Hi our hyper v is saying that we dont have a compatible RDFX card even though we have installed all the necessary roles (as stated here Enabling Physical GPUs in Hyper-V )drivers are present. Any advice ?
Perhaps this card is not compatible with hyper v, we just wanted to test it out as we do have a sucessfull deploy on a different server running the exact same cards .
Running P4 boards on VMs under Hyper-V and Server 2016 just fine. Which GRID driver version are you running? AFAIK, the M60 should be supported. Are you using DDA? You also need its own video board so that the M60 shows up as a second graphics device. Also, did you switch from compute to graphics mode using the gpumodeswitch utility?: gpumodeswitch User Guide :: NVIDIA Virtual GPU Software Documentation
