Hi
I try to get raw data from NvMediaImage with function NvMediaImageGetBits.But I got a Segmentation fault when run the code.
I add my codo into sample application img_cc.I add function NvMediaImageGetBits in save.c
Here is the code
static NvU32
_SaveThreadFunc(void *data)
SaveThreadCtx *threadCtx = (SaveThreadCtx *)data;
NvMediaImage *image = NULL;
[b] NvU8 *pSrcBuff = NULL;
NvU32 srcPitch = 2;
NvMediaImageSurfaceMap surfaceMap;[/b]
NvMediaImage *convertedImage = NULL;
NvMediaStatus status;
NvU32 totalSavedFrames=0;
char outputFileName[MAX_STRING_SIZE];
char buf[MAX_STRING_SIZE] = {0};
char *calSettings = NULL;
NVM_SURF_FMT_DEFINE_ATTR(attr);
while (!(*threadCtx->quit)) {
image=NULL;
/* Wait for captured frames */
while (NvQueueGet(threadCtx->inputQueue, &image, SAVE_DEQUEUE_TIMEOUT) !=
NVMEDIA_STATUS_OK) {
LOG_DBG("%s: saveThread input queue %d is empty\n",
__func__, threadCtx->virtualGroupIndex);
if (*threadCtx->quit)
goto loop_done;
if (threadCtx->saveEnabled) {
if (*threadCtx->numRtSettings) {
calSettings = threadCtx->rtSettings[_GetSettingNum(threadCtx->rtSettings,
*threadCtx->numRtSettings,
totalSavedFrames)
].outputFileName;
} else if (threadCtx->sensorInfo) {
memset(buf, 0 , MAX_STRING_SIZE);
status = threadCtx->sensorInfo->AppendOutputFilename(buf,
threadCtx->sensorProperties);
if (status != NVMEDIA_STATUS_OK) {
LOG_ERR("%s: Failed to append output filename\n", __func__);
*threadCtx->quit = NVMEDIA_TRUE;
goto loop_done;
calSettings = buf;
} else {
calSettings = NULL;
/* Save image to file */
_CreateOutputFileName(threadCtx->saveFilePrefix,
calSettings,
threadCtx->virtualGroupIndex,
totalSavedFrames,
threadCtx->useNvRawFormat,
outputFileName);
LOG_INFO("%s: Write image. res [%u:%u] (file: %s)\n",
__func__, image->width, image->height,
outputFileName);
if (threadCtx->useNvRawFormat) {
status = NvMediaSurfaceFormatGetAttrs(threadCtx->surfType,
attr,
NVM_SURF_FMT_ATTR_MAX);
LOG_ERR("%s:NvMediaSurfaceFormatGetAttrs failed\n", __func__);
goto loop_done;
if (threadCtx->sensorInfo && (attr[NVM_SURF_ATTR_SURF_TYPE].value == NVM_SURF_ATTR_SURF_TYPE_RAW)) {
threadCtx->sensorInfo->WriteNvRawImage(&threadCtx->settingsCommands,
threadCtx->calParams,
image,
totalSavedFrames,
outputFileName);
} else {
LOG_ERR("%s: NvRawFormat applicable only for RAW captured image \n", __func__);
goto loop_done;
} else {
WriteImage(outputFileName,
image,
NVMEDIA_TRUE,
NVMEDIA_FALSE,
threadCtx->rawBytesPerPixel);
[b] if (NvMediaImageLock(image, NVMEDIA_IMAGE_ACCESS_WRITE, &surfaceMap) !=
LOG_ERR("%s: NvMediaImageLock failed\n", __func__);
return NVMEDIA_STATUS_ERROR;
if (!(pSrcBuff = malloc(surfaceMap.height*surfaceMap.width*srcPitch))) {
LOG_ERR("%s: Out of memory\n", __func__);
return NVMEDIA_STATUS_OUT_OF_MEMORY;
status = NvMediaImageGetBits(image, NULL, (void **)&pSrcBuff, &srcPitch);
NvMediaImageUnlock(image);
LOG_ERR("%s: NvMediaImageGetBits() failed\n", __func__);
}[/b]
totalSavedFrames++;
if (threadCtx->displayEnabled) {
attr,
goto loop_done;
if (attr[NVM_SURF_ATTR_SURF_TYPE].value == NVM_SURF_ATTR_SURF_TYPE_RAW) {
/* Acquire image for storing converting images */
while (NvQueueGet(threadCtx->conversionQueue,
(void *)&convertedImage,
SAVE_DEQUEUE_TIMEOUT) != NVMEDIA_STATUS_OK) {
LOG_ERR("%s: conversionQueue is empty\n", __func__);
goto loop_done;
status = _ConvRawToRgba(image,
convertedImage,
threadCtx->rawBytesPerPixel,
threadCtx->pixelOrder);
LOG_ERR("%s: convRawToRgba failed for image %d in saveThread %d\n",
__func__, totalSavedFrames, threadCtx->virtualGroupIndex);
goto loop_done;
while (NvQueuePut(threadCtx->outputQueue,
&convertedImage,
SAVE_ENQUEUE_TIMEOUT) != NVMEDIA_STATUS_OK) {
LOG_DBG("%s: savethread output queue %d is full\n",
goto loop_done;
} else {
&image,
goto loop_done;
image=NULL;
if (threadCtx->numFramesToSave &&
(totalSavedFrames == threadCtx->numFramesToSave)) {
goto loop_done;
loop_done:
if (image) {
if (NvQueuePut((NvQueue *)image->tag,
(void *)&image,
0) != NVMEDIA_STATUS_OK) {
LOG_ERR("%s: Failed to put image back in queue\n", __func__);
image = NULL;
if (convertedImage) {
if (NvQueuePut((NvQueue *)convertedImage->tag,
LOG_ERR("%s: Failed to put image back in conversionQueue\n", __func__);
LOG_INFO("%s: Save thread exited\n", __func__);
threadCtx->exitedFlag = NVMEDIA_TRUE;
return NVMEDIA_STATUS_OK;
When exec the NvMediaImageGetBits function,it will Segmentation fault.
the gdb dump
[Thread 0x7fb57e3200 (LWP 4496) exited]
Thread 4 "nvmimg_cc" received signal SIGSEGV, Segmentation fault.
0x0000007fb7f75f84 in ?? () from /usr/lib/libnvmedia.so
Could you kindly tell me how to solve this problem?
