Please provide the following info (check/uncheck the boxes after clicking “+ Create Topic”):
Software Version
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.6.0.8170
1.5.1.7815
1.5.0.7774
other
Host Machine Version
native Ubuntu 18.04
other
We have connected the Velodyne Puck Hi-Res LIDAR to the Nvidia Drive AGX through the provided ethernet dongle, to J12 (1/2) (shown in pic).
However, the Lidar is not getting connected to the Drive AGX. The lights wrt the Lidar, on the dongle, are both red and blinking (shown in pic).
We need help with the configuration and setup.
Following is the content of /etc/systemd/network/99-nv_eth0_default.network:
[Match]
Name=eth0
##Network settings
[Network]
DHCP=no
##eth0 100Mbps interface
Address=10.99.230.6/24
Gateway=10.99.230.1
DNS=10.8.64.11
DNS=10.8.64.12
[Address]
#XA Radar Interface
Label=eth0:900
Address=10.1.0.81/16
[Address]
#XA Lidar Interface
Label=eth0:400
Address=192.168.1.200/24
Gateway=192.168.1.1
DNS=192.168.1.1
Following is the output of ifconfig:
can0: flags=193<UP,RUNNING,NOARP> mtu 16
unspec 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00 txqueuelen 10 (UNSPEC)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
device interrupt 108
can1: flags=193<UP,RUNNING,NOARP> mtu 16
RX packets 97 bytes 776 (776.0 B)
device interrupt 109
enp4s0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
inet 192.168.0.10 netmask 255.255.255.0 broadcast 192.168.0.255
ether 00:04:4b:f6:53:aa txqueuelen 1000 (Ethernet)
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 10.99.230.6 netmask 255.255.255.0 broadcast 10.99.230.255
inet6 fe80::204:4bff:fef6:53a7 prefixlen 64 scopeid 0x20
ether 00:04:4b:f6:53:a7 txqueuelen 1000 (Ethernet)
RX packets 561 bytes 50640 (50.6 KB)
RX errors 0 dropped 279 overruns 0 frame 0
TX packets 1132 bytes 162799 (162.7 KB)
device interrupt 84
eth0:400: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.1.200 netmask 255.255.255.0 broadcast 192.168.1.255
device interrupt 84
eth0:900: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 10.1.0.81 netmask 255.255.0.0 broadcast 10.1.255.255
device interrupt 84
eth0.200: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 10.42.0.28 netmask 255.255.255.0 broadcast 10.42.0.255
RX packets 251 bytes 24000 (24.0 KB)
TX packets 230 bytes 55190 (55.1 KB)
hv0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.12.4 netmask 255.255.255.0 broadcast 192.168.12.255
inet6 fe80::886:4cff:fef8:e900 prefixlen 64 scopeid 0x20
ether 0a:86:4c:f8:e9:00 txqueuelen 1000 (Ethernet)
TX packets 58 bytes 7025 (7.0 KB)
device interrupt 20
