Running PyTorch to use artificial intelligence to generate images with Nvidia GTX 1650Ti
I am using Ubuntu 22.04.4 LTS with 6.5.0-35-generic kernel.
I have nvidia-driver-555 with cuda-toolkit NVIDIA Container Runtime Hook version 1.17.1
installed. (Driver Version: 555.58.02 CUDA Version: 12.5)
this is the python code I’m running on conda environment
from diffusers import StableDiffusionPipeline
import torch
# Load the pre-trained Stable Diffusion model from Hugging Face
pipe = StableDiffusionPipeline.from_pretrained("CompVis/stable-diffusion-v1-4", torch_dtype=torch.float16)
# Move the model to GPU if available
pipe = pipe.to("cuda")
# Define your text prompt
prompt = "A scenic landscape with high mountains, a flowing river in the valley, and a colorful sunset sky with warm shades of orange and purple."
# Generate the image from the text prompt
image = pipe(prompt).images[0]
# Display the generated image
image.show()
# Optionally, save the image
image.save("generated_landscape.png")
I’m always getting black image with this error as output
import torch
import numpy as np
from PIL import Image
# Disable the safety checker (optional)
pipe.safety_checker = None
# Move the model to CPU (instead of GPU)
pipe = pipe.to("cpu")
# Define a very simple prompt to test the image generation
prompt = "a blue square"  # Simple prompt to check if the image generation works
output = pipe(prompt)
# Check the raw output (before image conversion)
print(f"Raw output: {output}")
# Check if any images were returned
if hasattr(output, 'images') and len(output.images) > 0:
    image = output.images[0]
    image_array = np.array(image)
    # Check raw image values
    print(f"Raw image array shape: {image_array.shape}")
    print(f"Min value in raw image: {np.min(image_array)}, Max value in raw image: {np.max(image_array)}")
    # If image is completely black
    if np.all(image_array == 0):
        print("The generated image is completely black.")
    # Normalize and convert to uint8
    image_array = np.clip(image_array * 255, 0, 255)
    image_array = image_array.astype(np.uint8)
    # Convert back to a PIL image
    image = Image.fromarray(image_array)
    # Display and save the image
    image.show()
    image.save("generated_blue_square.png")
else:
    print("Error: No images returned by the model.")
and I’m getting following error
/home/user/anaconda3/envs/myenv/lib/python3.9/site-packages/diffusers/image_processor.py:147: RuntimeWarning: invalid value encountered in cast
images = (images * 255).round().astype(“uint8”)
last try, I was able to produce image of blue rectangle on black gradient
using this code (had to be blue squere with white background)
import torch
import numpy as np
pipe = StableDiffusionPipeline.from_pretrained(“CompVis/stable-diffusion-v1-4”)
Move the model to the CPU (if you are testing on CPU)
pipe = pipe.to(“cpu”)
Define a more refined and specific prompt
prompt = “A perfect blue square centered on a white background.”
if hasattr(output, ‘images’) and len(output.images) > 0:
image.show()
image.save("generated_perfect_blue_square.png")
else:
print(“Error: No images returned by the model.”)
My last try after 300 invalid try’s and this code generates black image
import torch
Clear GPU cache
torch.cuda.empty_cache()
Load the Stable Diffusion model with mixed precision
“stabilityai/stable-diffusion-2-1-base”, torch_dtype=torch.float16
pipe = pipe.to(“cuda”) # Move the model to the GPU
Enable attention slicing for lower memory usage
pipe.enable_attention_slicing()
Set environment variable to prevent memory fragmentation
torch.backends.cuda.matmul.allow_tf32 = True # Allows TF32 to reduce memory in tensor ops
torch.backends.cudnn.benchmark = True # Optimizes performance for consistent input sizes
Define the prompt and image parameters
prompt = “A beautiful painting of a serene mountain landscape during sunrise.”
try:
# Generate the image with specified size (lower dimensions if necessary)
output = pipe(prompt=prompt, height=512, width=512)
if not output.images or len(output.images) == 0:
raise ValueError(“No images were generated by the pipeline.”)
# Retrieve the generated image
# Display the image for verification
image.show()
# Save the image
output_path = "mountain_landscape.png"
image.save(output_path)
print(f"Image successfully saved to {output_path}.")
except torch.cuda.OutOfMemoryError:
print(“CUDA out of memory. Try reducing the image size or batch size.”)
except Exception as e:
raise RuntimeError(f"Image generation failed: {e}")
