Software Version
[*] DRIVE OS 6.0.10.0
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
[*] Linux
QNX
other
Hardware Platform
[*] DRIVE AGX Orin Developer Kit (940-63710-0010-300)
other
SDK Manager Version
2.1.0
other
Host Machine Version
[*] native Ubuntu Linux 20.04 Host installed with DRIVE OS Docker Containers
other
Issue Description
why does the latest driveworks even doesn’t support the device? protocol specifies a device id to be 0x22, while VeloView, webinterface and wireshark can evidence the presence on the Lidar on network.
Ive got both VELO_VLP16 and VELO_VPL16HR, why such discrepancy?
Error String
root@6.0.10.0-0009-build-linux-sdk:/usr/local/driveworks/bin# ./sample_lidar_replay --protocol=lidar.socket --params=device=VELO_VLP16HR,ip=192.168.2.202,port=2368,scan-frequency=10,decoder-path=./libsample_nv_lidar_plugin.so --show-intensity=true
ProgramArguments: Missing argument 'dwTracePath' requested
System has not been booted with systemd as init system (PID 1). Can't operate.
Failed to create bus connection: Host is down
Starting my sample application...
[16-05-2025 15:57:30] Platform: Detected Generic x86 Platform
[16-05-2025 15:57:30] Adding variable DW_Base:DW_Version
[16-05-2025 15:57:30] Added variable DW_Base:DW_Version
[16-05-2025 15:57:30] Platform: number of GPU devices detected 1
[16-05-2025 15:57:30] Platform: currently selected GPU device 0, Resource Data Dir: trt_08_06_12_04, Arch: ga1xx-discrete
[16-05-2025 15:57:30] Platform: currently selected GPU device discrete ID 0
[16-05-2025 15:57:30] Context::mountResourceCandidateDataPath resource FAILED to mount from './resources': VirtualFileSystem: Failed to mount './resources/resources.pak'
[16-05-2025 15:57:30] Context::mountResourceCandidateDataPath resource FAILED to mount from '/usr/local/driveworks-5.20/bin/data': VirtualFileSystem: Failed to mount '/usr/local/driveworks-5.20/bin/data/resources.pak'
[16-05-2025 15:57:30] Context::findDataRootInPathWalk data/DATA_ROOT found at: /usr/local/driveworks-5.20/bin/../data
[16-05-2025 15:57:30] Context::mountResourceCandidateDataPath resource FAILED to mount from '/usr/local/driveworks-5.20/bin/../data': VirtualFileSystem: Failed to mount '/usr/local/driveworks-5.20/bin/../data/resources.pak'
[16-05-2025 15:57:30] Context::findDataRootInPathWalk data/DATA_ROOT found at: /usr/local/driveworks-5.20/data
[16-05-2025 15:57:30] Context::mountResourceCandidateDataPath resource FAILED to mount from '/usr/local/driveworks-5.20/data': VirtualFileSystem: Failed to mount '/usr/local/driveworks-5.20/data/resources.pak'
[16-05-2025 15:57:30] Context::findResourcesPackageInPathWalk: Could not find ./resources/resources.pak in upto 7 parent directories from /usr/local/driveworks-5.20/bin/../lib/libdw_base.so.5.20
[16-05-2025 15:57:30] Context::findResourcesPackageInPathWalk: Could not find ./resources/resources.pak in upto 7 parent directories from /usr/local/driveworks-5.20/targets/x86_64-Linux/lib/libdw_base.so.5.20
[16-05-2025 15:57:30] SDK: No resources(.pak) mounted, some modules will not function properly
[16-05-2025 15:57:30] [16-05-2025 15:57:30] Initialize DriveWorks SDK v5.20.24
[16-05-2025 15:57:30] [16-05-2025 15:57:30] Release build with GNU 9.3.0 from buildbrain-branch-0-gb4c0b405b15
[16-05-2025 15:57:30] SensorFactory::loadPluginLibraryHelper:Succeed to load dynamic lib - /usr/local/driveworks-5.20/bin/../lib/libsensor_plugin_public_radar.so
[16-05-2025 15:57:30] SensorFactory::createSensor() -> lidar.socket, device=VELO_VLP16HR,ip=192.168.2.202,port=2368,scan-frequency=10,decoder-path=./libsample_nv_lidar_plugin.so
[16-05-2025 15:57:30] Found driver: lidar.socket
[16-05-2025 15:57:30] LidarSocket::getParameters, return-mode not specified. Using default value 2
[16-05-2025 15:57:30] hfov-start is empty, default value 0 will be used
[16-05-2025 15:57:30] hfov-end is empty, default value 360 will be used
[16-05-2025 15:57:30] Destination IP address, Horizontal Resolution is used only by OUSTER and Hesai Lidars
[16-05-2025 15:57:30] Return Mode is used only by Velodyne and Hesai Lidars
[16-05-2025 15:57:30] Horizontal FOV is used only by Ouster, Velodyne and Hesai Lidars
[16-05-2025 15:57:30] Driveworks exception thrown: DW_FAILURE: DecoderVelodyne::processStatus, device type does not match product ID 0x22
terminate called after throwing an instance of 'std::runtime_error'
what(): [2025-05-16 15:57:30] DW Error DW_FAILURE executing DW function:
dwSAL_createSensor(&m_lidarSensor, params, m_sal)
at samples/sensors/lidar/lidar_replay/main.cpp:149
Aborted (core dumped)
I found similar query threads Lidar Connection to Nvidia Drive AGX - #13 by hitesh.pandya1
any status on this yet? : Cannot record LiDAR(VLP16-HiRes) - device type does not match product ID 0x22 - #8 by SivaRamaKrishnaNV
