Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.7.1.8928
other
Host Machine Version
native Ubuntu 18.04
other
Hello, there!
I’m trying to use sample_lidar_replay to visualize my recorded lidar data as a 3D point cloud. But the output is not as expected.
The recorded data has been sampled by a non-supported custom lidar. The lidar is not rotating. It creates a picture of 3260 points. 96 pictures have been recorded without moving the lidar.
I mapped my recorded data to the dwLidarDecodedPacket structure in the following why:
dwTime_t hostTimestamp; → currently set to 0
dwTime_t sensorTimestamp; → currently set to 0
dwTime_t duration; → should be 0 (nothing rotating)
uint32_t maxPoints; → 3260=1.920
uint32_t nPoints; → 1920
bool scanComplete; → true
const dwLidarPointRTHI* pointsRTHI; → spherical coordinates, intensity=0
const dwLidarPointXYZI* pointsXYZI; → set to NULL
I also changed the dwLidarProperties as follows:
spinFrequency = 30; → 30 frames per second
packetsPerSecond = 30;
packetsPerSpin = 1;
pointsPerSecond = 303260;
pointsPerPacket = 3260;
pointsPerSpin = 3260;
pointStride = 4;
In the sample_lidar_replay main.cpp I mainly made these changes:
· Instead of calling dwSensorLidar_readPacket I take the mapped date from my recorder file.
· I changed the coordinates from XYZ to RTH
· Function dwSensorLidar_returnPacket is not used
After building I execute the new sample_lidar_replay on nvidia drive AGX Xavier A. As output I can see a rectangular point cloud – see picture.
It shows a 360° point cloud, but as the lidar is not rotating I expected a theta = 70° point cloud only.
Is my mapping to dwLidarDecodedPacket and dwLidarProperties correct?
Is the sample_lidar_replay capable to work with spherical coordinates?
Do I have to define the coordinate system?
