GeForce Driver Bug on DX11, causing flickering and other problems
I’ve reported this problem few years ago, when you still had another website:
And I’m disappointed that the problem still hasn’t been fixed.
There’s a problem on the GeForce on DX11, causing flickering and other issues.
I’m attaching the app for you to test:
If you run on GeForce 650m GT you will see significant flickering.
If you run on any non GeForce GPU (Intel or ATI) you will see it’s working fine.
If I slightly modify the shader, to move the “Color[0]” constant to the Vertex Shader, then the problem goes away.
Expected results:
External Media
What I’m getting:
External Media
External Media
External Media
Application code:
#include "stdafx.h"
void InitPre()
   App.name("Project");
   App.flag=APP_MINIMIZABLE|APP_WORK_IN_BACKGROUND;
   Paks.add("Engine.pak");
   D.mode(800, 600);
Bool Init()
   return true;
void Shut()
bool Update()
   if(Kb.bp(KB_ESC))return false;
   return true;
void Draw()
   D.clear(TURQ); // clear screen to turquoise color
   const int steps=17; // number of rectangles to draw
   float width=D.w()*2/steps, height=D.h()*2/steps; // size of a single rectangle
   ImageRTPtr render_target; render_target.get(D.resW(), D.resH(), IMAGERT_RGBA); // get a helper render target
   // iterate X and Y rectangles
   REPD(y, steps)
   REPD(x, steps)
      Renderer.set(render_target(), null, false); // start rendering to helper render target
      Rect_LU rectangle(-D.w() + x*width, D.h() - y*height, width*0.9, height*0.9); // calculate rectangle
      D.alpha(ALPHA_NONE); // disable alpha blending
      Sh.clear(Vec4Zero, &rectangle); // force (0,0,0,0) color at rectangle
      D.alpha(ALPHA_ADD); // enable additive alpha blending (destination_rt.rgba+=color.rgba)
      Sh.clear(ColorHSB(float(x)/steps, float(y)/steps, 1).asVec4(), &rectangle); // draw HueSaturationBrightness color at the same rectangle
      Renderer.set(&Renderer._main, null, false); // activate main render target
      Sh.draw(*render_target, &rectangle); // draw render_target image onto the main render target at specified rectangle
Shaders:
THIS SHADER WORKS OK, NO FLICKERING:
void SetCol_VS(VtxInput vtx,
           out Vec4 outCol:COLOR   ,
           out Vec4 outVtx:POSITION)
   outCol=Color[0];
   outVtx=Vec4(vtx.pos2(), 0, 1);
Vec4 SetCol_PS(Vec4 inCol:COLOR):COLOR
   return inCol;
TECHNIQUE(SetCol, SetCol_VS(), SetCol_PS());
THIS SHADER CAUSES FLICKERING:
Vec4 SetCol_PS():COLOR
   return Color[0];
THE ONLY DIFFERENCE IS THAT THE Color[0] constant was moved from VS to PS
This is causing significant problems in the engine and the game that I’m developing.
Thank you for your help.
Bump.
This works OK on Intel/ATI, but not on GeForce.
I tested your DX11 code on my Geforce GTX 1050 (driver 388.59) and it works ok. No flickering.
Thanks for the reply.
I’ve tested on a friend’s laptop with 1050m and works fine too.
However on 650m GT I’m having flickering, updated drivers today (390.77).
I remember that when I submitted the problem to the older Nvidia website, I’ve got confirmation from Nvidia employee that they were able to reproduce the problem on their machine as well. Perhaps they’ve used 650m like me.
DxDiag:
[code]------------------
System Information
  Time of this report: 3/7/2018, 14:51:18
         Machine name: WIN
           Machine Id: {9544597F-9367-4F61-96CE-A8E294844564}
     Operating System: Windows 10 Pro 64-bit (10.0, Build 16299) (16299.rs3_release.170928-1534)
             Language: English (Regional Setting: English)
  System Manufacturer: ASUSTeK COMPUTER INC.
         System Model: UX51VZA
                 BIOS: UX51VZA.204
            Processor: Intel(R) Core(TM) i7-3632QM CPU @ 2.20GHz (8 CPUs), ~2.2GHz
               Memory: 8192MB RAM
  Available OS Memory: 8078MB RAM
            Page File: 5625MB used, 3731MB available
          Windows Dir: C:\WINDOWS
      DirectX Version: DirectX 12
  DX Setup Parameters: Not found
     User DPI Setting: 144 DPI (150 percent)
   System DPI Setting: 120 DPI (125 percent)
      DWM DPI Scaling: Disabled
             Miracast: Available, with HDCP
Microsoft Graphics Hybrid: Supported
DxDiag Version: 10.00.16299.0015 64bit Unicode
DxDiag Notes
  Display Tab 1: No problems found.
  Display Tab 2: No problems found.
    Sound Tab 1: No problems found.
      Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
       Card name: Intel(R) HD Graphics 4000
    Manufacturer: Intel Corporation
       Chip type: Intel(R) HD Graphics Family
        DAC type: Internal
     Device Type: Full Device
      Device Key: Enum\PCI\VEN_8086&DEV_0166&SUBSYS_15A71043&REV_09
   Device Status: 0180200A [DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]
Device Problem Code: No Problem
Driver Problem Code: Unknown
Display Memory: 1792 MB
Dedicated Memory: 32 MB
Shared Memory: 1760 MB
Current Mode: 1920 x 1080 (32 bit) (60Hz)
HDR Support: Not Supported
Display Topology: Internal
Display Color Space: DXGI_COLOR_SPACE_RGB_FULL_G22_NONE_P709
Color Primaries: Red(0.629406,0.350109), Green(0.349133,0.614758), Blue(0.154797,0.112805), White Point(0.313977,0.329602)
Display Luminance: Min Luminance = 0.500000, Max Luminance = 270.000000, MaxFullFrameLuminance = 270.000000
Monitor Name: Generic PnP Monitor
Monitor Model: unknown
Monitor Id: LGD0323
Native Mode: 1920 x 1080(p) (59.975Hz)
Output Type: Internal
Monitor Advanced Color Capabilities: None
Display Pixel Format: DISPLAYCONFIG_PIXELFORMAT_32BPP
Driver Name: igdumdim64.dll,igd10iumd64.dll,igd10iumd64.dll
Driver File Version: 10.18.0010.4653 (English)
Driver Version: 10.18.10.4653
DDI Version: 11.2
Feature Levels: 11_0,10_1,10_0,9_3,9_2,9_1
Driver Model: WDDM 1.3
Graphics Preemption: DMA
Compute Preemption: Thread group
Miracast: Supported
Hybrid Graphics GPU: Integrated
Power P-states: Not Supported
Driver Attributes: Final Retail
Driver Date/Size: 07-Apr-17 13:00:00, 11158160 bytes
WHQL Logo’d: n/a
WHQL Date Stamp: n/a
Device Identifier: {D7B78E66-4226-11CF-DE61-AD35B4C2C735}
Vendor ID: 0x8086
Device ID: 0x0166
SubSys ID: 0x15A71043
Revision ID: 0x0009
Driver Strong Name: oem65.inf:5f63e5341859ec8c:iIVBM_w10:10.18.10.4653:pci\ven_8086&dev_0166
Rank Of Driver: 00D12001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_C ModeVC1_C
DXVA2 Modes: DXVA2_ModeMPEG2_VLD DXVA2_ModeMPEG2_IDCT DXVA2_ModeVC1_D2010 DXVA2_ModeWMV9_IDCT DXVA2_ModeVC1_IDCT DXVA2_ModeH264_VLD_NoFGT
Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
D3D9 Overlay: Supported
DXVA-HD: Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
MPO MaxPlanes: 1
MPO Caps: Not Supported
MPO Stretch: Not Supported
MPO Media Hints: Not Supported
MPO Formats: Not Supported
PanelFitter Caps: Not Supported
PanelFitter Stretch: Not Supported
       Card name: NVIDIA GeForce GT 650M
    Manufacturer: NVIDIA
       Chip type: GeForce GT 650M
        DAC type: Integrated RAMDAC
      Device Key: Enum\PCI\VEN_10DE&DEV_0FD1&SUBSYS_15A71043&REV_A1
Display Memory: 6046 MB
Dedicated Memory: 2007 MB
Shared Memory: 4038 MB
Current Mode: Unknown
HDR Support: Unknown
Display Topology: Unknown
Display Color Space: Unknown
Color Primaries: Unknown
Display Luminance: Unknown
Driver Name: C:\WINDOWS\System32\DriverStore\FileRepository\nvami.inf_amd64_80865528b013df3a\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nvami.inf_amd64_80865528b013df3a\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nvami.inf_amd64_80865528b013df3a\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nvami.inf_amd64_80865528b013df3a\nvldumdx.dll
Driver File Version: 23.21.0013.9077 (English)
Driver Version: 23.21.13.9077
DDI Version: 12
Driver Model: WDDM 2.3
Compute Preemption: DMA
Miracast: Not Supported by Graphics driver
Hybrid Graphics GPU: Discrete
Driver Date/Size: 23-Jan-18 13:00:00, 931584 bytes
WHQL Logo’d: n/a
Device Identifier: Unknown
Vendor ID: 0x10DE
Device ID: 0x0FD1
Revision ID: 0x00A1
Driver Strong Name: oem72.inf:0f066de368ef4c06:Section050:23.21.13.9077:pci\ven_10de&dev_0fd1&subsys_15a71043
Rank Of Driver: 00D10001
Video Accel: Unknown
DXVA2 Modes: DXVA2_ModeMPEG2_VLD DXVA2_ModeVC1_D2010 DXVA2_ModeVC1_VLD DXVA2_ModeH264_VLD_Stereo_Progressive_NoFGT DXVA2_ModeH264_VLD_Stereo_NoFGT DXVA2_ModeH264_VLD_NoFGT DXVA2_ModeHEVC_VLD_Main DXVA2_ModeMPEG4pt2_VLD_Simple DXVA2_ModeMPEG4pt2_VLD_AdvSimple_NoGMC
Deinterlace Caps: n/a
D3D9 Overlay: Unknown
DXVA-HD: Unknown
D3D Status: Enabled
AGP Status: Enabled
MPO MaxPlanes: 0
Sound Devices
        Description: Speakers (Realtek High Definition Audio)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0663&SUBSYS_104315A7&REV_1000
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: RTKVHD64.sys
Driver Version: 6.00.0001.7535 (English)
WHQL Logo’d: n/a
Date and Size: 16-Jun-15 00:00:00, 4504320 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
HW Accel Level: Basic
Cap Flags: 0x0
Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX™ 2.0 Listen/Src: No, No
I3DL2™ Listen/Src: No, No
Sensaura™ ZoomFX™: No
Sound Capture Devices
        Description: Microphone (Realtek High Definition Audio)
Default Sound Capture: Yes
Default Voice Capture: Yes
Date and Size: 6/24/2015 23:57:00, 4504320 bytes
Cap Flags: 0x0
Format Flags: 0x0
Video Capture Devices
Number of Devices: 1
       FriendlyName: USB2.0 HD UVC WebCam
       SymbolicLink: \\?\usb#vid_04f2&pid_b36e&mi_00#7&2e7fcb2d&5&0000#{e5323777-f976-4f5b-9b55-b94699c46e44}\global
       Manufacturer: Microsoft
         HardwareID: USB\VID_04F2&PID_B36E&REV_2943&MI_00,USB\VID_04F2&PID_B36E&MI_00
         DriverDesc: USB Video Device
     DriverProvider: Microsoft
      DriverVersion: 10.0.16299.15
  DriverDateEnglish: 6/21/2006 00:00:00
DriverDateLocalized: 21-Jun-06 00:00:00
            Service: usbvideo
              Class: Camera
      DevNodeStatus: 180200A[DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]
        ContainerId: {00000000-0000-0000-FFFF-FFFFFFFFFFFF}
        ProblemCode: No Problem
BusReportedDeviceDesc: USB2.0 HD UVC WebCam
Parent: USB\VID_04F2&PID_B36E\200901010001
DriverProblemDesc: n/a
UpperFilters: n/a
LowerFilters: n/a
Stack: \Driver\ksthunk,\Driver\usbvideo,\Driver\ACPI,\Driver\usbccgp
ContainerCategory: n/a
DirectInput Devices
  Device Name: Mouse
     Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
  Device Name: Keyboard
     Attached: 1
Controller ID: n/a
FF Driver: n/a
  Device Name: eGalaxTouch EXC7903-18v01_Test5
     Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x0EEF, 0x7910
FF Driver: n/a
  Device Name: SteelSeries Rival 500
     Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x1038, 0x170E
FF Driver: n/a
     Attached: 1
Controller ID: 0x0
FF Driver: n/a
  Device Name: SteelSeries Rival 500 Gaming Mouse
     Attached: 1
Controller ID: 0x0
FF Driver: n/a
  Device Name: ASUS Wireless Radio Control
     Attached: 1
Controller ID: 0x0
FF Driver: n/a
  Device Name: USB Keyboard
     Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x046D, 0xC326
FF Driver: n/a
     Attached: 1
Controller ID: 0x0
FF Driver: n/a
     Attached: 1
Controller ID: 0x0
FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
  • USB Root Hub (USB 3.0)
    | Vendor/Product ID: 0x8086, 0x1E31
    | Matching Device ID: USB\ROOT_HUB30
    | Service: USBHUB3
    | Driver: USBHUB3.SYS, 10/25/2017 17:30:40, 555416 bytes
    ±+ USB Composite Device
    | | Matching Device ID: USB\COMPOSITE
    | | Service: usbccgp
    | | Driver: usbccgp.sys, 9/30/2017 02:41:08, 168856 bytes
    | ±+ SteelSeries Rival 500
    | | | Matching Device ID: USB\VID_1038&PID_170E&MI_01
    | | | Lower Filters: sshid
    | | | Service: mshidkmdf
    | | | Driver: sshid.sys, 10/11/2017 07:47:42, 45928 bytes
    | | ±+ HID-compliant mouse
    | | | | Matching Device ID: HID_DEVICE_SYSTEM_MOUSE
    | | | | Service: mouhid
    | | | | Driver: mouhid.sys, 9/30/2017 02:41:08, 32768 bytes
    | | | | Driver: mouclass.sys, 9/30/2017 02:41:08, 57240 bytes
    | | ±+ HID Keyboard Device
    | | | | Matching Device ID: HID_DEVICE_SYSTEM_KEYBOARD
    | | | | Service: kbdhid
    | | | | Driver: kbdhid.sys, 9/30/2017 02:41:08, 40448 bytes
    | | | | Driver: kbdclass.sys, 9/30/2017 02:41:08, 63384 bytes
    | ±+ USB Input Device
    | | | Matching Device ID: USB\Class_03
    | | | Service: HidUsb
    | | | Driver: hidusb.sys, 9/30/2017 02:41:08, 40960 bytes
    | | | Driver: hidclass.sys, 9/30/2017 02:41:08, 187392 bytes
    | | | Driver: hidparse.sys, 2/10/2018 17:47:33, 46080 bytes
    | | | | Service: kbdhid
    | | Service: usbccgp
    | ±+ USB Input Device
    | | | Matching Device ID: USB\Class_03&SubClass_01
    | | | Service: HidUsb
    | | | | Service: kbdhid
Gameport Devices
PS/2 Devices
  • Keyboard Device Filter
    | Matching Device ID: *ATK3001
    | Upper Filters: kbfiltr
    | Service: i8042prt
    | Driver: kbfiltr.sys, 8/2/2012 16:22:48, 14992 bytes
    | Driver: i8042prt.sys, 9/30/2017 02:41:08, 105984 bytes
  • ASUS Touchpad
    | Matching Device ID: ACPI\ETD0105
    | Upper Filters: AsusTP
    | Service: i8042prt
    | Driver: AsusTP.sys, 3/9/2017 11:18:58, 128024 bytes
Disk & DVD/CD-ROM Drives
  Drive: C:
Free Space: 6.5 GB
Total Space: 188.1 GB
File System: NTFS
Model: Intel Raid 0 Volume
  Drive: D:
Free Space: 10.7 GB
Total Space: 260.8 GB
File System: NTFS
System Devices
 Name: Intel(R) 7 Series/C216 Chipset Family PCI Express Root Port 2 - 1E12
Device ID: PCI\VEN_8086&DEV_1E12&SUBSYS_15A71043&REV_C4\3&11583659&0&E1
Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 10.00.16299.0248 (English), 2/10/2018 19:06:11, 362904 bytes
 Name: Xeon(R) processor E3-1200 v2/3rd Gen Core processor PCI Express Root Port - 0151
Device ID: PCI\VEN_8086&DEV_0151&SUBSYS_15A71043&REV_09\3&11583659&0&08
 Name: This Qualcomm Atheros network Controller connects you to the network.
Device ID: PCI\VEN_1969&DEV_1083&SUBSYS_15A71043&REV_C0\4&D5DB309&0&00E3
Driver: C:\WINDOWS\system32\DRIVERS\L1C63x64.sys, 2.01.0000.0016 (English), 9/30/2017 02:41:02, 121344 bytes
 Name: NVIDIA GeForce GT 650M
Device ID: PCI\VEN_10DE&DEV_0FD1&SUBSYS_15A71043&REV_A1\4&1B5D39FA&0&0008
Driver: C:\WINDOWS\system32\DRIVERS\NVIDIA Corporation\Drs\dbInstaller.exe, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 464880 bytes
Driver: C:\WINDOWS\system32\DRIVERS\NVIDIA Corporation\Drs\nvdrsdb.bin, 1/24/2018 13:23:45, 1473020 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvami.inf_amd64_80865528b013df3a\NvContainerSetup.exe, 1.00.0007.0000 (English), 1/24/2018 13:23:45, 4181928 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvami.inf_amd64_80865528b013df3a\NvCplSetupInt.exe, 1.00.0007.0000 (English), 1/24/2018 13:23:45, 101308928 bytes
Driver: C:\Program Files (x86)\NVIDIA Corporation\coprocmanager\detoured.dll, 2.01.0000.0224 (English), 1/24/2018 13:23:45, 19952 bytes
Driver: C:\Program Files (x86)\NVIDIA Corporation\coprocmanager\nvd3d9wrap.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 219800 bytes
Driver: C:\Program Files (x86)\NVIDIA Corporation\coprocmanager\nvdxgiwrap.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 144592 bytes
Driver: C:\Program Files\NVIDIA Corporation\coprocmanager\detoured.dll, 2.01.0000.0224 (English), 1/24/2018 13:23:45, 19760 bytes
Driver: C:\Program Files\NVIDIA Corporation\coprocmanager\nvd3d9wrapx.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 262536 bytes
Driver: C:\Program Files\NVIDIA Corporation\coprocmanager\nvdxgiwrapx.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 171712 bytes
Driver: C:\Program Files\NVIDIA Corporation\license.txt, 8/22/2017 14:01:55, 27203 bytes
Driver: C:\Program Files\NVIDIA Corporation\NVSMI\MCU.exe, 1.01.5204.20580 (English), 1/24/2018 13:23:45, 849392 bytes
Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvdebugdump.exe, 6.14.0013.9077 (English), 1/24/2018 13:23:45, 419312 bytes
Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvidia-smi.1.pdf, 1/24/2018 13:23:45, 78094 bytes
Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvidia-smi.exe, 8.17.0013.9077 (English), 1/24/2018 13:23:45, 509936 bytes
Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvml.dll, 8.17.0013.9077 (English), 1/24/2018 13:23:45, 918088 bytes
Driver: C:\Program Files\NVIDIA Corporation\OpenCL\OpenCL.dll, 2.00.0004.0000 (English), 1/24/2018 13:23:45, 438768 bytes
Driver: C:\Program Files\NVIDIA Corporation\OpenCL\OpenCL64.dll, 2.00.0004.0000 (English), 1/24/2018 13:23:45, 532040 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvami.inf_amd64_80865528b013df3a\nvlddmkm.sys, 23.21.0013.9077 (English), 1/25/2018 10:41:38, 17493824 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvami.inf_amd64_80865528b013df3a\nvpciflt.sys, 23.21.0013.9077 (English), 1/25/2018 10:42:14, 48072 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvami.inf_amd64_80865528b013df3a\nv-vk64.json, 1/24/2018 13:23:45, 669 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvami.inf_amd64_80865528b013df3a\nvd3dumx.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 18969472 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvami.inf_amd64_80865528b013df3a\nvd3dumx_cfg.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 19358800 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvami.inf_amd64_80865528b013df3a\nvinitx.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 197992 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvami.inf_amd64_80865528b013df3a\nvldumdx.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 931584 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvami.inf_amd64_80865528b013df3a\nvoglshim64.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 173432 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvami.inf_amd64_80865528b013df3a\nvoglv64.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 35404592 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvami.inf_amd64_80865528b013df3a\nvumdshimx.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 577056 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvami.inf_amd64_80865528b013df3a\nvwgf2umx.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 28909824 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvami.inf_amd64_80865528b013df3a\nvwgf2umx_cfg.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 29740528 bytes
Driver: C:\WINDOWS\system32\NvFBC64.dll, 6.14.0013.9077 (English), 1/24/2018 13:23:45, 1126888 bytes
Driver: C:\WINDOWS\system32\NvIFR64.dll, 6.14.0013.9077 (English), 1/24/2018 13:23:45, 988464 bytes
Driver: C:\WINDOWS\system32\NvIFROpenGL.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 616240 bytes
Driver: C:\WINDOWS\system32\nvEncMFTH264.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 1325384 bytes
Driver: C:\WINDOWS\system32\nvEncodeAPI64.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 795928 bytes
Driver: C:\WINDOWS\system32\nvapi64.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 4580832 bytes
Driver: C:\WINDOWS\system32\nvcompiler.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 40269808 bytes
Driver: C:\WINDOWS\system32\nvcuda.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 12843496 bytes
Driver: C:\WINDOWS\system32\nvcuvid.dll, 7.17.0013.9077 (English), 1/24/2018 13:23:45, 4308976 bytes
Driver: C:\WINDOWS\system32\nvfatbinaryLoader.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 1134768 bytes
Driver: C:\WINDOWS\system32\nvinfo.pb, 1/24/2018 13:23:45, 48407 bytes
Driver: C:\WINDOWS\system32\nvopencl.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 19796336 bytes
Driver: C:\WINDOWS\system32\nvptxJitCompiler.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 13444552 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvami.inf_amd64_80865528b013df3a\nv-vk32.json, 1/24/2018 13:23:45, 669 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvami.inf_amd64_80865528b013df3a\nvd3dum.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 15591424 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvami.inf_amd64_80865528b013df3a\nvd3dum_cfg.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 15912784 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvami.inf_amd64_80865528b013df3a\nvinit.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 171896 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvami.inf_amd64_80865528b013df3a\nvldumd.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 774304 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvami.inf_amd64_80865528b013df3a\nvoglshim32.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 145616 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvami.inf_amd64_80865528b013df3a\nvoglv32.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 27975152 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvami.inf_amd64_80865528b013df3a\nvumdshim.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 495352 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvami.inf_amd64_80865528b013df3a\nvwgf2um.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 24473608 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvami.inf_amd64_80865528b013df3a\nvwgf2um_cfg.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 25371952 bytes
Driver: C:\WINDOWS\SysWow64\NvFBC.dll, 6.14.0013.9077 (English), 1/24/2018 13:23:45, 1054704 bytes
Driver: C:\WINDOWS\SysWow64\NvIFR.dll, 6.14.0013.9077 (English), 1/24/2018 13:23:45, 939832 bytes
Driver: C:\WINDOWS\SysWow64\NvIFROpenGL.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 506864 bytes
Driver: C:\WINDOWS\SysWow64\nvEncMFTH264.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 1043128 bytes
Driver: C:\WINDOWS\SysWow64\nvEncodeAPI.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 635248 bytes
Driver: C:\WINDOWS\SysWow64\nvapi.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 3894304 bytes
Driver: C:\WINDOWS\SysWow64\nvcompiler.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 35180016 bytes
Driver: C:\WINDOWS\SysWow64\nvcuda.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 10900248 bytes
Driver: C:\WINDOWS\SysWow64\nvcuvid.dll, 7.17.0013.9077 (English), 1/24/2018 13:23:45, 3709424 bytes
Driver: C:\WINDOWS\SysWow64\nvfatbinaryLoader.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 885680 bytes
Driver: C:\WINDOWS\SysWow64\nvopencl.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 16449872 bytes
Driver: C:\WINDOWS\SysWow64\nvptxJitCompiler.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 11026080 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvami.inf_amd64_80865528b013df3a\VulkanRT-Installer.exe, 1.00.0065.0000 (English), 1/24/2018 13:23:45, 979288 bytes
Driver: C:\WINDOWS\system32\nvdispco6439077.dll, 2.00.0049.0004 (English), 1/24/2018 13:23:45, 1976120 bytes
Driver: C:\WINDOWS\system32\nvdispgenco6439077.dll, 2.00.0026.0002 (English), 1/24/2018 13:23:45, 1673616 bytes
 Name: 3rd Gen Core processor DRAM Controller - 0154
Device ID: PCI\VEN_8086&DEV_0154&SUBSYS_15A71043&REV_09\3&11583659&0&00
Driver: n/a
 Name: Intel(R) 7 Series/C216 Chipset Family SMBus Host Controller - 1E22
Device ID: PCI\VEN_8086&DEV_1E22&SUBSYS_15A71043&REV_04\3&11583659&0&FB
Driver: n/a
 Name: Intel(R) Centrino(R) Advanced-N 6235
Device ID: PCI\VEN_8086&DEV_088E&SUBSYS_40608086&REV_24\4&20A32E22&0&00E1
Driver: C:\WINDOWS\system32\DRIVERS\NETwew01.sys, 15.18.0000.0001 (English), 5/4/2015 16:54:36, 3354384 bytes
Driver: C:\WINDOWS\system32\DRIVERS\Netwfw01.dat, 5/4/2015 16:53:00, 8108584 bytes
 Name: Intel(R) 7 Series/C216 Chipset Family PCI Express Root Port 1 - 1E10
Device ID: PCI\VEN_8086&DEV_1E10&SUBSYS_15A71043&REV_C4\3&11583659&0&E0
 Name: Intel Chipset SATA RAID Controller
Device ID: PCI\VEN_8086&DEV_282A&SUBSYS_15A71043&REV_04\3&11583659&0&FA
Driver: C:\WINDOWS\system32\DRIVERS\iaStorA.sys, 15.02.0000.1020 (English), 9/20/2016 11:04:30, 795640 bytes
 Name: Intel(R) Management Engine Interface
Device ID: PCI\VEN_8086&DEV_1E3A&SUBSYS_15A71043&REV_04\3&11583659&0&B0
Driver: C:\WINDOWS\system32\DRIVERS\HECIx64.sys, 8.01.0000.1263 (English), 7/3/2012 12:16:02, 62784 bytes
 Name: Intel(R) USB 3.0 eXtensible Host Controller - 1.0 (Microsoft)
Device ID: PCI\VEN_8086&DEV_1E31&SUBSYS_15A71043&REV_04\3&11583659&0&A0
Driver: C:\WINDOWS\system32\DRIVERS\USBXHCI.SYS, 10.00.16299.0125 (English), 12/8/2017 12:24:06, 437144 bytes
 Name: Intel(R) HD Graphics 4000
Device ID: PCI\VEN_8086&DEV_0166&SUBSYS_15A71043&REV_09\3&11583659&0&10
Driver: C:\WINDOWS\system32\DRIVERS\igdkmd64.sys, 10.18.0010.4653 (English), 5/18/2017 15:11:34, 3811816 bytes
Driver: C:\WINDOWS\system32\igd10iumd64.dll, 10.18.0010.4653 (English), 5/18/2017 15:11:32, 12442968 bytes
Driver: C:\WINDOWS\system32\igdusc64.dll, 10.18.0010.4653 (English), 5/18/2017 15:11:36, 4710224 bytes
Driver: C:\WINDOWS\system32\igdmd64.dll, 10.18.0010.4653 (English), 5/18/2017 15:11:34, 480584 bytes
Driver: C:\WINDOWS\system32\igfxcmrt64.dll, 3.00.0000.1284 (English), 5/18/2017 15:11:36, 209640 bytes
Driver: C:\WINDOWS\system32\igfx11cmrt64.dll, 3.00.0000.1284 (English), 5/18/2017 15:11:36, 202240 bytes
Driver: C:\WINDOWS\system32\igfxcmjit64.dll, 3.00.0000.1284 (English), 5/18/2017 15:11:36, 2044416 bytes
Driver: C:\WINDOWS\system32\IccLibDll_x64.dll, 5/18/2017 15:11:32, 111616 bytes
Driver: C:\WINDOWS\system32\igdde64.dll, 5/18/2017 15:11:34, 238592 bytes
Driver: C:\WINDOWS\SysWow64\igdde32.dll, 5/18/2017 15:11:34, 200192 bytes
Driver: C:\WINDOWS\system32\iglhxs64.vp, 5/18/2017 15:11:36, 2582 bytes
Driver: C:\WINDOWS\system32\iglhxo64.vp, 5/18/2017 15:11:36, 44025 bytes
Driver: C:\WINDOWS\system32\iglhxc64.vp, 5/18/2017 15:11:36, 43494 bytes
Driver: C:\WINDOWS\system32\iglhxg64.vp, 5/18/2017 15:11:36, 43256 bytes
Driver: C:\WINDOWS\system32\iglhxo64_dev.vp, 5/18/2017 15:11:36, 42079 bytes
Driver: C:\WINDOWS\system32\iglhxc64_dev.vp, 5/18/2017 15:11:36, 43816 bytes
Driver: C:\WINDOWS\system32\iglhxg64_dev.vp, 5/18/2017 15:11:36, 43298 bytes
Driver: C:\WINDOWS\system32\iglhxa64.vp, 5/18/2017 15:11:36, 1125 bytes
Driver: C:\WINDOWS\system32\iglhxa64.cpa, 5/18/2017 15:11:36, 2813952 bytes
Driver: C:\WINDOWS\system32\iglhcp64.dll, 9.00.0020.9000 (English), 5/18/2017 15:11:36, 240424 bytes
Driver: C:\WINDOWS\system32\iglhsip64.dll, 9.00.0020.9000 (English), 5/18/2017 15:11:36, 1174824 bytes
Driver: C:\WINDOWS\SysWow64\igdusc32.dll, 10.18.0010.4653 (English), 5/18/2017 15:11:36, 3733488 bytes
Driver: C:\WINDOWS\SysWow64\igdmd32.dll, 10.18.0010.4653 (English), 5/18/2017 15:11:34, 390920 bytes
Driver: C:\WINDOWS\SysWow64\igd10iumd32.dll, 10.18.0010.4653 (English), 5/18/2017 15:11:32, 12007928 bytes
Driver: C:\WINDOWS\SysWow64\igdumdim32.dll, 10.18.0010.4653 (English), 5/18/2017 15:11:36, 10676400 bytes
Driver: C:\WINDOWS\SysWow64\igdail32.dll, 5/18/2017 15:11:32, 161280 bytes
Driver: C:\WINDOWS\SysWow64\iglhcp32.dll, 9.00.0020.9000 (English), 5/18/2017 15:11:36, 204840 bytes
Driver: C:\WINDOWS\SysWow64\iglhsip32.dll, 9.00.0020.9000 (English), 5/18/2017 15:11:36, 1170632 bytes
Driver: C:\WINDOWS\SysWow64\IntelCpHeciSvc.exe, 9.00.0020.9000 (English), 5/18/2017 15:17:36, 280696 bytes
Driver: C:\WINDOWS\SysWow64\igfxcmrt32.dll, 3.00.0000.1284 (English), 5/18/2017 15:11:36, 179592 bytes
Driver: C:\WINDOWS\SysWow64\igfx11cmrt32.dll, 3.00.0000.1284 (English), 5/18/2017 15:11:36, 172544 bytes
Driver: C:\WINDOWS\SysWow64\igfxcmjit32.dll, 3.00.0000.1284 (English), 5/18/2017 15:11:36, 1775616 bytes
Driver: C:\WINDOWS\system32\difx64.exe, 1.04.0003.0000 (English), 5/18/2017 15:17:46, 156280 bytes
Driver: C:\WINDOWS\system32\igfxDH.dll, 6.15.0010.4653 (English), 5/18/2017 15:11:36, 689664 bytes
Driver: C:\WINDOWS\system32\igfxDHLib.dll, 1.00.0000.0000 (Invariant Language), 5/18/2017 15:11:36, 77312 bytes
Driver: C:\WINDOWS\system32\igfxDHLibv2_0.dll, 1.00.0000.0000 (Invariant Language), 5/18/2017 15:11:36, 87040 bytes
Driver: C:\WINDOWS\system32\igfxDI.dll, 6.15.0010.4653 (English), 5/18/2017 15:11:36, 302080 bytes
Driver: C:\WINDOWS\system32\igfxDILib.dll, 1.00.0000.0000 (Invariant Language), 5/18/2017 15:11:36, 28160 bytes
Driver: C:\WINDOWS\system32\igfxDILibv2_0.dll, 1.00.0000.0000 (Invariant Language), 5/18/2017 15:11:36, 28160 bytes
Driver: C:\WINDOWS\system32\igfxLHM.dll, 6.15.0010.4653 (English), 5/18/2017 15:11:36, 269824 bytes
Driver: C:\WINDOWS\system32\igfxLHMLib.dll, 1.00.0000.0000 (Invariant Language), 5/18/2017 15:11:36, 22528 bytes
Driver: C:\WINDOWS\system32\igfxLHMLibv2_0.dll, 1.00.0000.0000 (Invariant Language), 5/18/2017 15:11:36, 22528 bytes
Driver: C:\WINDOWS\system32\igfxEM.exe, 6.15.0010.4653 (English), 5/18/2017 15:17:48, 530552 bytes
Driver: C:\WINDOWS\system32\igfxEMLib.dll, 1.00.0000.0000 (Invariant Language), 5/18/2017 15:11:36, 27648 bytes
Driver: C:\WINDOWS\system32\igfxEMLibv2_0.dll, 1.00.0000.0000 (Invariant Language), 5/18/2017 15:11:36, 27648 bytes
Driver: C:\WINDOWS\system32\GfxUIEx.exe, 6.15.0010.4653 (English), 5/18/2017 15:17:28, 959608 bytes
Driver: C:\WINDOWS\system32\Gfxv4_0.exe, 8.15.0010.4653 (English), 5/18/2017 15:17:34, 4382840 bytes
Driver: C:\WINDOWS\system32\Gfxv4_0.exe.config, 5/18/2017 15:11:30, 889 bytes
Driver: C:\WINDOWS\system32\Gfxv2_0.exe, 8.15.0010.4653 (English), 5/18/2017 15:17:30, 4379256 bytes
Driver: C:\WINDOWS\system32\Gfxv2_0.exe.config, 5/18/2017 15:11:30, 895 bytes
Driver: C:\WINDOWS\system32\MetroIntelGenericUIFramework.dll, 1.00.0000.0000 (English), 5/18/2017 15:11:38, 626688 bytes
Driver: C:\WINDOWS\system32\igfxCUIServicePS.dll, 5/18/2017 15:11:36, 103936 bytes
Driver: C:\WINDOWS\system32\igfxCUIService.exe, 6.15.0010.4653 (English), 5/18/2017 15:17:48, 319096 bytes
Driver: C:\WINDOWS\system32\igfxCPL.cpl, 5/18/2017 15:11:36, 272896 bytes
Driver: C:\WINDOWS\system32\igfxTray.exe, 6.15.0010.4653 (English), 5/18/2017 15:17:54, 372856 bytes
Driver: C:\WINDOWS\system32\igfxDTCM.dll, 6.15.0010.4653 (English), 5/18/2017 15:11:36, 226816 bytes
Driver: C:\WINDOWS\system32\igfxHK.exe, 6.15.0010.4653 (English), 5/18/2017 15:17:52, 247416 bytes
Driver: C:\WINDOWS\system32\igfxOSP.dll, 6.15.0010.4653 (English), 5/18/2017 15:11:36, 389120 bytes
Driver: C:\WINDOWS\system32\DPTopologyApp.exe, 8.15.0010.4653 (English), 5/18/2017 15:17:22, 545912 bytes
Driver: C:\WINDOWS\system32\DPTopologyApp.exe.config, 5/18/2017 15:11:30, 889 bytes
Driver: C:\WINDOWS\system32\CustomModeApp.exe, 8.15.0010.4653 (English), 5/18/2017 15:17:16, 399992 bytes
Driver: C:\WINDOWS\system32\CustomModeApp.exe.config, 5/18/2017 15:11:30, 889 bytes
Driver: C:\WINDOWS\system32\DPTopologyAppv2_0.exe, 8.15.0010.4653 (English), 5/18/2017 15:17:24, 545400 bytes
Driver: C:\WINDOWS\system32\DPTopologyAppv2_0.exe.config, 5/18/2017 15:11:30, 895 bytes
Driver: C:\WINDOWS\system32\CustomModeAppv2_0.exe, 8.15.0010.4653 (English), 5/18/2017 15:17:18, 399480 bytes
Driver: C:\WINDOWS\system32\CustomModeAppv2_0.exe.config, 5/18/2017 15:11:30, 895 bytes
Driver: C:\WINDOWS\system32\igfxext.exe, 6.15.0010.4653 (English), 5/18/2017 15:17:58, 195192 bytes
Driver: C:\WINDOWS\system32\igfxexps.dll, 6.15.0010.4653 (English), 5/18/2017 15:11:36, 49928 bytes
Driver: C:\WINDOWS\SysWow64\igfxexps32.dll, 6.15.0010.4653 (English), 5/18/2017 15:11:36, 48128 bytes
Driver: C:\WINDOWS\system32\resARA.cui, 5/18/2017 15:11:42, 165460 bytes
Driver: C:\WINDOWS\system32\resCHS.cui, 5/18/2017 15:11:42, 149524 bytes
Driver: C:\WINDOWS\system32\resCHT.cui, 5/18/2017 15:11:42, 150404 bytes
Driver: C:\WINDOWS\system32\resCSY.cui, 5/18/2017 15:11:42, 156628 bytes
Driver: C:\WINDOWS\system32\resDAN.cui, 5/18/2017 15:11:42, 153508 bytes
Driver: C:\WINDOWS\system32\resDEU.cui, 5/18/2017 15:11:42, 158388 bytes
Driver: C:\WINDOWS\system32\resELL.cui, 5/18/2017 15:11:42, 184036 bytes
Driver: C:\WINDOWS\system32\resENU.cui, 5/18/2017 15:11:42, 152164 bytes
Driver: C:\WINDOWS\system32\resESN.cui, 5/18/2017 15:11:42, 158052 bytes
Driver: C:\WINDOWS\system32\resFIN.cui, 5/18/2017 15:11:42, 155972 bytes
Driver: C:\WINDOWS\system32\resFRA.cui, 5/18/2017 15:11:42, 160196 bytes
Driver: C:\WINDOWS\system32\resHEB.cui, 5/18/2017 15:11:42, 164884 bytes
Driver: C:\WINDOWS\system32\resHRV.cui, 5/18/2017 15:11:42, 155540 bytes
Driver: C:\WINDOWS\system32\resHUN.cui, 5/18/2017 15:11:42, 160260 bytes
Driver: C:\WINDOWS\system32\resITA.cui, 5/18/2017 15:11:42, 158356 bytes
Driver: C:\WINDOWS\system32\resJPN.cui, 5/18/2017 15:11:42, 164948 bytes
Driver: C:\WINDOWS\system32\resKOR.cui, 5/18/2017 15:11:42, 158532 bytes
Driver: C:\WINDOWS\system32\resNLD.cui, 5/18/2017 15:11:42, 157332 bytes
Driver: C:\WINDOWS\system32\resNOR.cui, 5/18/2017 15:11:42, 154004 bytes
Driver: C:\WINDOWS\system32\resPLK.cui, 5/18/2017 15:11:42, 157652 bytes
Driver: C:\WINDOWS\system32\resPTB.cui, 5/18/2017 15:11:42, 156708 bytes
Driver: C:\WINDOWS\system32\resPTG.cui, 5/18/2017 15:11:42, 156420 bytes
Driver: C:\WINDOWS\system32\resROM.cui, 5/18/2017 15:11:42, 158148 bytes
Driver: C:\WINDOWS\system32\resRUS.cui, 5/18/2017 15:11:42, 179828 bytes
Driver: C:\WINDOWS\system32\resSKY.cui, 5/18/2017 15:11:42, 157492 bytes
Driver: C:\WINDOWS\system32\resSLV.cui, 5/18/2017 15:11:42, 154964 bytes
Driver: C:\WINDOWS\system32\resSVE.cui, 5/18/2017 15:11:44, 155124 bytes
Driver: C:\WINDOWS\system32\resTHA.cui, 5/18/2017 15:11:44, 191476 bytes
Driver: C:\WINDOWS\system32\resTRK.cui, 5/18/2017 15:11:44, 156596 bytes
Driver: C:\WINDOWS\system32\ig7icd64.dll, 10.18.0010.4653 (English), 5/18/2017 15:11:32, 8530944 bytes
Driver: C:\WINDOWS\SysWow64\ig7icd32.dll, 10.18.0010.4653 (English), 5/18/2017 15:11:32, 6518272 bytes
Driver: C:\WINDOWS\system32\igdumdim64.dll, 10.18.0010.4653 (English), 5/18/2017 15:11:36, 11158160 bytes
Driver: C:\WINDOWS\system32\igdail64.dll, 5/18/2017 15:11:34, 179712 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\llvm_release_license.txt, 5/18/2017 15:11:40, 1981 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\readme.txt, 5/18/2017 15:11:42, 9788 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\version.ini, 5/18/2017 15:11:42, 32 bytes
Driver: C:\WINDOWS\SysWow64\Intel_OpenCL_ICD32.dll, 1.02.0011.0000 (English), 5/18/2017 15:11:38, 77824 bytes
Driver: C:\WINDOWS\SysWow64\IntelOpenCL32.dll, 10.18.0010.4653 (English), 5/18/2017 15:11:36, 304128 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\task_executor32.dll, 3.00.0001.10891 (English), 5/18/2017 15:11:42, 225280 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\OclCpuBackend32.dll, 3.00.0001.10891 (English), 5/18/2017 15:11:40, 6776320 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\intelocl32.dll, 3.00.0001.10891 (English), 5/18/2017 15:11:40, 644096 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\cpu_device32.dll, 3.00.0001.10891 (English), 5/18/2017 15:11:40, 326144 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfnn8.rtl, 5/18/2017 15:11:40, 2986764 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfnn8_img_cbk.o, 5/18/2017 15:11:40, 240244 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfnn8_img_cbk.rtl, 5/18/2017 15:11:40, 375380 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfng9.rtl, 5/18/2017 15:11:40, 2930216 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfng9_img_cbk.o, 5/18/2017 15:11:40, 234396 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfng9_img_cbk.rtl, 5/18/2017 15:11:40, 374552 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfns9.rtl, 5/18/2017 15:11:40, 2408580 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfns9_img_cbk.o, 5/18/2017 15:11:40, 197272 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfns9_img_cbk.rtl, 5/18/2017 15:11:40, 329372 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clang_compiler32.dll, 3.00.0001.10891 (English), 5/18/2017 15:11:38, 14906880 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86__ocl_svml_n8.dll, 2.00.0000.0000 (English), 5/18/2017 15:11:42, 5911552 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86__ocl_svml_g9.dll, 2.00.0000.0000 (English), 5/18/2017 15:11:42, 5182464 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86__ocl_svml_s9.dll, 2.00.0000.0000 (English), 5/18/2017 15:11:42, 4695040 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\tbb\tbbmalloc.dll, 4.00.2012.0408 (), 5/18/2017 15:11:42, 183232 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\tbb\tbb.dll, 4.00.2012.0408 (), 5/18/2017 15:11:42, 350656 bytes
Driver: C:\WINDOWS\system32\Intel_OpenCL_ICD64.dll, 1.02.0011.0000 (English), 5/18/2017 15:11:38, 81408 bytes
Driver: C:\WINDOWS\system32\IntelOpenCL64.dll, 10.18.0010.4653 (English), 5/18/2017 15:11:36, 394240 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\task_executor64.dll, 3.00.0001.10891 (English), 5/18/2017 15:11:42, 263680 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\OclCpuBackend64.dll, 3.00.0001.10891 (English), 5/18/2017 15:11:42, 9179136 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\intelocl64.dll, 3.00.0001.10891 (English), 5/18/2017 15:11:40, 814080 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\cpu_device64.dll, 3.00.0001.10891 (English), 5/18/2017 15:11:40, 390144 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfnh8.rtl, 5/18/2017 15:11:40, 2941464 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfnh8_img_cbk.o, 5/18/2017 15:11:40, 295744 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfnh8_img_cbk.rtl, 5/18/2017 15:11:40, 388464 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfne9.rtl, 5/18/2017 15:11:40, 2884992 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfne9_img_cbk.o, 5/18/2017 15:11:40, 284840 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfne9_img_cbk.rtl, 5/18/2017 15:11:40, 387724 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfnl9.rtl, 5/18/2017 15:11:40, 2365892 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfnl9_img_cbk.o, 5/18/2017 15:11:40, 228328 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfnl9_img_cbk.rtl, 5/18/2017 15:11:40, 342372 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clang_compiler64.dll, 3.00.0001.10891 (English), 5/18/2017 15:11:40, 19593728 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64__ocl_svml_h8.dll, 2.00.0000.0000 (English), 5/18/2017 15:11:42, 6108160 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64__ocl_svml_e9.dll, 2.00.0000.0000 (English), 5/18/2017 15:11:42, 5529600 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64__ocl_svml_l9.dll, 2.00.0000.0000 (English), 5/18/2017 15:11:42, 5076480 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\tbb\tbbmalloc.dll, 4.00.2012.0408 (), 5/18/2017 15:11:42, 215488 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\tbb\tbb.dll, 4.00.2012.0408 (), 5/18/2017 15:11:42, 425920 bytes
Driver: C:\WINDOWS\SysWow64\igdbcl32.dll, 10.18.0010.4653 (English), 5/18/2017 15:11:34, 338944 bytes
Driver: C:\WINDOWS\SysWow64\igdrcl32.dll, 10.18.0010.4653 (English), 5/18/2017 15:11:34, 1803264 bytes
Driver: C:\WINDOWS\SysWow64\igdfcl32.dll, 10.18.0010.4653 (English), 5/18/2017 15:11:34, 17854976 bytes
Driver: C:\WINDOWS\system32\igdbcl64.dll, 10.18.0010.4653 (English), 5/18/2017 15:11:34, 383488 bytes
Driver: C:\WINDOWS\system32\igdrcl64.dll, 10.18.0010.4653 (English), 5/18/2017 15:11:34, 2003968 bytes
Driver: C:\WINDOWS\system32\igdfcl64.dll, 10.18.0010.4653 (English), 5/18/2017 15:11:34, 22922752 bytes
Driver: C:\Program Files\Intel\Media SDK\libmfxhw32.dll, 5.15.0005.0029 (English), 5/18/2017 15:11:38, 8401656 bytes
Driver: C:\Program Files\Intel\Media SDK\mfxplugin32_hw.dll, 3.11.0005.0020 (English), 5/18/2017 15:11:38, 599288 bytes
Driver: C:\Program Files\Intel\Media SDK\mfx_mft_h264ve_32.dll, 6.16.0007.0004 (English), 5/18/2017 15:11:38, 811008 bytes
Driver: C:\Program Files\Intel\Media SDK\mfx_mft_mjpgvd_32.dll, 6.16.0007.0004 (English), 5/18/2017 15:11:38, 753664 bytes
Driver: C:\Program Files\Intel\Media SDK\he_32.vp, 5/18/2017 15:11:30, 28553 bytes
Driver: C:\Program Files\Intel\Media SDK\c_32.cpa, 5/18/2017 15:11:30, 846855 bytes
Driver: C:\Program Files\Intel\Media SDK\cpa_32.vp, 5/18/2017 15:11:30, 993 bytes
Driver: C:\Program Files\Intel\Media SDK\dev_32.vp, 5/18/2017 15:11:30, 21523 bytes
Driver: C:\Program Files\Intel\Media SDK\mj_32.vp, 5/18/2017 15:11:38, 26961 bytes
Driver: C:\Program Files\Intel\Media SDK\libmfxhw64.dll, 5.15.0005.0029 (English), 5/18/2017 15:11:38, 9309432 bytes
Driver: C:\Program Files\Intel\Media SDK\mfxplugin64_hw.dll, 3.11.0005.0020 (English), 5/18/2017 15:11:38, 696056 bytes
Driver: C:\Program Files\Intel\Media SDK\mfx_mft_h264ve_64.dll, 6.16.0007.0004 (English), 5/18/2017 15:11:38, 1003520 bytes
Driver: C:\Program Files\Intel\Media SDK\mfx_mft_mjpgvd_64.dll, 6.16.0007.0004 (English), 5/18/2017 15:11:38, 932864 bytes
Driver: C:\Program Files\Intel\Media SDK\he_64.vp, 5/18/2017 15:11:30, 6533 bytes
Driver: C:\Program Files\Intel\Media SDK\c_64.cpa, 5/18/2017 15:11:30, 1519616 bytes
Driver: C:\Program Files\Intel\Media SDK\cpa_64.vp, 5/18/2017 15:11:30, 993 bytes
Driver: C:\Program Files\Intel\Media SDK\dev_64.vp, 5/18/2017 15:11:30, 21523 bytes
Driver: C:\Program Files\Intel\Media SDK\mj_64.vp, 5/18/2017 15:11:38, 6321 bytes
Driver: C:\WINDOWS\system32\IntelWiDiMCUMD64.dll, 4.05.0072.0000 (English), 5/18/2017 15:11:36, 150496 bytes
Driver: C:\WINDOWS\system32\IntelWiDiSecureSourceFilter64.dll, 4.05.0072.0000 (English), 5/18/2017 15:11:36, 1478624 bytes
Driver: C:\WINDOWS\system32\IntelWiDiAAC64.dll, 4.05.0072.0000 (English), 5/18/2017 15:11:36, 4032992 bytes
Driver: C:\WINDOWS\system32\IntelWiDiMux64.dll, 4.05.0072.0000 (English), 5/18/2017 15:11:36, 625632 bytes
Driver: C:\WINDOWS\system32\IntelWiDiDDEAgent64.dll, 4.05.0072.0000 (English), 5/18/2017 15:11:36, 199648 bytes
Driver: C:\WINDOWS\system32\IntelWiDiAudioFilter64.dll, 4.05.0072.0000 (English), 5/18/2017 15:11:36, 668128 bytes
Driver: C:\WINDOWS\system32\IntelWiDiUtils64.dll, 4.05.0072.0000 (English), 5/18/2017 15:11:36, 232416 bytes
Driver: C:\WINDOWS\system32\IntelWiDiLogServer64.dll, 4.05.0072.0000 (English), 5/18/2017 15:11:36, 116192 bytes
Driver: C:\WINDOWS\system32\IntelWiDiWinNextAgent64.dll, 4.05.0072.0000 (English), 5/18/2017 15:11:38, 881120 bytes
Driver: C:\WINDOWS\system32\IntelWiDiSilenceFilter64.dll, 4.05.0072.0000 (English), 5/18/2017 15:11:36, 366560 bytes
Driver: C:\WINDOWS\system32\IntelWiDiVAD64.exe, 4.05.0072.0000 (English), 5/18/2017 15:17:42, 2497568 bytes
Driver: C:\WINDOWS\system32\IntelWiDiUMS64.exe, 4.05.0072.0000 (English), 5/18/2017 15:17:40, 433784 bytes
Driver: C:\WINDOWS\system32\igfxCoIn_v4653.dll, 1.03.0018.0000 (English), 5/18/2017 15:11:36, 212480 bytes
Driver: C:\WINDOWS\system32\DisplayAudiox64.cab, 5/18/2017 15:11:30, 316245 bytes
 Name: High Definition Audio Controller
Device ID: PCI\VEN_8086&DEV_1E20&SUBSYS_15A71043&REV_04\3&11583659&0&D8
Driver: C:\WINDOWS\system32\DRIVERS\hdaudbus.sys, 10.00.16299.0015 (English), 9/30/2017 02:40:59, 86016 bytes
Driver: C:\WINDOWS\system32\DRIVERS\drmk.sys, 10.00.16299.0015 (English), 9/30/2017 02:40:59, 96768 bytes
Driver: C:\WINDOWS\system32\DRIVERS\portcls.sys, 10.00.16299.0015 (English), 9/30/2017 02:40:59, 379392 bytes
 Name: Intel(R) 7 Series/C216 Chipset Family PCI Express Root Port 4 - 1E16
Device ID: PCI\VEN_8086&DEV_1E16&SUBSYS_15A71043&REV_C4\3&11583659&0&E3
 Name: Intel(R) 7 Series/C216 Chipset Family USB Enhanced Host Controller - 1E26
Device ID: PCI\VEN_8086&DEV_1E26&SUBSYS_15A71043&REV_04\3&11583659&0&E8
Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 10.00.16299.0015 (English), 9/30/2017 02:41:08, 95640 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 10.00.16299.0015 (English), 9/30/2017 02:41:08, 454040 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 10.00.16299.0015 (English), 9/30/2017 02:41:08, 513944 bytes
 Name: Intel(R) HM77 Express Chipset LPC Controller - 1E57
Device ID: PCI\VEN_8086&DEV_1E57&SUBSYS_15A71043&REV_04\3&11583659&0&F8
Driver: C:\WINDOWS\system32\DRIVERS\msisadrv.sys, 10.00.16299.0015 (English), 9/30/2017 02:41:03, 18840 bytes
 Name: Intel(R) 7 Series/C216 Chipset Family USB Enhanced Host Controller - 1E2D
Device ID: PCI\VEN_8086&DEV_1E2D&SUBSYS_15A71043&REV_04\3&11583659&0&D0
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,10.00.16299.0015
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,10.00.16299.0015
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,10.00.16299.0015
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,10.00.16299.0015
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,10.00.16299.0015
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,10.00.16299.0015
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,10.00.16299.0015
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,10.00.16299.0015
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,10.00.16299.0015
WD Secure Source Filter,0x00200000,0,1,WDSecureSourceFilter.dll,3.05.0040.0000
DV Muxer,0x00400000,0,0,qdv.dll,10.00.16299.0015
Color Space Converter,0x00400001,1,1,quartz.dll,10.00.16299.0015
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.16299.0015
AVI Splitter,0x00600000,1,1,quartz.dll,10.00.16299.0015
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,10.00.16299.0015
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,10.00.16299.0015
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,10.00.16299.0248
DS Video Buffer Filter,0x00200000,1,1,DSBuffer_Video.ax,3.05.0040.0000
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,10.00.16299.0015
StreamBufferSink,0x00200000,0,0,sbe.dll,10.00.16299.0015
MJPEG Decompressor,0x00600000,1,1,quartz.dll,10.00.16299.0015
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,10.00.16299.0015
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,10.00.16299.0015
VBI Codec,0x00600000,1,4,VBICodec.ax,10.00.16299.0015
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,10.00.16299.0015
Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,10.00.16299.0015
SBE2FileScan,0x00200000,0,0,sbe.dll,10.00.16299.0015
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,10.00.16299.0015
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,10.00.16299.0015
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,10.00.16299.0015
TechSmith File Source,0x00400000,0,1,CamtasiaFilters.dll,8.01.0002.1327
TechSmith SWF Writer,0x00200000,2,0,CamtasiaFilters.dll,8.01.0002.1327
TechSmith WMFSDK Writer,0x00200000,1,0,CamtasiaFilters.dll,8.01.0002.1327
TechSmith Simple PIP,0x00200000,0,0,CamtasiaFilters.dll,8.01.0002.1327
ImageSource,0x00200000,0,0,CamtasiaFilters.dll,8.01.0002.1327
TitleSource,0x00200000,0,0,CamtasiaFilters.dll,8.01.0002.1327
TechSmith Time Adjust,0x00200000,1,1,CamtasiaFilters.dll,8.01.0002.1327
TechSmith Splitter Filter,0x00200000,1,1,CamtasiaFilters.dll,8.01.0002.1327
TechSmith Frame Skip Filter,0x00200000,1,1,CamtasiaFilters.dll,8.01.0002.1327
TechSmith Perf Skip Filter,0x00200000,1,1,CamtasiaFilters.dll,8.01.0002.1327
TechSmith ZoomPIP Filter,0x00200000,2,1,CamtasiaFilters.dll,8.01.0002.1327
TechSmith PushVMR Source,0x00200000,0,1,CamtasiaFilters.dll,8.01.0002.1327
TechSmith PushBitmap Source,0x00200000,0,2,CamtasiaFilters.dll,8.01.0002.1327
TechSmith SimplePushBitmap Source,0x00200000,0,2,CamtasiaFilters.dll,8.01.0002.1327
TechSmith Wave Dest,0x00200000,0,0,CamtasiaFilters.dll,8.01.0002.1327
TechSmith Overlay,0x00200000,1,1,CamtasiaFilters.dll,8.01.0002.1327
TechSmith Wave Buffer,0x00200000,1,0,CamtasiaFilters.dll,8.01.0002.1327
TechSmith ForceColor 8,0x00200000,0,0,CamtasiaFilters.dll,8.01.0002.1327
TechSmith ForceColor 555,0x00200000,0,0,CamtasiaFilters.dll,8.01.0002.1327
TechSmith ForceColor 565,0x00200000,0,0,CamtasiaFilters.dll,8.01.0002.1327
TechSmith ForceColor 24,0x00200000,0,0,CamtasiaFilters.dll,8.01.0002.1327
TechSmith ForceColor 32,0x00200000,0,0,CamtasiaFilters.dll,8.01.0002.1327
TechSmith Force Color32A,0x00200000,0,0,CamtasiaFilters.dll,8.01.0002.1327
SSFileWriter,0x00200000,1,0,CamtasiaFilters.dll,8.01.0002.1327
TechSmith Frame Rate Tuner,0x00200000,1,1,CamtasiaFilters.dll,8.01.0002.1327
TechSmith Camera Adjust,0x00200000,1,1,CamtasiaFilters.dll,8.01.0002.1327
TechSmith Sound Effects Filter,0x00200000,1,1,CamtasiaFilters.dll,8.01.0002.1327
TechSmith Flv Key Frame Setter,0x00200000,1,1,CamtasiaFilters.dll,8.01.0002.1327
TechSmith Floating Point Wave Filter,0x003fffff,1,1,CamtasiaFilters.dll,8.01.0002.1327
DV Splitter,0x00600000,1,2,qdv.dll,10.00.16299.0015
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,10.00.16299.0015
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,10.00.16299.0015
ACM Wrapper,0x00600000,1,1,quartz.dll,10.00.16299.0015
Video Renderer,0x00800001,1,0,quartz.dll,10.00.16299.0015
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,10.00.16299.0015
Line 21 Decoder,0x00600000,1,1,
Video Port Manager,0x00600000,2,1,quartz.dll,10.00.16299.0015
Video Renderer,0x00400000,1,0,quartz.dll,10.00.16299.0015
VPS Decoder,0x00200000,0,0,WSTPager.ax,10.00.16299.0015
Intel® AAC encoder,0x00200000,1,1,intelaac.dll,
WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.16299.0015
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,
File writer,0x00200000,1,0,qcap.dll,10.00.16299.0015
Intel® Mux Renderer,0x00200000,2,0,intelmux.dll,3.05.0040.0000
DVD Navigator,0x00200000,0,3,qdvd.dll,10.00.16299.0015
Overlay Mixer2,0x00200000,1,1,
AVI Draw,0x00600064,9,1,quartz.dll,10.00.16299.0015
TechSmith Grabber Sample Filter,0x00200000,1,1,CamtasiaFilters.dll,8.01.0002.1327
Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,10.00.16299.0015
WST Pager,0x00200000,1,1,WSTPager.ax,10.00.16299.0015
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,10.00.16299.0015
DV Video Decoder,0x00800000,1,1,qdv.dll,10.00.16299.0015
SampleGrabber,0x00200000,1,1,qedit.dll,10.00.16299.0015
Null Renderer,0x00200000,1,0,qedit.dll,10.00.16299.0015
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,10.00.16299.0015
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,10.00.16299.0015
StreamBufferSource,0x00200000,0,0,sbe.dll,10.00.16299.0015
Smart Tee,0x00200000,1,2,qcap.dll,10.00.16299.0015
Overlay Mixer,0x00200000,0,0,
AVI Decompressor,0x00600000,1,1,quartz.dll,10.00.16299.0015
WD Audio Filter,0x00200000,0,1,WDAudioFilter.dll,3.05.0040.0000
AVI/WAV File Source,0x00400000,0,2,quartz.dll,10.00.16299.0015
Wave Parser,0x00400000,1,1,quartz.dll,10.00.16299.0015
MIDI Parser,0x00400000,1,1,quartz.dll,10.00.16299.0015
Multi-file Parser,0x00400000,1,1,quartz.dll,10.00.16299.0015
File stream renderer,0x00400000,1,1,quartz.dll,10.00.16299.0015
Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,10.00.16299.0015
StreamBufferSink2,0x00200000,0,0,sbe.dll,10.00.16299.0015
AVI Mux,0x00200000,1,0,qcap.dll,10.00.16299.0015
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,10.00.16299.0015
File Source (Async.),0x00400000,0,1,quartz.dll,10.00.16299.0015
File Source (URL),0x00400000,0,1,quartz.dll,10.00.16299.0015
WDSource Filter,0x00200000,0,1,WDSourceFilter.dll,3.05.0040.0000
WD Silence Filter,0x00200000,0,1,WDSilenceFilter.dll,
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,10.00.16299.0015
Enhanced Video Renderer,0x00200000,1,0,evr.dll,10.00.16299.0248
Intel®WiDi H264 encoder,0x00200000,1,1,h264HWEnc.dll,
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,10.00.16299.0015
MPEG Video Decoder,0x40000001,1,1,quartz.dll,10.00.16299.0015
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,10.00.16299.0015
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,10.00.16299.0248
WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,10.00.16299.0015
MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,10.00.16299.0248
DV Video Encoder,0x00200000,0,0,qdv.dll,10.00.16299.0015
MJPEG Compressor,0x00200000,0,0,quartz.dll,10.00.16299.0015
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,10.00.16299.0015
WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,10.00.16299.0015
IMA ADPCM,0x00200000,1,1,quartz.dll,10.00.16299.0015
Microsoft ADPCM,0x00200000,1,1,quartz.dll,10.00.16299.0015
GSM 6.10,0x00200000,1,1,quartz.dll,10.00.16299.0015
CCITT A-Law,0x00200000,1,1,quartz.dll,10.00.16299.0015
CCITT u-Law,0x00200000,1,1,quartz.dll,10.00.16299.0015
MPEG Layer-3,0x00200000,1,1,quartz.dll,10.00.16299.0015
Audio Capture Sources:
Microphone (Realtek High Definition Audio),0x00200000,0,0,qcap.dll,10.00.16299.0015
PBDA CP Filters:
PBDA DTFilter,0x00600000,1,1,CPFilters.dll,10.00.16299.0192
PBDA ETFilter,0x00200000,0,0,CPFilters.dll,10.00.16299.0192
PBDA PTFilter,0x00200000,0,0,CPFilters.dll,10.00.16299.0192
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,10.00.16299.0015
Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,10.00.16299.0015
WDM Streaming Capture Devices:
USB2.0 HD UVC WebCam,0x00200000,1,2,ksproxy.ax,10.00.16299.0015
Realtek HD Audio Mic input,0x00200000,1,1,ksproxy.ax,10.00.16299.0015
Realtek HD Audio Stereo input,0x00200000,1,1,ksproxy.ax,10.00.16299.0015
WDM Streaming Rendering Devices:
Realtek HD Audio output,0x00200000,1,1,ksproxy.ax,10.00.16299.0015
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.16299.0015
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.16299.0015
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.16299.0015
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.16299.0015
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,10.00.16299.0015
Video Capture Sources:
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,10.00.16299.0015
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,10.00.16299.0015
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,1,EncDec.dll,10.00.16299.0192
Encrypt/Tag,0x00200000,0,0,EncDec.dll,10.00.16299.0192
PTFilter,0x00200000,0,0,EncDec.dll,10.00.16299.0192
XDS Codec,0x00200000,0,0,EncDec.dll,10.00.16299.0192
WDM Streaming Communication Transforms:
Audio Renderers:
Speakers (Realtek High Definition Audio),0x00200000,1,0,quartz.dll,10.00.16299.0015
Default DirectSound Device,0x00800000,1,0,quartz.dll,10.00.16299.0015
Default WaveOut Device,0x00200000,1,0,quartz.dll,10.00.16299.0015
DirectSound: Speakers (Realtek High Definition Audio),0x00200000,1,0,quartz.dll,10.00.16299.0015
So I’m having this exact same problem with my openGL game.
Your demo is buggy on the same machines my game is buggy on.
I posted about it here:
[url]What do nvldumdx.dll & nvd3dumx.dll do? - OpenGL - NVIDIA Developer Forums
It’s obviously not related to those dll’s, but in my case when I record and replay with apitrace I get the correct results.
What I forgot to mention in my post was that this same code used to work 2 years ago on windows 7.
