SFP module compatibility Jetson Thor
We are working on a custom carrier board design where we plan to use two of the MGBE controllers and connect them directly to two separate SFP28 cage connectors. We were wondering what is the MAC behind these XFI interfaces and which are then compatible SFP transceiver modules to use with the Jetson Thor.
Thank you very much,
Ivan
Please refer to Jetson T5000 Series Modules Data Sheet https://developer.nvidia.com/downloads/assets/embedded/secure/jetson/thor/docs/Jetson_T5000_Modules_DS_DS11945001_v1.1.pdf
