Jetpack 6
Hardware Platform
SDK Manager Version
2.0
Host Machine Version
native Ubuntu Linux 22.04 Host installed with SDK Manager
After flashing I have noticed the joystick has stopped working with dmesg -w as same as below topic. The joystick rules show in /etc/udev/rules.d/ but ls /dev/input/ only shows event0 till event 5 and by-path but no js0 exists.
[ 110.962170] usb 1-4.3.4: new full-speed USB device number 11 using tegra-xusb
[ 110.989198] usb 1-4.3.4: New USB device found, idVendor=046d, idProduct=c219
[ 110.989207] usb 1-4.3.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 110.989211] usb 1-4.3.4: Product: Logitech Cordless RumblePad 2
[ 110.989215] usb 1-4.3.4: Manufacturer: Logitech
[ 111.039721] input: Logitech Logitech Cordless RumblePad 2 as /devices/3610000.xhci/usb1/1-4/1-4.3/1-4.3.4/1-4.3.4:1.0/0003:046D:C219.0008/input/input9
[ 111.040473] logitech 0003:046D:C219.0008: input,hidraw1: USB HID v1.11 Gamepad [Logitech Logitech Cordless RumblePad 2] on usb-3610000.xhci-4.3.4/input0
[ 111.040516] logitech: probe of 0003:046D:C219.0008 failed with error -1
It should be AGX Orin Developer Kit and please confirm it. We have drive platforms and embedded platforms. Each platform has individual software release.
Yes it is AGX orin developer kit. My bad I can change the topic forum listing topic.
Please check if this config has to be enabled for the device:
No data being updated from Joystick in o/p of $sudo jstest /dev/input/js0 (Solved) - #4 by DaneLLL
@DaneLLL I customized the kernel for RT, appended the line CONFIG_LOGITECH_FF=y to 'Linux_for_Tegra/source/kernel/kernel-jammy-src/arch/arm64/configs/defconfig` but still the joystick does not work, under /pro/config.gz I do not see the configuration
Please check if you can try Jetpack 5.1.3. We have the guidance for kernel customization in
Kernel — NVIDIA Jetson Linux Developer Guide 1 documentation
