I’m wondering if i have 2 servers close enough and i have a single Quadro Sync II. Lets say i have 2 RTX 5000 in both servers and i connect them all to the single Quadro Sync II will that work or can i only do multi-server/chassis sync with multiple QS2 Cards?
No, you will need a separate Quadro Sync II board for each chassis, and then connect the two Quadro Sync boards with a network cable in the RJ45 port. One system will be the timing server, and the other will be the timing client, and that way all 4 RTX 5000s will be synchronized.
