After working under linux and nsight eclipse edition, I have to port some of my code for windows. So I want to test it under visual studio 2008, but I’ve got only the express edition.
Now I want to set up a project template manual on my own, because I don’t want to adjust every program for the cuda requirements.
I can run a cuda programm and build it with vs2008 express, after adjust everything manual.
I know it’s possible to import project templates with the express editions - I testet it with a template for c# and it works.
But I’m not possible to import a template for c++.
This is my .vstemplate file (I extracted it from the cuda toolkit installer .cab files)
<VSTemplate
xmlns="http://schemas.microsoft.com/developer/vstemplate/2005"
Type="Project"
Version="3.0.0">
<TemplateData>
<Name>Cuda 5.0 Runtime Project</Name>
<Description>Creates a cuda runtime project</Description>
<Icon>CudaRuntime5.0</Icon>
<ProjectType>Visual C++</ProjectType>
</TemplateData>
<TemplateContent>
<Project File="CudaRuntimeVS9.0.vcproj" TargetFileName="$safeprojectname$.vcproj" ReplaceParameters="true">
</Project>
<CustomParameters>
<CustomParameter Name="$cudamajorver$" Value="5" />
<CustomParameter Name="$cudaminorver$" Value="0" />
</CustomParameters>
</TemplateContent>
</VSTemplate>
I’ve packed the .vstemplate, .vcproj and the .ico to a zip, copied the zip file to the default project template dir and run VCExpress.exe /installvstemplates.
These three steps work fine with the c# template (it’s not a cuda template and I used VCSExpress.exe of course) but not for c++.
Is there any failure in de .vstemplate or make I anything else wrong?
