Hi WayneWWW,
we applied all changes to the Nano but the error still persists.
When changing the test script to test only write processes we get following error after some time:
[ 488.798065] mmcblk1: error -110 requesting status
[ 489.378613] mmc1: tried to reset card, got error -110
[ 489.384033] blk_update_request: I/O error, dev mmcblk1, sector 8193
[ 489.390533] Buffer I/O error on dev mmcblk1p1, logical block 1, lost async page write
[ 489.400480] mmcblk1: error -110 sending status command, retrying
[ 489.407670] mmcblk1: error -110 sending status command, retrying
[ 489.414557] mmcblk1: error -110 sending status command, aborting
[ 489.420764] blk_update_request: I/O error, dev mmcblk1, sector 9650
[ 489.427430] Buffer I/O error on dev mmcblk1p1, logical block 1458, lost async page write
[ 489.438013] mmcblk1: error -110 sending status command, retrying
[ 489.445124] mmcblk1: error -110 sending status command, retrying
[ 489.452530] mmcblk1: error -110 sending status command, aborting
[ 489.459170] blk_update_request: I/O error, dev mmcblk1, sector 13350
[ 489.465950] Buffer I/O error on dev mmcblk1p1, logical block 5158, lost async page write
[ 489.475997] mmcblk1: error -110 sending status command, retrying
[ 489.482967] mmcblk1: error -110 sending status command, retrying
[ 489.489558] mmcblk1: error -110 sending status command, aborting
[ 489.496078] blk_update_request: I/O error, dev mmcblk1, sector 16384
[ 489.502936] Buffer I/O error on dev mmcblk1p1, logical block 8192, lost async page write
And calling umount now leads to:
[ 1186.264797] mmcblk1: error -110 sending status command, retrying
[ 1186.271321] mmcblk1: error -110 sending status command, retrying
[ 1186.278199] mmcblk1: error -110 sending status command, aborting
[ 1186.499591] mmc1: tried to reset card, got error -2
[ 1186.504877] blk_update_request: I/O error, dev mmcblk1, sector 8985
[ 1186.511626] blk_update_request: I/O error, dev mmcblk1, sector 8986
[ 1186.518110] blk_update_request: I/O error, dev mmcblk1, sector 8987
[ 1186.524644] blk_update_request: I/O error, dev mmcblk1, sector 8988
[ 1186.531262] blk_update_request: I/O error, dev mmcblk1, sector 8989
[ 1186.537882] blk_update_request: I/O error, dev mmcblk1, sector 8990
[ 1186.544607] blk_update_request: I/O error, dev mmcblk1, sector 8991
[ 1186.551275] blk_update_request: I/O error, dev mmcblk1, sector 8992
[ 1186.557886] blk_update_request: I/O error, dev mmcblk1, sector 8993
[ 1186.564387] blk_update_request: I/O error, dev mmcblk1, sector 8994
[ 1186.573482] mmcblk1: error -110 sending status command, retrying
[ 1186.581017] mmcblk1: error -110 sending status command, retrying
[ 1186.588416] mmcblk1: error -110 sending status command, aborting
[ 1186.604261] mmcblk1: error -110 sending status command, retrying
[ 1186.610768] mmcblk1: error -110 sending status command, retrying
[ 1186.617396] mmcblk1: error -110 sending status command, aborting
[ 1186.629629] mmcblk1: error -110 sending status command, retrying
[ 1186.636213] mmcblk1: error -110 sending status command, retrying
[ 1186.642676] mmcblk1: error -110 sending status command, aborting
[ 1186.648819] FAT-fs (mmcblk1p1): FAT read failed (blocknr 793)
But the card is still visible at /dev/mmcblk1. I’m not sure but before the patches the card was not listed at /dev when the errors happened.
Is the patch from Jetson Nano SD card enters back to high speed mode instead of uhs mode after soft reboot - #4 by WayneWWW also applicable for Xavier NX?
