Hi, just got my devkit.
While installing the tools, SDK manager informs me I lack permissions or memberships. What is needed to resolve this?
Hi frank_motta,
Are you following the instruction to setup your environment?
See more info at https://developer.nvidia.com/nvidia-sdk-manager
Note: The login has two choices. One is for commercial partners (e.g., including automotive products), and the other is one is just a “developer” (someone with a Jetson would use this). There is a drop-down menu to select which you are trying to log in to. The “developer” one is mentioned as being valid, and I suppose it might say that if you accidentally tried to log in to the “partners” instead. Some of the drop downs and other GUI elements are not always obvious as being selectable.
