DRIVE OS Version: 7.0.3
Issue Description: Should the default sample_lidar_replay initialize a TimeSensor?
Following up on my previous question TimeSensor::addData() Buffer full, draining data I don’t understand the reason why the sample_lidar_replay is initializing a TimeSensor when it is executed on the Thor platform .. more importantly why does it say “SensorFactory: Override default timeSensor with the user passed one” when I didn’t actually provide or set any time sensor information as shown in the logs below:
[08-02-2026 07:57:41] SensorFactory::createSensor() -> time.nvpps, nvpps-device=/dev/nvpps0
[08-02-2026 07:57:41] Found driver: time.nvpps
[08-02-2026 07:57:41] TimeSensorNVPPS: initialized with no UTC time reference.
[08-02-2026 07:57:41] output-timestamp parameter is deprecated and will be removed in next release
[08-02-2026 07:57:41] SensorFactory: Override default timeSensor with the user passed one
[08-02-2026 07:57:41] EndpointNVPPS: started on /dev/nvpps0
Can anyone explain to me what is the role of the TimeSensor within the sample_lidar_replay? is there any knobs that one could use to control this time sensor or disable it?
