Could we live stream two videos over WiFi from an AGX to NX simultaneously (two USB cameras connected to AGX, reading them through openCV, and sending over WiFi, to be received by NX). Which method could give us minimum latency. Are there some examples that we could look into. If this is possible, could we send the videos pear to pear (directly from AGX to NX, maybe also using a second Wi-Fi adaptor on each) not using a router.
General usecases are to use UDP or RTSP. Please refer to
Jetson Nano FAQ
Q: Is there any example of running RTSP streaming?
Jetson 4k Encoding -> Decoding Pipeline and latency - #11 by DaneLLL
Delay in video - #5 by DaneLLL
Yo may try the two cases and pick one fitting your usecase.
Hi @DaneLLL,
Many thanks
./test-launch āvideotestsrc ! nvvidconv ! nvv4l2h264enc ! h264parse ! rtph264pay name=pay0 pt=96ā
works as expected.
when I have a Econsytems See3Cam_130 connected as video0 source:
./test-launch ādevice=/dev/video0 ! nvvidconv ! nvv4l2h264enc ! h264parse ! rtph264pay name=pay0 pt=96ā
works as well
But
./test-launch āv4l2src device=/dev/video0 ! video/x-raw,format=UYVY,width=1280,height=720,framerate=30 ! omxh264enc ! rtph264pay name=pay0 pt=96ā
doesnāt work. Camera turns-on very briefly and turns off again, and receiving side says āunable to openā
And if I wanted to stream two USB cameras at the same time, should I modify the Test_launch to add another port maybe?
Could you help
Best,
Sefa
Since your camera outputs UYVY format, you need to convert it to NV12 through nvvidconv:
v4l2src device=/dev/video0 ! video/x-raw,format=UYVY,width=1280,height=720,framerate=30 ! nvvidconv ! nvv4l2h264enc ! h264parse ! rtph264pay name=pay0 pt=96
You can check if the pipeline is valid through gst-launch-1.0 command and then apply it to test-launch:
gst-launch-1.0 v4l2src device=/dev/video0 ! video/x-raw,format=UYVY,width=1280,height=720,framerate=30 ! nvvidconv ! nvv4l2h264enc ! h264parse ! rtph264pay name=pay0 pt=96 ! fakesink
I receive this message when I try to check the pipeline:
WARNING: erroneous pipeline: could not link v4l2src0 to nvvconv0, neither element can handle caps video/x-raw, format=(string)UYVY, width=(int)1280, height=(int)720, framerate=(int)30
Edit1:removing the frame rate, check is OK
This is the message when I stream it, after I try to connect to stream:
(test-launch:10898): GLib-GObject-WARNING **: 16:29:15.333: invalid cast from āGstV4l2Srcā to āGstBinā
(test-launch:10898): GStreamer-CRITICAL **: 16:29:15.333: gst_bin_get_by_name: assertion āGST_IS_BIN (bin)ā failed
Edit2: I donāt know why double quotes was the issue, changing it to single quotes work
Hi @DaneLLL ,
$ gst-launch-1.0 uridecodebin uri=rtsp://<SERVER_IP_ADDRESS>:8554/test ! nvoverlaysink
opens a full-size window, with no re-sizing option, how can we open a window of certain size, or control the window size or re-size the window at the receiver side
Another Question is:
$ gst-launch-1.0 v4l2src device=/dev/video1 ! video/x-raw,format=YUY2,width=640,height=480,framerate=30/1 ! nvvidconv ! 'video/x-raw(memory:NVMM),format=NV12' ! nvoverlaysink
does not open any video window:
Setting pipeline to PAUSED ā¦
Pipeline is live and does not need PREROLL ā¦
Setting pipeline to PLAYING ā¦
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Internal data stream error.
Additional debug info:
gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
streaming stopped, reason not-negotiated (-4)
Execution ended after 0:00:00.000106629
Setting pipeline to READY ā¦
Setting pipeline to NULL ā¦
Freeing pipeline ā¦
For video scaling, you can utilize nvvidconv plugin. Two reference pipelines:
$ gst-launch-1.0 uridecodebin uri=rtsp://10.19.107.93:8554/test ! nvvidconv ! 'video/x-raw(memory:NVMM),width=640,height=360' ! nvegltransform ! nveglglessink
$ gst-launch-1.0 uridecodebin uri=rtsp://10.19.107.93:8554/test ! nvvidconv ! 'video/x-raw(memory:NVMM),width=640,height=360' ! nvoverlaysink overlay-w=640 overlay-h=360
The v4l2 source may not support YUY2(YUYV) format. You may refer to Jetson Nano FAQ:
Q: I have a USB camera. How can I launch it on Jetson Nano?
