I have noticed that unless the width is a multiple of 160,
I get different flows for the same input.
Is this indeed so?
Is it different with SDK 2.0?
Ilan
Is this indeed so?
Ilan
Hi.
Can you reconfirm the observation is related to ‘width is a multiple of 160’ or setting of ‘disableTemporalHints’ in the application?
Yes I do.
When I run the application( as an outside utility) on an image with a width multiple of 160 I get the exact same results.
However, when the width is not a multiple of 160, but say a multiple of 80, like width 240, I get different results.
For example, I run the application, and store the results.
Then I recompile the code, or add some GPU computation so as to change the GPU memory. Then, I get different results.
Let me note that this does not happen with the height parameter.
Whenever it is a multiple of 4 it works fine.
I am referring to the sample SDK code.
Best Ilan
