Hello fellows
My screen is tearing in every application after a fresh Arch Linux installation
The driver was installed via:
▶ sudo pacman -S nvidia-open-dkms
Sway was run with the following command:
▶ GBM_BACKEND=nvidia-drm __GLX_VENDOR_LIBRARY_NAME=nvidia WLR_NO_HARDWARE_CURSORS=1 sway --unsupported-gpu -d 2> ~/.sway/sway.log
Configuration:
▶ uname -r
6.8.7-arch1-2
▶ nvidia-smi
Sun Apr 28 18:27:17 2024
| NVIDIA-SMI 550.76 Driver Version: 550.76 CUDA Version: 12.4 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA GeForce RTX 3050 On | 00000000:10:00.0 On | N/A |
| 0% 37C P8 8W / 130W | 328MiB / 8192MiB | 5% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 1148 G sway 185MiB |
| 0 N/A N/A 1270 G Xwayland 8MiB |
| 0 N/A N/A 1830 G alacritty 38MiB |
| 0 N/A N/A 4127 G alacritty 40MiB |
| 0 N/A N/A 4742 G /usr/bin/telegram-desktop 1MiB |
▶ sway --version
sway version 1.9
▶ ls /sys/module/nvidia_drm/parameters
fbdev modest
# I tried both configurations for this variable. No difference
▶ sudo cat /sys/module/nvidia_drm/parameters/fbdev
N
▶ sudo cat /sys/module/nvidia_drm/parameters/modeset
Y
nvidia-bug-report.log.gz (429.1 KB)
sway.log.tar.gz (86.3 KB)
