The fan curve(s) is set by the vendor in the VBIOS. You can only set it to manual control and then use a fan-control daemon to set up your own fan curve.
Related topics
Any workaround to the 30% fan speed limitation on newer NVIDIA GPUs? | 7 | 10980 | March 22, 2025 | |
Can't control fan speed with beta driver 349.12 | 36 | 28927 | May 19, 2015 | |
Fan Control Issue on Open NVIDIA Driver 570 – Fan Stuck at 30% Under Load (nvidia-ml-py Attempted) | 4 | 463 | February 24, 2025 | |
Diff (Windows/Linux) Target Temperature ---> 87 C -> 80 C [After Reboot] | 2 | 95 | May 18, 2025 | |
RTX 3090 fan 30% limit acts incorrect (too high and hence fan is too loud) | 16 | 771 | April 28, 2025 | |
Nvidia-smi -pl safe throttling limit | 2 | 10 | July 8, 2025 | |
Nitro 5 with Pop - my fans go on at full speed with no reason | 0 | 34 | January 23, 2025 | |
Nvidia-smi -gtt doesn't work 535.104.05 | 17 | 1715 | June 23, 2025 | |
Nvidia-smi GPU target temperature / Maximum Operating Temperature | 4 | 10620 | May 2, 2025 | |
Fan Profile Change | 3 | 25 | July 9, 2025 |
