Segment fault on V100
• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 7.0
• TensorRT Version 8.6
• NVIDIA GPU Driver Version (valid for GPU only) 535.161.08
There is error when I run deepstream7.0 on V100 in docker.
Why this issue appear?
1.Driver errors, usually caused by incorrect installation.
Please check whether nvidia-container-toolkit and GPU driver have been installed correctly.
v100 has been tested and is working properly
  1. How do you start docker?
    Please try the following command line first.
docker run --gpus all -it --rm --net=host --privileged -v /tmp/.X11-unix:/tmp/.X11-unix -e DISPLAY=$DISPLAY -w /opt/nvidia/deepstream/deepstream-7.0 deepstream:7.0-triton-multiarch
3.Can deepstream-app or other samples reproduce the problem?
Thank you.
I have already test it.
