Hi guys,
I am new on Tx2 board. I try to expand the memory using a SD card. But I cannot write any data in it, even create folders. I have tried to format the SD card to different formats, EXT4, exFAT, NTFs. I still fails to write any data into the SD card. I search online. It seems no one had mentioned this issue. Could you give me some help. Appreciate that.
Bests
Xiao
sometimes there is a physical mechanical pin that locks the memory
What is your current way to write data to sdcard?
The write protection should be controlled by your card but not TX2. What carrier board are you using?
I feel like an idiot. Yes, the problem is on the SD card, not on the TX2. Switching the notch to unlock and it works. Thank you guys.
