Serial Mouse can't work on JetPack6
Hi NVIDIA,
I am using a comport mouse connected to a PL2303 USB to comport adapter.
It was working fine with JetPack 5, but after upgrading to JetPack 6, it stopped working.
Here is the command:
sudo inputattach --intellimouse /dev/ttyUSB0
After running the command, I checked the dmesg log, and event9 and mouse1 were created, so I believe the driver is working correctly.
dmesg:
[   64.869820] input: Microsoft MZ Mouse as /devices/platform/bus@0/3610000.usb/usb1/1-2/1-2.1/1-2.1:1.0/ttyUSB0/tty/ttyUSB0/serio0/input/input11
[   64.869889] serio: Serial port ttyUSB0
$ ls /dev/input/
by-id  by-path  event0  event1  event2  event3  event4  event5  event6  event7  event8  event9  mice  mouse0  mouse1
However, the mouse is not responding. Do you have any suggestions?
It should be certain configs are not enabled for the device. Please check deconfig of Jetpack 5 and 6 to identify which configs have to be anbled.
FYR, some examples of kernel customization are listed
Jetson/L4T/r36.3.x patches - eLinux.org
