Can I Run Raspbian On JetsonNano???
Raspbian is a variant of Debian Linux that is customized for the VideoCore of the Raspberry Pi system. It will not work on any other hardware, and will not work on Jetson anything.
The Jetson runs Ubuntu Linux, which is another derivative of Debian Linux, so many things that you know how to do in Raspbian (if they aren’t specific to the Pi hardware) will likely work the same on Ubuntu, though.
So … There is an Armbian build available for it, And I also have a Yocto build for the Nano.
https://devtalk.nvidia.com/default/topic/1052684/jetson-nano/armbian-for-jetson-nano/
it does work, Ive tested it after a bit of a fight with an sdcard.
