Hi, is someone know what i need to do in this case? “cannot allocate memory in static TLS block” when i am trying to use sklearn with jupyter on my Xavier NX (aarch64)
ImportError Traceback (most recent call last)
<ipython-input-18-31b3c7c2fd14> in <module>
14 import tensorflow.compat.v1 as tfc
15
---> 16 from sklearn.model_selection import KFold, cross_val_score, train_test_split
17 from sklearn.metrics import r2_score,mean_squared_error
18 from sklearn.preprocessing import MinMaxScaler
~/.local/lib/python3.6/site-packages/sklearn/__init__.py in <module>
79 from . import __check_build # noqa: F401
80 from .base import clone
---> 81 from .utils._show_versions import show_versions
82
83 __all__ = ['calibration', 'cluster', 'covariance', 'cross_decomposition',
~/.local/lib/python3.6/site-packages/sklearn/utils/_show_versions.py in <module>
10 import importlib
11
---> 12 from ._openmp_helpers import _openmp_parallelism_enabled
13
14
ImportError: /usr/lib/aarch64-linux-gnu/libgomp.so.1: cannot allocate memory in static TLS block
