Hi NV Team,
Since our device can only log in to the system through ssh,
How to flash secure-os image?
BSP R35.3.1
Hi NV Team,
BSP R35.3.1
hello future.wang,
did you meant a partition update?
you may refer to Preparing the OTA Payload Package section to create the OTA payload package for updating Bootloader only.
Hi Jerry,
I searched and found the following conversation:
Can I use the dd command to flash secure-os?
Hi Jerry,
I just need to re-flash:tos-optee_t194.img.
hello future.wang,
did you have Jetson security enabled? for instance, burning fuse variables, PCK, SBK…etc
please check partition labels with… $ ls -al /dev/disk/by-partlabel/
Hi Jerry,
Not enabling security
total 0
drwxr-xr-x 2 root root 920 Mar 15 2023 .
drwxr-xr-x 8 root root 160 Mar 15 2023 ..
lrwxrwxrwx 1 root root 15 Mar 15 2023 APP -> ../../mmcblk0p1
lrwxrwxrwx 1 root root 16 Mar 15 2023 RECROOTFS -> ../../mmcblk0p38
lrwxrwxrwx 1 root root 16 Mar 15 2023 RP1 -> ../../mmcblk0p36
lrwxrwxrwx 1 root root 16 Mar 15 2023 RP2 -> ../../mmcblk0p37
lrwxrwxrwx 1 root root 16 Mar 15 2023 UDA -> ../../mmcblk0p44
lrwxrwxrwx 1 root root 16 Mar 15 2023 adsp-fw -> ../../mmcblk0p12
lrwxrwxrwx 1 root root 16 Mar 15 2023 adsp-fw_b -> ../../mmcblk0p28
lrwxrwxrwx 1 root root 15 Mar 15 2023 bootloader-dtb -> ../../mmcblk0p5
lrwxrwxrwx 1 root root 16 Mar 15 2023 bootloader-dtb_b -> ../../mmcblk0p21
lrwxrwxrwx 1 root root 15 Mar 15 2023 bpmp-fw -> ../../mmcblk0p8
lrwxrwxrwx 1 root root 15 Mar 15 2023 bpmp-fw-dtb -> ../../mmcblk0p9
lrwxrwxrwx 1 root root 16 Mar 15 2023 bpmp-fw-dtb_b -> ../../mmcblk0p25
lrwxrwxrwx 1 root root 16 Mar 15 2023 bpmp-fw_b -> ../../mmcblk0p24
lrwxrwxrwx 1 root root 15 Mar 15 2023 cpu-bootloader -> ../../mmcblk0p4
lrwxrwxrwx 1 root root 16 Mar 15 2023 cpu-bootloader_b -> ../../mmcblk0p20
lrwxrwxrwx 1 root root 15 Mar 15 2023 eks -> ../../mmcblk0p7
lrwxrwxrwx 1 root root 16 Mar 15 2023 eks_b -> ../../mmcblk0p23
lrwxrwxrwx 1 root root 16 Mar 15 2023 esp -> ../../mmcblk0p40
lrwxrwxrwx 1 root root 16 Mar 15 2023 esp_alt -> ../../mmcblk0p43
lrwxrwxrwx 1 root root 16 Mar 15 2023 kernel -> ../../mmcblk0p15
lrwxrwxrwx 1 root root 16 Mar 15 2023 kernel-dtb -> ../../mmcblk0p16
lrwxrwxrwx 1 root root 16 Mar 15 2023 kernel-dtb_b -> ../../mmcblk0p32
lrwxrwxrwx 1 root root 16 Mar 15 2023 kernel_b -> ../../mmcblk0p31
lrwxrwxrwx 1 root root 15 Mar 15 2023 mts-mce -> ../../mmcblk0p2
lrwxrwxrwx 1 root root 16 Mar 15 2023 mts-mce_b -> ../../mmcblk0p18
lrwxrwxrwx 1 root root 15 Mar 15 2023 mts-proper -> ../../mmcblk0p3
lrwxrwxrwx 1 root root 16 Mar 15 2023 mts-proper_b -> ../../mmcblk0p19
lrwxrwxrwx 1 root root 16 Mar 15 2023 rce-fw -> ../../mmcblk0p11
lrwxrwxrwx 1 root root 16 Mar 15 2023 rce-fw_b -> ../../mmcblk0p27
lrwxrwxrwx 1 root root 16 Mar 15 2023 recovery -> ../../mmcblk0p34
lrwxrwxrwx 1 root root 16 Mar 15 2023 recovery-dtb -> ../../mmcblk0p35
lrwxrwxrwx 1 root root 16 Mar 15 2023 recovery-dtb_alt -> ../../mmcblk0p42
lrwxrwxrwx 1 root root 16 Mar 15 2023 recovery_alt -> ../../mmcblk0p41
lrwxrwxrwx 1 root root 16 Mar 15 2023 reserved_for_chain_A_user -> ../../mmcblk0p17
lrwxrwxrwx 1 root root 16 Mar 15 2023 reserved_for_chain_B_user -> ../../mmcblk0p33
lrwxrwxrwx 1 root root 16 Mar 15 2023 sc7 -> ../../mmcblk0p14
lrwxrwxrwx 1 root root 16 Mar 15 2023 sc7_b -> ../../mmcblk0p30
lrwxrwxrwx 1 root root 16 Mar 15 2023 sce-fw -> ../../mmcblk0p13
lrwxrwxrwx 1 root root 16 Mar 15 2023 sce-fw_b -> ../../mmcblk0p29
lrwxrwxrwx 1 root root 15 Mar 15 2023 secure-os -> ../../mmcblk0p6
lrwxrwxrwx 1 root root 16 Mar 15 2023 secure-os_b -> ../../mmcblk0p22
lrwxrwxrwx 1 root root 16 Mar 15 2023 uefi_variables -> ../../mmcblk0p39
lrwxrwxrwx 1 root root 16 Mar 15 2023 xusb-fw -> ../../mmcblk0p10
lrwxrwxrwx 1 root root 16 Mar 15 2023 xusb-fw_b -> ../../mmcblk0p26
hello future.wang,
yes, it should works.
you need to create sign/encrypt binary file locally, it’s able to created by flash script.
$ sudo ./flash.sh --no-flash -r -k secure-os jetson-agx-xavier-devkit mmcblk0p1
for instance,
[ 0.1456 ] Signed file: /home/jerry/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/tos-optee_t194_sigheader.img.encrypt
after that,
please using scp to copy the sign/encrypt binary file to your target, and running with dd commands to update secure-os partition.
for example,
$ sudo dd if=tos-optee_t194_sigheader.img.encrypt of=/dev/mmcblk0p6 bs=1M
it’ll take effect after warm reboot, i.e. $ sudo reboot
Hi Jerry,
The flshing was successful.
Very detailed, thank you very much!
