Hi, I am using this command to install JetPack 5.0.2 on a Xavier NX Dev Kit:
docker run -it sdkmanager --cli --action install --login-type devzone --product Jetson --target-os Linux --version Runtime_5.0.2 --host --target JETSON_XAVIER_NX_TARGETS --flash --license accept --archived-versions true --stay-logged-in true
It fails:
===== INSTALLATION FAILED =====
- CUDA on Host: Up-to-date
- CUDA Cross Compile Package on Host: Up-to-date
- NvSci: Up-to-date
- VPI on Host: Up-to-date
- Nsight Systems: Up-to-date
- Nsight Graphics: Up-to-date
- Nsight Compute: Up-to-date
- CUPTI: Up-to-date
- Compute Sanitizer: Up-to-date
- Drivers for Jetson: Failed
- File System and OS: DependencyFailure
- Flash Jetson Xavier NX: DependencyFailure
- DateTime Target Setup: DependencyFailure
- CUDA Runtime: DependencyFailure
- CuDNN Runtime: DependencyFailure
- TensorRT Runtime: DependencyFailure
- OpenCV Runtime: DependencyFailure
- VPI Runtime: DependencyFailure
- NVIDIA Container Runtime with Docker integration (Beta): DependencyFailure
- Multimedia API: DependencyFailure
- BSP Patch: DependencyFailure
===== Installation failed - Total 21 components =====
===== 0 succeeded, 1 failed, 9 up-to-date, 11 skipped =====
The only error I see in the log is this:
unzip: command not found
I suppose one fix is to install unzip into the docker image, I’ll try that.
Thanks,
/Clyde
