da18fc70 00007ff9
07 00000000da18fca0 00007ff9
08 00000000da18fce0 00007ffa
1211a713 PlaySdkM4!CLS_Player::PlayThread(void * _pvParam = 0x00000000780cc010)+0x127 [e:\01code\sdk22\trunk\avplaysdk\avplayer\avplayer.cpp @ 268] 09 00000000
da18fd20 00007ffa1211a7c7 OsCore!_callthreadstartex(void)+0x17 [f:\dd\vctools\crt_bld\self_64_amd64\crt\src\threadex.c @ 348] 0a 00000000
da18fd50 00007ffa438554e0 OsCore!_threadstartex(void * ptd = 0x00000000
0b 00000000da18fd80 00007ffa
0c 00000000da18fdb0 00000000
49 Id: 27ac.71e4 Suspend: 1 Teb: 00000000`00f8c000 Unfrozen
00 0000000000d6f5e8 00007ffa
01 0000000000d6f5f0 00007ffa
02 0000000000d6f8e0 00007ff9
d3db821b KERNELBASE!WaitForMultipleObjects+0xe
03 0000000000d6f920 00007ff9
d3c0149d nvd3dumx!QueryOglResource+0x11457b
04 0000000000d6f9f0 00007ff9
d3fce458 nvd3dumx+0xa5149d
05 0000000000d6fa20 00007ffa
438554e0 nvd3dumx!QueryOglResource+0x32a7b8
06 0000000000d6fa50 00007ffa
07 0000000000d6fa80 00000000
50 Id: 27ac.4e08 Suspend: 1 Teb: 00000000`00f8e000 Unfrozen
00 0000000000d7f5c8 00007ffa
01 0000000000d7f5d0 00007ffa
02 0000000000d7f8c0 00007ff9
03 0000000000d7f900 00007ff9
04 0000000000d7f9d0 00007ff9
05 0000000000d7fa00 00007ffa
06 0000000000d7fa30 00007ffa
07 0000000000d7fa60 00000000
51 Id: 27ac.5838 Suspend: 1 Teb: 00000000`00f90000 Unfrozen
00 0000000000d8f708 00007ffa
01 0000000000d8f710 00007ffa
02 0000000000d8fa00 00007ff9
03 0000000000d8fa40 00007ff9
04 0000000000d8fb10 00007ff9
05 0000000000d8fb40 00007ffa
06 0000000000d8fb70 00007ffa
07 0000000000d8fba0 00000000
52 Id: 27ac.6ecc Suspend: 1 Teb: 00000000`00fba000 Unfrozen
00 000000000010f658 00007ffa
01 000000000010f660 00007ffa
02 000000000010f950 00007ffa
03 000000000010f980 00000000
53 Id: 27ac.83a8 Suspend: 1 Teb: 00000000`00fbc000 Unfrozen
00 000000000020f7d8 00007ffa
44af830e ntdll!DbgBreakPoint
01 000000000020f7e0 00007ffa
438554e0 ntdll!DbgUiRemoteBreakin+0x4e
02 000000000020f810 00007ffa
03 000000000020f840 00000000
0:053> lmvm nvd3dumx
start end module name
00007ff9d31b0000 00007ff9
d4943000 nvd3dumx (export symbols) nvd3dumx.dll
Loaded symbol image file: nvd3dumx.dll
CheckSum: 017E6806
ImageSize: 01793000
