I would like to set up a static ip in L4T so that when the image is up it already has a static ip of my own. I have tried to find out where it defined. Is the route_localnet.sh is the correct file ? and if so , then do I have to just add ip address or is there more I have to do ?
Please check this and give it a try:
Jetson AGX Orin FAQ
I have seen this FAQ also. But I belive this for JP in the running image means after image is being flashed. I want to add IP address in the image during image build so that after flash it already assigned to the IP address.
@DaneLLL , I have seen this FAQ also. But I belive this for JP in the running image means after image is being flashed. I want to add IP address in the image before image build so that after flash, it already has assigned to the IP address.
A possible solution for this is to have the device being well set and clone out the rootfs. So that you can flash the rootfs to other devices. You may check
@DaneLLL , I will try that. I have tried to add ‘Wired connection 1.nmconnection’ in rootfs in L4T but it does not works, I wonder why !
Using netplan on Ubuntu is supposed to work. If you would like to use other software stack, would see if other users can share experience.
