A2F runs in headless mode. I have successfully implemented live face animation in UE by calling /A2F/Player/SetTrack API to supply the audio piece by piece.
/A2F/Player/SetTrack API accepts a path to an audio file(*.wav) in local filesystem. This means that A2F cannot be deployed remotely. I intend to deploy A2F in Linux docker container accessed remotely. Hence I need a way to send audio stream(PCM samples) to A2F.
I think this is doable because A2F can accept input from microphone (but not running in headless mode).
So, my question is – is there some TCP port I can stream audio to A2F?
