Use netplan.io apply static ip will cause kernel warning
every time network apply it will print the warning .how to fixed it?
[ 17.269040] ------------[ cut here ]------------
[ 17.269048] Unbalanced IRQ 318 wake disable
[ 17.269063] WARNING: CPU: 4 PID: 366 at kernel/irq/manage.c:915 irq_set_irq_wake+0x16c/0x1c0
[ 17.269084] Modules linked in: nvidia_modeset(O) snd_soc_tegra186_asrc(O) snd_soc_tegra210_mixer(O) snd_soc_tegra186_dspk(O) snd_soc_tegra210_admaif(O) snd_soc_tegra210_mvc(O) snd_soc_tegra210_ope(O) snd_soc_tegra186_arad(O) snd_soc_tegra_pcm snd_soc_tegra210_afc(O) snd_soc_tegra210_adx(O) snd_soc_tegra210_dmic(O) snd_soc_tegra210_sfc(O) snd_soc_tegra210_amx(O) snd_soc_tegra210_i2s(O) tegra210_adma snd_soc_tegra210_ahub(O) spidev tegra_pcie_dma_test(O) tegra_pcie_edma(O) mttcan(O) can_dev tegra_aconnect tegra_cactmon_mc_all(O) snd_hda_codec_hdmi snd_soc_rt5640 snd_soc_rl6231 at24 pwm_tegra_tachometer(O) snd_hda_tegra snd_hda_codec snd_hda_core nvethernet(O) spi_tegra114 mc_hwpm(O) nvpps(O) host1x_fence(O) nvhost_isp5(O) nvhost_vi5(O) nvhost_nvcsi_t194(O) bridge lzo_rle lzo_compress stp llc tegra_camera(O) ramoops zram zsmalloc reed_solomon nvme_fabrics nvvrs_pseq_rtc(O) crct10dif_ce v4l2_dv_timings usb_f_ncm snd_soc_tegra_machine_driver(O) nvhost_nvcsi(O) snd_soc_tegra_utils(O)
[ 17.269190] usb_f_mass_storage snd_soc_simple_card_utils tegra_camera_platform(O) capture_ivc(O) tegra234_oc_event(O) v4l2_fwnode tegra23x_perf_uncore(O) v4l2_async videobuf2_dma_contig videobuf2_memops videobuf2_v4l2 rfkill videobuf2_common governor_userspace videodev nvpmodel_clk_cap(O) tegra_mce(O) nvidia(O) tegra_camera_rtcpu(O) thermal_trip_event(O) mc tegra_drm(O) ivc_bus(O) i2c_nvvrs11(O) lm90 nvidia_vrs_pseq(O) hsp_mailbox_client(O) nvhost_pva(O) nvhost_nvdla(O) ivc_ext(O) tegra_wmark(O) tegra_dce(O) nvhost_capture(O) nvhwpm(O) tegra_se(O) cec host1x_nvhost(O) tsecriscv(O) crypto_engine drm_kms_helper usb_f_acm u_serial usb_f_rndis u_ether libcomposite nvidia_p2p(O) ina3221 nvgpu(O) governor_pod_scaling(O) host1x(O) mc_utils(O) nvmap(O) nvsciipc(O) xdma(OE) txgbe(OE) vxlan ip6_udp_tunnel udp_tunnel marvell fuse drm ip_tables x_tables ipv6 pwm_fan pwm_tegra tegra_bpmp_thermal tegra_xudc ucsi_ccg typec_ucsi typec nvme nvme_core phy_tegra194_p2u pcie_tegra194
[ 17.269323] CPU: 4 PID: 366 Comm: NetworkManager Tainted: G OE 5.15.136-tegra #1
[ 17.269330] Hardware name: NVIDIA NVIDIA Jetson AGX Orin Developer Kit/Jetson, BIOS 202406.0-a9a61c80 06/29/2024
[ 17.269333] pstate: 604000c9 (nZCv daIF +PAN -UAO -TCO -DIT -SSBS BTYPE=–)
[ 17.269339] pc : irq_set_irq_wake+0x16c/0x1c0
[ 17.269344] lr : irq_set_irq_wake+0x16c/0x1c0
[ 17.269348] sp : ffff80000c333b10
[ 17.269349] x29: ffff80000c333b10 x28: ffff00008a941f00 x27: 0000000000000000
[ 17.269357] x26: 0000000000000000 x25: ffff80000c333d10 x24: 0000ffffeb01fd88
[ 17.269363] x23: ffffd554802f4280 x22: 0000000000000000 x21: 000000000000013e
[ 17.269369] x20: 00000000ffffffea x19: ffff00008996c800 x18: ffffffffffffffff
[ 17.269374] x17: 0000000000000000 x16: ffffd5547ea07dd0 x15: ffffd55480298e39
[ 17.269380] x14: ffffffffffffffff x13: ffffd55480298e27 x12: 2d2d2d2d5d206572
[ 17.269386] x11: 656820747563205b x10: ffffd5547febf618 x9 : 000000000000013e
[ 17.269391] x8 : ffff80000c333b10 x7 : 0a656c6261736964 x6 : 696420656b617720
[ 17.269398] x5 : ffff000da3c249f0 x4 : 00000000fffff38c x3 : ffffd5547ff09318
[ 17.269403] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff00008a941f00
[ 17.269409] Call trace:
[ 17.269412] irq_set_irq_wake+0x16c/0x1c0
[ 17.269416] osd_ivc_send_cmd+0xf74/0x15e0 [nvethernet]
[ 17.269437] dev_ethtool+0x5dc/0x23e0
[ 17.269451] dev_ioctl+0x1d8/0x580
[ 17.269460] sock_do_ioctl+0xd0/0x120
[ 17.269468] sock_ioctl+0x2e8/0x4f0
[ 17.269474] __arm64_sys_ioctl+0xbc/0x100
[ 17.269481] invoke_syscall+0x5c/0x150
[ 17.269490] el0_svc_common.constprop.0+0x64/0x120
[ 17.269498] do_el0_svc+0x74/0xb0
[ 17.269505] el0_svc+0x28/0x90
[ 17.269510] el0t_64_sync_handler+0xac/0x130
[ 17.269514] el0t_64_sync+0x1a4/0x1a8
[ 17.269519] —[ end trace be6709f734ed09d7 ]—
[ 19.505757] rfkill: input handler disabled
If you have put the setting in
/etc/netplan/01-network-manager-all.yaml
It shall be applied in booting and no need to manually execute sudo netplan apply in each boot.
For setting static IP, please refer to
Jetson AGX Orin FAQ
Q: How to set up static IP address?
i have put it in /etc/netplan/01-network-manager-all.yaml and i find when booting over it will apply automatically,and will print one time , netplan apply manully is also will print that .
We test on Jetpack 5.1.3 and don’t observe the issue. Please share which Jetpack version you are using.
And please try to configure static IP through Ubuntu GUI of system setting. See if the prints are shown in this method.
Hello,DaneLLL,i am using Jetpack6.0(R36.3).Here is my dmesg info.
dmesg.txt (67.5 KB)
We test AGX Orin developer kit and don’t hit the issue. Please check if you can share the yaml file for reference.
01-network-manager-all.yaml.txt (968 Bytes)
Hi,DaneLLL,this is my yaml file.
