The provided context appears to be a collection of documentation and forum posts related to NVIDIA’s Jetson platform, specifically the Jetson Orin NX and other Jetson modules. The context includes information on how to identify the type of Jetson module using the lsusb command, as well as various discussions and topics related to the Jetson platform, such as thermal management, partition configurations, and device tree bindings.
To answer your question, it seems that you are asking about the getSensorTimestamp function and its output on the Jetson Orin NX platform. The output you provided shows two sets of timestamps, labeled as T1 and T2, as well as a third set of timestamps labeled as T3 in the second output.
Based on the context, it appears that the getSensorTimestamp function is used to retrieve timestamps from sensors on the Jetson platform. The output shows two sets of timestamps, T1 and T2, which seem to be related to the sensor data. The third set of timestamps, T3, is only present in the second output and seems to be related to the SOFT3 sensor.
Without more information about the specific sensor and the context in which the getSensorTimestamp function is being used, it is difficult to provide a more detailed explanation of the output. However, it appears that the function is returning timestamps in a format that includes a large integer value followed by a smaller integer value.
In comparison to other Jetson platforms, the output of the getSensorTimestamp function may vary depending on the specific sensor and platform being used. However, the general format of the output, with two or three sets of timestamps, seems to be consistent across different platforms.
It’s worth noting that the context also includes information on how to obtain the correct compatible string for a Jetson platform, which may be useful for identifying the specific platform and sensor being used. Additionally, the context includes discussions on thermal management and partition configurations, which may be relevant to the use of the getSensorTimestamp function on the Jetson Orin NX platform.
