Scattering 20,000 grass instances (without collision check) is not possible
Isaac Sim Version
4.0.0
Operating System
Windows 11
GPU Information
  • Model: RTX 4090 Laptop
  • Driver Version: 566.36
Steps to Reproduce
  1. scatter 20,000 instances of a small mesh using a scatter node
Screenshots or Videos
Topic Description
When i start my simulation, I scatter small patches of grass. Until now, I scattered 2000 instances.
If I increase the number of instances to 20000, the editor frizes.
this is how I initialize my scatter graph:
def init_graph(self, surface_prims_path, rand_usd_paths):
        self.graph = og.Controller.create_graph(
            graph_id = {
                "graph_path" : f"/Graphs/ScatterGraphs/grass_Graph",
                "fc_backing_type" : og.GraphBackingType.GRAPH_BACKING_TYPE_FABRIC_WITHOUT_HISTORY,
                "pipeline_stage" : og.GraphPipelineStage.GRAPH_PIPELINE_STAGE_ONDEMAND
        keys = og.Controller.Keys
        _, _, _, nodes = og.Controller.edit(
            self.graph,
                keys.CREATE_NODES: [
                    ("OgnScatter2D", "omni.replicator.core.OgnScatter2D"),
                    ("OgnSamplePopulation", "omni.replicator.core.OgnSamplePopulation"),
                    ("OgnCount1", "omni.replicator.core.OgnCount"),
                    ("OgnCount2", "omni.replicator.core.OgnCount"),
                    ("OgnSampleUniform", "omni.replicator.core.OgnSampleUniform"),
                    ("PerAxisPose", "omni.replicator.core.OgnPerAxisPose"),
                    ("OgnWritePrimAttribute", "omni.replicator.core.OgnWritePrimAttribute"),
                keys.CONNECT: [
                    ("OgnSamplePopulation.outputs:prims", "OgnCount1.inputs:prims"),
                    ("OgnCount1.outputs:count", "OgnSampleUniform.inputs:numSamples"),
                    ("OgnSampleUniform.outputs:samples", "PerAxisPose.inputs:fullValues"),
                    ("OgnSamplePopulation.outputs:prims", "OgnCount2.inputs:prims"),
                    ("OgnCount2.outputs:count", "PerAxisPose.inputs:numSamples"),
                    ("OgnSamplePopulation.outputs:prims", "PerAxisPose.inputs:prims"),
                    ("PerAxisPose.outputs:samples", "OgnWritePrimAttribute.inputs:values"),
                    ("OgnSamplePopulation.outputs:prims", "OgnWritePrimAttribute.inputs:prims"),
                    ("OgnSamplePopulation.outputs:exec", "OgnScatter2D.inputs:execIn"),
                    ("OgnSamplePopulation.outputs:exec", "PerAxisPose.inputs:exec"),
                    ("PerAxisPose.outputs:exec", "OgnWritePrimAttribute.inputs:execIn"),
                    ("OgnSamplePopulation.outputs:prims", "OgnScatter2D.inputs:prims"),
                keys.SET_VALUES: [
                    ("OgnSamplePopulation.inputs:paths", rand_usd_paths),
                    ("OgnSamplePopulation.inputs:mode", 'scene_instance'),
                    ("OgnSamplePopulation.inputs:useCache", False),
                    ("OgnSamplePopulation.inputs:withReplacements", False),
                    ("OgnSamplePopulation.inputs:populationName", f"{self.assets_name}_ScatterPopulation"),
                    ("OgnCount1.inputs:mode", 'prims'),
                    ("OgnSampleUniform.inputs:lower", [0,0,0]),
                    ("OgnSampleUniform.inputs:upper", [0,0,180]),
                    ("OgnSampleUniform.inputs:outputType", "float3[]"),
                    ("OgnCount2.inputs:mode", 'prims'),
                    ("PerAxisPose.inputs:mode", "rotation"),
                    ("OgnWritePrimAttribute.inputs:attribute", "xformOp:rotateXYZ"),
                    ("OgnWritePrimAttribute.inputs:attributeType", "double3"),
                    #("OgnScatter2D.inputs:surfacePrims", plane_path),
                    ("OgnScatter2D.inputs:checkForCollisions", False),
                    ("OgnScatter2D.inputs:seed", self.seed),
what am i doing wrong? how is it possible to scatter many meshes in Isaac Sim?
Could you test version 4.2.0? If the issue persists, do you notice any suspicious messages? Please share the complete code for easier reproduction.
@VickNV Thank you for your responce.
here is a simple test case:
  1. create an empty stage with a plane mesh.
  2. download the attacked usd file (this is a patch of grass)
    Collected_Bunch of Grass1.zip (2.7 MB)
  3. past this code in the script editor:
grass_usd = "<path to where the downloaded grass usd is>"
plane_path = "/World/Plane"
plane_prim = rep.get.prim_at_path(plane_path)
grass = rep.randomizer.instantiate(paths = grass_usd, size = 10000, use_cache = False)
rep.randomizer.scatter_2d(input_prims = grass, surface_prims = plane_prim)
  1. press “Run”
For this simple test case, it has been running for the last 20 minutes and the editor is still stuck (waiting for the scattering to complete).
BTW, I see that my system is not being fully utilized:
any idea on how I can better utilize my CPU and/or GPU to lower the time it takes to scatter?
Thank you
I have set the omniverse kit preffered processor to the RTX4090:
still, I see that while the editor is frozen (from attampting to scatter10000 instances) that only the CPU is utilized.
Updating from isaac sim 4.0.0 to isacc sim 4.2.0 has reduced the scatter time from 28 minutes to 12 minutes (for 10000 instances).
If i try to drag the instances (to change it’s position):
I see in the performance tab in the task manager that only the CPU is doing the work.
Hi @VickNV,
still hoping for some help on how to utilize the GPU. Thank you
