I’m running 10.6.1 on a MacBook Pro, GeForce 9400M and 9600GT, w/ CUDA 2.3.1a installed as tmurray had described in another post. I have installed, removed, and reinstalled the driver, toolkit, and SDK, in that order, and toolkit, driver, SDK, in that order (also as suggested in another post). However, when I try to run the deviceQuery to verify that my GPU is being seen, in /Developer/GPU Computing/C/bin/darwin/release, the Developer/GPU Computing/C/bin/ directory is empty each time! If somebody could help me out with this it would be greatly appreciated!
I think you just need to type “make i386=1 x86_64=0” in /Developer/GPU Computing/C to get the CUDA utilities & examples.
That did the trick! Much appreciated!
Hmm, feeling a little slow here.
I have installed everything in order, and changed the 2 environment variables, but still no luck.
My error is similar, no devicequery binary. (error below when running the make recommended above)
Also, my
/Developer/GPU Computing/lib
is empty. (No “libcutil.a”).
I’m running Macos 10.5.8.
Thanks for any help!!
$ make
make -C src/3DFD/
make -C src/alignedTypes/
make -C src/asyncAPI/
make -C src/bandwidthTest/
make -C src/bicubicTexture/
make -C src/binomialOptions/
make -C src/BlackScholes/
make -C src/boxFilter/
make -C src/clock/
make -C src/convolutionFFT2D/
make -C src/convolutionSeparable/
make -C src/convolutionTexture/
make -C src/cppIntegration/
make -C src/dct8x8/
make -C src/deviceQuery/
make -C src/deviceQueryDrv/
ld: library not found for -lcuda
collect2: ld returned 1 exit status
make[1]: *** […/…/bin/darwin/release/deviceQueryDrv] Error 1
make: *** [src/deviceQueryDrv/Makefile.ph_build] Error 2
Got it, somehow the driver wasn’t installed!
