I have the following short c++ program (pos.cpp) that creates a cublas handle. It compiles fine using the command that follows the listed program. Running the executable as per the next section yields no errors, and the expected output. However, when running compute-sanitizer memcheck, there are errors (“Error: process didn’t terminate successfully”). If I comment out the cublasCreate line in pos.cpp (“stat = cublasCreate(&handle);”), there are no errors. Below gives my cpp, compile command, execute command, and command to invoke compute-sanitizer. The gpu card is a tesla V100, if that matters, and this is one node on an HPC, using cuda 11.5 in the HPC SDK… I don’t know why I get this error.
Thank you.
// pos.cpp
#include <cuda.h>
#include <cuda_runtime.h>
#include <cublas_v2.h>
#include <stdio.h>
#include <stdlib.h>
#include
int main(void){
cublasHandle_t handle;
cublasStatus_t stat;
std::cout << "stat=" << stat << std::endl;
cublasDestroy ( handle );
return 0;
// compile and link pos.cpp using HPC SDK CUDA 11.5:(and necessary includes)
nvc++ pos.cpp -lcublas
// run executable
./a.out
stat=0
// run compute-sanitizer memcheck:
compute-sanitizer --tool memcheck ./a.out
========= COMPUTE-SANITIZER
========= Error: process didn’t terminate successfully
========= Target application returned an error
========= ERROR SUMMARY: 0 errors
Sorry, no idea. I tried you’re program here with NVHPC 22.1 and CUDA 11.5 but didn’t see any error. Any additional information that you can give such as the nvc++ version you’re using? Are you using the CUDA 11.5 that comes with the NVHPC SDK or from a CUDA SDK?
I believe some early versions of compute-sanitizer had issues, but don’t know if this is to blame here.
Also, the formatting of the program was off in your post so don’t know if I’m missing anything relevant.
-Mat
Thanks. I see that one of the include directives got chopped off. At the end is my full program, all within pretext.
The nvc++ version is:
nvc++ 22.1-0 64-bit target on x86-64 Linux -tp skylake-avx512
I am using the CUDA 11.5 that comes with the NVHPC SDK, contained within this directory:
NVIDIA_HPC_SDK/Linux_x86_64/22.1/cuda/11.5
However, if I run nvidia-smi, I see that cuda 11.4 may be what is used:
| NVIDIA-SMI 470.74 Driver Version: 470.74 CUDA Version: 11.4 |
| | | MIG M. |
| 0 Tesla V100-PCIE... Off | 00000000:D8:00.0 Off | 0 |
| N/A 34C P0 35W / 250W | 0MiB / 32510MiB | 2% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| No running processes found |
Here is the program again:
#include <cuda.h>
#include <stdio.h>
#include <iostream>
#include <stdlib.h>
int main(void){
return 0;
The version of compute-sanitizer is:
NVIDIA (R) Compute Sanitizer
Copyright (c) 2020-2021 NVIDIA Corporation
Version 2021.3.1
My PATH is set to only call the nvc++ and nvcc from here:
NVIDIA_HPC_SDK/Linux_x86_64/22.1/compilers/bin
But, it’s possible that the CUDA 11.4 version takes over, if that is an issue.
Thanks, I’m now able to recreate the error. It is due to the mismatch in the CUDA Driver version. The driver is backwards compatible but not forward compatible. You’ll need to either update your driver or use the CUDA 11.0 libraries, i.e. add “-gpu=cuda11.0”.
Using a system with a CUDA 11.3 driver with the CUDA 11.5 libraries:
% nvc++ -cuda -gpu=cuda11.5 test.cpp -I/proj/nv/Linux_x86_64/22.1/math_libs/11.5/include/ -cudalib=cublas
% compute-sanitizer a.out
========= Program hit CUDA_ERROR_NOT_FOUND (error 500) due to "named symbol not found" on CUDA API call to cuGetProcAddress.
========= Saved host backtrace up to driver entry point at error
.... continues ...
Works when switching to use the CUDA 11.0 libraries:
% nvc++ -cuda -gpu=cuda11.0 test.cpp -I/proj/nv/Linux_x86_64/22.1/math_libs/11.0/include/ -cudalib=cublas
stat=0
Hope this helps,
Mat
