File “helmholtz.py”, line 3, in
import modulus
File “/home/datascience/conda/nmodulusv1_0/lib/python3.8/site-packages/modulus-22.9-py3.8.egg/modulus/init.py”, line 7, in
from .hydra.utils import main, compose
File “/home/datascience/conda/nmodulusv1_0/lib/python3.8/site-packages/modulus-22.9-py3.8.egg/modulus/hydra/init.py”, line 1, in
from .utils import (
File “/home/datascience/conda/nmodulusv1_0/lib/python3.8/site-packages/modulus-22.9-py3.8.egg/modulus/hydra/utils.py”, line 18, in
from modulus.models.arch import Arch
File “/home/datascience/conda/nmodulusv1_0/lib/python3.8/site-packages/modulus-22.9-py3.8.egg/modulus/models/arch.py”, line 6, in
import functorch
File “/home/datascience/conda/nmodulusv1_0/lib/python3.8/site-packages/functorch/init.py”, line 13, in
from . import _C
ImportError: /home/datascience/conda/nmodulusv1_0/lib/python3.8/site-packages/functorch/_C.so: undefined symbol: _ZN3c105ErrorC2ENS_14SourceLocationESs
Seems this is an issue arising from functorch, is this using the docker image? I see you’re in a Conda environment so I would focus on getting functorch working in your Python environment before running Modulus.
Also what operating system are you using?
