Hi all,
We have designed a Thor carrier with just one MGBE UPHY lane broken out into an SFP, instead of an SFP-28. What device tree modifications need to be made to adapt the nvidia QSFP implementation to work with a single SFP? I cannot find where the pin assignments for the QSFP are made in the dts.
Thank you
Any updates on this? I am having a similar issue.
As mentioned in the Jetson Thor Series Modules Interface Design Guide, the MGBE on Jetson Thor supports 2.5, 5, 10, or 25 Gbps. SFP is likely limited to a maximum of 1.25 Gbps and may not work with Jetson Thor’s MGBE. SFP+ supports up to 10 Gbps and should be used instead of SFP.
So far I have been trying to use a 10G SFP28 DAC directly into a 10G capable switch, but I am not seeing any traffic over any of the MGBE interfaces. Are any changes required to the default QSFP setup provided with the Thor developer kit for this? We are not using the same GPIO as were used on the QSFP in the dev kit.
Are you following the Jetson Linux Developer Guide for enabling QSFP and checking for traffic?
Since you did not use the same GPIOs, have you programmed whatever was used accordingly? Is there a particular reason the GPIOs were remapped instead of following the Dev Kit?
The QSFP28 and SFP28 GPIO assignments are not the same - the difference in GPIO functions are shown here. Additionally, we are using 2 SFP28 modules instead of 1 QSFP, so using all of the same GPIOs as the developer kit was not feasible. I was not able to find where nvethernet maps these GPIOs, so I have not be able to reasign them. Setting a static IP (suggested in a different post by I think NV’s Wayne) and forcing the interface up shows a couple of TX packets in ifconfig, but never an actual link. We’re a bit stuck here, do you have any leads on what we should try next?
10G SFP28 with DAC (Direct Attachment Cable) adds additional losses to the system, scaling with the length of the cable. The high losses could be one of the reasons why you are not able to link-up..
Can you try a Fiber transceiver (instead of DAC) for connecting the SFP28 to the 10G capable switch?
Just looking at my Thor and here are somethings that may be relevant.
Jetson Thor Series Modules Pinmux Template
In excel did a search for sfp and got these 4 rows.
Row259 J52 I2C0_CLK GP190_I2C0_CLK GEN0_I2C_SCL unused_GEN0_I2C_SCL GPIO3_PW.04 I2C0_CLK B B I2C0_CLK RSVD1 RSVD2 RSVD3 RSVD1 gen0_i2c_scl_pw4 vddio_gpiob I2C0 GPIOB ST/DD BDGPIOLTL_DFCT6M16L_VD121812NC 20K z GPIO_PW4 NORMAL NORMAL DISABLE 0 TRUE TRUE TRUE TRUE TRUE TRUE VALID GPIO3_PW.04 Output Drive 0 Disable Disable Disable Enable Mid Disable 1k XFI0_RST_N (SOC_QSFP_RESET) BM20
Row260 J53 I2C0_DAT GP191_I2C0_DAT GEN0_I2C_SDA unused_GEN0_I2C_SDA GPIO3_PW.05 I2C0_DAT B B I2C0_DAT RSVD1 RSVD2 RSVD3 RSVD1 gen0_i2c_sda_pw5 vddio_gpiob I2C0 GPIOB ST/DD BDGPIOLTL_DFCT6M16L_VD121812NC 20K z GPIO_PW5 NORMAL TRISTATE ENABLE TRUE TRUE TRUE TRUE TRUE TRUE VALID GPIO3_PW.05 Input Disable Disable Disable Enable Mid Disable 1k XFI0_INT_N (SOC_QSFP_INT) BR20
Row276 H17 GPIO62 GP273 SOC_GPIO273 unused_SOC_GPIO273 GPIO3_PY.03 I2S3_SDATA_OUT B O RSVD0 I2S3_SDATA_OUT RSVD2 RSVD3 RSVD0 soc_gpio273_py3 vddio_gpiod DAP3 GPIOD ST/DD BDGPIOLTL_DFCT6M16L_VD121812NC 20K pd GPIO_PY3 NORMAL TRISTATE ENABLE TRUE TRUE TRUE TRUE TRUE TRUE VALID GPIO3_PY.03 Input Disable Disable Disable Enable Mid Disable 10k SOC_QSFP_RPSNT_N BY12
Row278 GPIO57 GP275 SOC_GPIO275 unused_SOC_GPIO275 GPIO3_PY.05 I2S3_LRCK B B RSVD0 I2S3_LRCK RSVD2 RSVD3 RSVD0 soc_gpio275_py5 vddio_gpiod DAP3 GPIOD ST/DD BDGPIOLTL_DFCT6M16L_VD121812NC 20K pd GPIO_PY5 NORMAL NORMAL DISABLE 1 TRUE TRUE TRUE TRUE TRUE TRUE VALID GPIO3_PY.05 Output Drive 1 Disable Disable Disable Enable Mid Disable 10k XFI3_RST_N (SOC_QSFP_LP_N) CC12
/etc/systemd/nvpower.sh
function udev_mgbe_handler()
# INTERFACE environment variable is initialized by udev based on
# the interface detected by the kernel
inf=$INTERFACE
if [[ -e "/sys/class/net/$inf/carrier" ]]; then
connected=$(cat "/sys/class/net/$inf/carrier")
if [[ "$connected" -eq 0 ]]; then
ip link set dev "$inf" down
fi
fi
/etc/udev/rules.d/99-tegra-devices.rules
SUBSYSTEM=="net", KERNEL=="mgbe0_0", RUN+="/bin/bash /etc/systemd/nvpower.sh --mgbe"
SUBSYSTEM=="net", KERNEL=="mgbe1_0", RUN+="/bin/bash /etc/systemd/nvpower.sh --mgbe"
SUBSYSTEM=="net", KERNEL=="mgbe2_0", RUN+="/bin/bash /etc/systemd/nvpower.sh --mgbe"
SUBSYSTEM=="net", KERNEL=="mgbe3_0", RUN+="/bin/bash /etc/systemd/nvpower.sh --mgbe"
sudo cat /etc/netplan/90-NM-c19b17e2-f49c-3c83-99dc-b7cd9b26ca6e.yaml
network:
version: 2
ethernets:
NM-c19b17e2-f49c-3c83-99dc-b7cd9b26ca6e:
renderer: NetworkManager
match:
addresses:
- "192.168.1.60/24"
dhcp6: true
wakeonlan: true
networkmanager:
uuid: "c19b17e2-f49c-3c83-99dc-b7cd9b26ca6e"
passthrough:
connection.autoconnect-priority: "-999"
connection.timestamp: "1760080945"
ethernet._: ""
ipv4.address1: "192.168.1.60/24,192.168.1.1"
ipv4.method: "manual"
ipv6.addr-gen-mode: "default"
ipv6.ip6-privacy: "-1"
proxy._: ""
Thank you both for the information, it was helpful in determining that the setup we have should work. We have now managed to obtain link and transfer data over the DAC cable in both 10G and 25G mode. The issue was with a misbehaving clock signal on the MGBE UPHY, and fixing this allowed the link to come up.
