Hii,
I have a MS5611 pressure sensor connected to Jetson nano over i2c port but it’s not showing its address . If connect same sensor to raspberry pi it’s showing its address . If anyone knows why this is happening thn plz help me to solve this problem.
Hi, have you checked the voltage level matching of the I2C port? Is it 1.8V or 3.3V? Which port of nano do you use?
Did you using i2cdetect to scan the bus?
Yes voltage is 3.3v and I’m connecting to pin no.3 and 5
Yes I’m using i2cdetect to scan the bus and it’s not showing its address . But if I use i2cdetect on raspberry pi it’s showing its address and also working
Sorry for the late response, is this still an issue to support? Thanks
