Thor QSFP to SFP+ Breakout
Hi all,
I’m working with a Thor AGX dev kit. We want to be able to use QSFP 100GB to 4x25GB SFP+ breakout with the Thor. Does anyone know if each SFP+ can be managed at different rates? (i.e. 2x SFP+ at 10GB and 2x SFP+ at 25GB?
Thank you for any help.
This document states
"In the Jetson AGX Thor Developer Kit, the QSFP port can support both 10 Gigabit Ethernet (10GbE) and 25 Gigabit Ethernet (25GbE). The default is 10GbE.
The QSFP port can support only one configuration at a time. To enable 25GbE, apply the following patches, rebuild the BSP, and flash the device."
jetson_thor_series_modules_designguide states:
  Four MGBE can run at 2.5/5/10 Gbps or 25 Gbps [validation in progress]. Note that MGBE at 25 Gbps requires all controllers to be at the same speed. If MGBE is not at 25 Gbps, controllers can be a combination of 2.5/5/10 Gbps.
