Hello!
I had this problem when building a package on ROS2 Humble.
I have all the libs and it seems that even the signatures of the erroneous functions are in the libcudla.so
libs, etc.
But I still can’t build the ROS package. What could be the problem?
I use nvcr.io/nvidia/l4t-jetpack:r36.4.0
with the command
nvidia-docker run -it --rm --mount type=bind,source=$(pwd),target=/workspace --gpus all --runtime nvidia nvcr.io/nvidia/l4t-jetpack:r36.4.0
Then
colcon build --packages-select modern_detect --symlink-install --continue-on-error --cmake-args -DBUILD_TESTING=OFF -DCMAKE_EXPORT_COMPILE_COMMANDS=ON -DCMAKE_BUILD_TYPE=Release
Starting >>> modern_detect
--- stderr: modern_detect
/usr/bin/ld: /usr/local/cuda/lib64/libcudla.so.1: undefined reference to `cudlaDrvGetExternalExportTable'
/usr/bin/ld: /usr/lib/gcc/aarch64-linux-gnu/11/../../../aarch64-linux-gnu/libnvinfer.so: undefined reference to `nvdla::IProfile::setCanGenerateDetailedLayerwiseStats(bool)'
/usr/bin/ld: /usr/lib/gcc/aarch64-linux-gnu/11/../../../aarch64-linux-gnu/libnvinfer.so: undefined reference to `nvdla::IConcatenationLayer::setAxis(int)'
/usr/bin/ld: /usr/local/cuda/lib64/libcudla.so.1: undefined reference to `cudlaDrvSetTaskTimeoutInMs'
collect2: error: ld returned 1 exit status
gmake[2]: *** [CMakeFiles/modern_detect_node.dir/build.make:278: modern_detect_node] Error 1
gmake[1]: *** [CMakeFiles/Makefile2:182: CMakeFiles/modern_detect_node.dir/all] Error 2
gmake: *** [Makefile:146: all] Error 2
Failed <<< modern_detect [2.74s, exited with code 2]
Summary: 0 packages finished [5.03s]
1 package failed: modern_detect
1 package had stderr output: modern_detect
