Running QNX onto Jetson TK1 Pro (1860)
I downloaded JetPackTK1ProQNX-1.2-linux-x64-PDK.run and vibrante-vcm30t124-qnx-V3Q-23.16.01-5757763.zip. After I run the file JetPackTK1ProQNX-1.2-linux-x64-PDK.run. it seems everything is ok.
The logs from minicom:
Welcome to QNX on the nVidia T124 board
Starting pipe manager…
Starting devg-nvsku
Starting nvclock
Starting I2C master drivers…
Starting nvos
Starting I2C master driver for HDMI DDC…
Starting Powergate server…
Starting MC Latency server…
Starting res_init
Starting NvPmu server…
Starting SOC_THERM server…
Starting DVFS server…
Starting io-nvdt
Starting serial driver UART-C…
Starting Powergate in
Starting DVFS init…
Starting nvrm
Starting devg-nvgpio
Starting DVFS governor …
Started Tegra dvfs governor
Sampling interval = 10
Starting display init…
Initializing i2s controller0 for BT/WIFI
Starting onboard mNAND…
Starting External MMC slot driver…
Starting devg-nvtmon…
Starting MCD server…
Starting External SD Card 1 slot driver…
Initializing i2s controller2 for Modem
Path=0 - Generic SDHCI
Starting USB Host 1, 2 and XUSB controllers…
target=0 lun=0 Direct-Access(0) - MMC:144 HCG8e4 Rev: 0.3
target=0 lun=0 Direct-Access(0) - MMC:144 H8G2d4 Rev: 0.3
Starting Usb Ethernet with TCP/IP stack…
Starting Mass storage device…
SATA: Sata Init: Pxis failed
Path=0 - AHCI (generic)
Is there anything wrong? there is no MMC card inserted.
However, when I ssh into the device, it seems a minimum OS is running on device. Shall I manually copy the entire directory vibrante-vcm30t124-qnx-V3Q from host to device?
thanks
Robin
It seems I need to manually mount qnx.
but when I screen. it crashes.
screen
Memory fault
It’s hard to test without a TK1 Pro. You may need to ask the QNX people since there isn’t enough information to go by.
the issue is gone today. I could run application now. don’t know the root cause. the topic can be closed.
