Hi all,
I am using Nvidia Jetson Xavier NX device and trying to import cudf and cuml libraries in RAPIDS Jupyter notebook docker image. But when executing the notebook cell, I am getting an error as below.
RuntimeError: Failed to dlopen libcuda.so
libcuda.so is available in the “/usr/local/cuda/targets/sbsa-linux/lib/stubs:” and I have set the LD_LIBRARY_PATH into this folder path as well. But the error is still coming up. Do I need to set any other system paths apart from the LD_LIBRARY_PATH?
Any advice would be greatly appreciated!
Thank you
