I’m trying to run a pipeline with a video recorded with a 20 MP camera and I get the following error:
Error String :
Resolution : 5504x3680
Max Supported (wxh) : 4096x4096
Resolution not supported on this GPUError Code : 801
2024-02-27 11:56:03,356 [ERROR][root] ERROR: [gst-resource-error-quark: Failed to process frame. (1)] gstv4l2videodec.c(1804): gst_v4l2_video_dec_handle_frame (): /GstPipeline:pipeline0/GstDsNvUriSrcBin:dsnvurisrcbin0/GstURIDecodeBin:nvurisrc_bin_src_elem/GstDecodeBin:decodebin0/nvv4l2decoder:nvv4l2decoder0:
Maybe be due to not enough memory or failing driver
2024-02-27 11:56:03,357 [ERROR][root] ERROR: [gst-stream-error-quark: Internal data stream error. (1)] matroska-demux.c(5732): gst_matroska_demux_loop (): /GstPipeline:pipeline0/GstDsNvUriSrcBin:dsnvurisrcbin0/GstURIDecodeBin:nvurisrc_bin_src_elem/GstDecodeBin:decodebin0/GstMatroskaDemux:matroskademux0:
streaming stopped, reason error (-5)
Changing the video resolution to the max specified is not an option because we need it for the model inference.
