Set fix joint ,cause the robotic arm not to move
  • Isaac sim 4.5
  • RTX 4060
  • ubuntu22.04
    what should i do when adding fixed joints results in a robotic arm that cannot move the other joints of the robotic arm ,even though it is already integral with the dog?
after setting up the fix joint ,the arm has no more options for joint configuration.
Thank you for reporting this issue. To help us reproduce and investigate the problem with the fixed joint causing your robotic arm to stop moving, could you please provide a minimal example (with the exact steps and any relevant files) that demonstrates the issue?
Hello!
Best regards,
