@parance it seems like an odd behavior and if it’s a bug, it’s a big one. a few questions that i’d like to inquire (some may be irrelevant to the cause):
- is there any additional context you can provide? for example, do you recall saving after a specific operation or anything in particular that could allow devs to repro?
- are you experiencing the same occurrences across multiple OV apps or only a specific app? If so, which apps and what versions are you using?
- have you tried using Save-as instead (then overwrite the file) to see if the problem persists?
- are you using any connectors or third party extensions in your workflow?
- when you said “none of the things i’ve worked on are there”, are you implying the stage is completely wiped or only the work from the most recent session didn’t get implemented? my understanding per this explanation is checkpoints don’t always make a copy of the file but could be metadata with reference points. not sure if what you were seeing upon opening the checkpoints could be a reflection of this?
- are all of your files saved on the Nucleus?
