Jetpack 4.6.1 install broken
We run $ docker run -it --rm --privileged -v /dev/bus/usb:/dev/bus/usb/ --name JetPack_TX2_Devkit sdkmanager --cli install --logintype devzone --product Jetson --target P2888-0001 --targetos Linux --version 4.6.1 --select 'Jetson OS' --deselect 'Jetson SDK Components' --flash all --license accept --staylogin true --datacollection disable --exitonfinish. It downloads, but when installing it suddenly fails:
No update is available.
To initiate login process open https://static-login.nvidia.com/service/default  ===== FLASHING FAILED =====
      - Drivers for Jetson: Installed
      - File System and OS: Installed
      - Flash Jetson AGX Xavier: Failed
  ===== Flashing failed - Total 3 components =====
  ===== 2 succeeded, 1 failed, 0 up-to-date, 0 skipped =====
In the end after 4 tries, one succeed.
Glad to know the installation successly, sometimes that might be network or USB cable issue.
