• Hardware Platform (Jetson Orin NX) • DeepStream Version 7 • JetPack Version (valid for Jetson only)
I am running AINVR app with deepstream and sdr using kubernetes, when i use host network i get no problem because sdr i trying to connect to VST using localhost, but when i provide the service name for VST, it doesn’t even take it into consideration.
Here’s where i provide the service name in the env variables:
Can you share more on the architecture of your deployment? Do you mean the VST located in another device and SDR need access the VST_ENDPOINT in another device with IP? Please have a try with: VST_STREAMS_ENDPOINT.
