We designed our carrier board with NX module. The difference to the devkit is we only connect CSI0 and CAM0_PWDN and no i2c mux. With single IMX219 camera, it can work on the devkit, but failed to work with our board (we use the devkit’s image file). So, I doubt we need do some changes to the device tree or the driver. As there are two cameras on the devkit carrier board, but we only have one on our board. So the I2C mux toggling has no effect on our board, it will always access the same camera. The driver may think there are two cameras on board. Will this cause some problem?
please modify the device tree since you’re having your customize board.
you may also share the kernel initial messages for camera device registration process.
furthermore, you should access Jetson Xavier NX Product Design Guide, please review [Chapter 9. MIPI CSI Video Input] for your CSI connection design.
thanks
I wonder if the Linux image for devkit can work with this configuration. Because the same camera can work on the devkit, so we expect it may work with our board.
The attached file is the output after run “gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! \ ‘video/x-raw(memory:NVMM),width=1280,height=720,format=NV12,framerate=120/1’ ! \ nvoverlaysink”
please check the reference driver,
for example, $L4T_Sources/r32.6.1/Linux_for_Tegra/source/public/hardware/nvidia/platform/t19x/jakku/kernel-dts/common/tegra194-camera-jakku-rbpcv2-imx219.dtsi
you’ll need to revise the device tree to adapt the settings to your customize board.
thanks
We’ve test this configuration on the devkit: DP + rbpcv2, it won’t work, same result with our carrier board. But with HDMI + rbpcv2, it work. So, the problem now is does devkit support DP and CSI co-work?
Are you talking about the DP cannot work (no matter the status of camera) at all or you are talking about the camera gst pipeline fails to render to the DP?
The DP is ok, but when connect both DP and rbpcv2,run “nvgstcapture-1.0” no output window pop out. If we connect a HDMI display, and connect rbpcv2, run same command, there will be a image window pop out. It seems the camera can’t capture any image if use a DP display, or the captured image can’t be shown on display with DP port?
I’ll try this later. But I find some interesting info on net. Please see the attached file, it’s from Waveshare’s tutorial for the camera, may Nvidia confirm this? And there are some discussion on net.
Waveshare’s tutorial say when run nvgstcapture-1.0 with the camera, must connect with HDMI display, or there will no image output. And in the link, some developers say when they run nvgstcapure on Jetson NANO with IMX219, and with DP display, no image output.
it’s by default having preview display rendering.
however, you may have gst pipeline combination to disable preview and shows frame-rate only.
for example, $ gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! 'video/x-raw(memory:NVMM),width=1920, height=1080, framerate=30/1, format=NV12' ! nvvidconv ! 'video/x-raw(memory:NVMM),format=I420' ! fpsdisplaysink text-overlay=0 video-sink=fakesink sync=0 -v
