Is there a trick to this? I thought you could just add it to the virtual switch, but apparently the guest VM traffic isn’t routed across the infiniband fabric. I can ping the host machine, but no other machines on the network are ping-able.
Doing some more research, this seems to be an issue with IPoIB not wanting to be bridged, only NAT’d which vmware supports but not hyper-v, and my only option is network virtualization with SCVMM. Is there another way? has anyone deal with this before?
Related topics
Use RRAS to nat Infiniband connections to Virtual Machines?
0 | 160 | January 1, 2014 | |
| Pinging between KVM guests using IPOIB over Virtual Functions. | 1 | 790 | January 14, 2020 | |
Linux VM communication on IPoIB Network
3 | 251 | April 9, 2014 | |
A newbie problem with infiniband.
0 | 496 | March 19, 2014 | |
| Server 2012r2 VOLTAIRE Infiniband PCI-E HCA 500EX-D Dual-Port Cards | 0 | 280 | December 31, 2014 | |
| Bridged ethernet to infiniband switch. Possible to bridge on linux? | 1 | 500 | August 28, 2019 | |
New to infiniband, can't get a working connection.
22 | 2375 | September 9, 2013 | |
| A few questions about InfiniBand cards | 4 | 363 | April 6, 2013 | |
| IPoIB not working on Windows 2008 r2 - need help | 9 | 578 | July 12, 2013 | |
As must be configured Infiban 40 GB integrating VMware 5.x
3 | 209 | March 11, 2015 |
